Like Tree39Likes
 Old 12-27-2011, 09:33 PM   #1
RhoadBlock's Avatar
Posts: 793   (View Stats)
Groaned at 7 Times in 4 Posts
Default The Motor Mount Thread
*****Thank you to @Inquisitive; for a 2015 update!******
This thread will be for discussion of motor mounts for the MS3 & MS6. All currently available mounts are listed, relative prices, & links where they can be purchased. Note: you may be able to find them for sale elsewhere, possibly for cheaper. I simply linked them to their own company's site. If you have any questions regarding mounts, want to know which duro is best for you, etc, read thru this thread first! IF and ONLY IF it has not been answered already in this thread, post your new question in this thread. Do NOT create a new one.
Most of these if you buy brand new will come with installation instructions, but if you buy used and can't figure it out, or simply want to plan ahead, How-To's may be found in here:
MS3 How-To Database
MS6 How-To Database
One of the first mods almost everybody does is the Rear Motor Mount (RMM). As well you should. The factory bushings are mediocre and allow too much movement. There is a small amount of drivetrain slop and shifting may feel a bit notchy. Upgrading the RMM stiffens up the drivetrain slop quite a bit allowing for smoother shifting for one. The Passenger Side Motor Mount (PMM) & Transmission Mount (TM) are mediocre and are big eye sores to boot. Upgrading the mounts allows for much better shifting response and handling as the engine isn't rocking or being tossed around in the bay, but it comes at the expense of some NVH. Vibrations are felt at idle, tho this can be remedied by raising idle RPM if you have an AP. Vibrations often lessen after several months/several hundred miles of breaking in.
Genpu MMs:
• JBR RMM 88 & unknown durometer
• CP-E RMM Stage 2
• JBR TMM unknown
• CorkSport RMM
• JBR PMM unknown
• JBR RMM 80
• Sure RMM TorqR3 WARNING: read http://www.mazdaspeedforum.org/forum/foru...3/#post1927730
• JBR PMM 80
• JBR RMM 70
• Cobb RMM
• CorkSport TMM
• Damond Motorsports RMM
• JBR PMM 70 & 88
• CP-E TMM
• TRZ RMM
• CorkSport PMM
• Street Unit RMM WARNING: read http://www.mazdaspeedforum.org/forum/foru...3/#post1927730
• Ford Electric Focus RMM (RMM part number CM5Z-6068-A; bolt W500545S900)
• Minerva PMM & TMM (probably best to avoid, see Minerva Motorwerkz? )
• Sure PMM & TMM WARNING: read http://www.mazdaspeedforum.org/forum/foru...3/#post1927730
• AWR RMM 88
• Torque Solution RMM
• Turbine Tech Front Engine Mount
• Turbine Tech Differential Mount
Update using 2015 prices:
JBR RMM Urethane
MS6
MS3
Available from:
MS6
JBR RMM Urethane MS6
MS3
JBR RMM Urethane MS3
MS6 (Yes: 80a $105), MS3 1st Gen (Yes: 88a $100, 80a $125, 70a $125), MS3 2nd Gen (Yes: 88a $100, 80a $125, 70a $125)
CP-E RMM Stage 2 Rubber
MS6
MS3
Available from:
MS6
CP-E RMM Stage 2 Rubber MS6
MS3
CP-E RMM Stage 2 Rubber MS3
MS6 (Yes: 70a xFlex) $139, MS3 1st Gen (Not found), MS3 2nd Gen (Yes) $198
JBR TMM Urethane
MS6
MS3
Available from:
MS6
JBR TMM Urethane MS6
MS3
JBR TMM Urethane MS3
MS6 (Yes: 80a, 70a) $175, MS3 1st Gen (Yes: 88a, 80a, 70a) $185, MS3 2nd Gen (Yes: 88a, 80a, 70a) $185
CorkSport RMM Urethane
MS6's Insert
MS6's Full Replacement
MS3's Insert
MS3's Full Replacement
MS3's Race
Available from:
MS6
CorkSport RMM Urethane MS6
MS3
CorkSport RMM Urethane MS3 Gen1
CorkSport RMM Urethane MS3 Gen2
MS6 (Yes, Standard 70a) $115.99, MS3 1st Gen (Yes: Insert 70a $39.99, Standard 80a $99.99, Race 80a $125.99), MS3 2nd Gen (Yes: Insert 70a $39.99, Standard 80a $99.99, Race 80a $125.99)
JBR PMM Urethane
MS6
MS3
Available from:
MS6
JBR PMM Urethane MS6
MS3
JBR PMM Urethane MS3
MS6 (Yes: 80a, 70a) $175, MS3 1st Gen (Yes: 80a, 70a) $185, MS3 2nd Gen (Yes: 80a, 70a) $185
Cobb RMM
Available from: Cobb RMM MS3
MS6 (Not found), MS3 1st Gen (Yes) $159, MS3 2nd Gen (Yes) $159
CorkSport TMM Insert Polyurethane
MS6
MS3
Available from:
MS6
CorkSport TMM Insert Polyurethane MS6
MS3
CorkSport TMM Insert Polyurethane MS3
MS6 (Yes) $54.99, MS3 1st Gen (Yes), MS3 2nd Gen (Yes) $39.99
Available from: Damond Motorsports RMM MS3
MS6 (Not found), MS3 1st Gen (Yes), MS3 2nd Gen (Yes) $145 in black or gold mount and black or red bushing
CP-E TMM
Available from: CP-E TMM MS3
MS6 (Not found), MS3 1st Gen (Yes, 75a) $271.30, MS3 2nd Gen (Yes, 75a) $271.30
TRZ RMM
Available from: TRZ RMM MS3
MS6 (Not found), MS3 1st Gen (Yes), MS3 2nd Gen (Yes) $100
CorkSport PMM
Available from: CorkSport PMM MS3
MS6 (Not found), MS3 1st Gen (Yes), MS3 2nd Gen (Yes) $229.99
Available from: local Ford dealership
MS6 (Not confirmed), MS3 1st Gen (Yes), MS3 2nd Gen (Yes) $43.92 + $1.10
AWR RMM Urethane
MS6
MS3
Available from:
MS6
AWR RMM Urethane MS6
MS3
AWR RMM Urethane MS3
MS6 (Yes: 95a, 80a, 70a) $82, MS3 1st Gen (Yes: 95a, 80a, 70a) $95, MS3 2nd Gen (Yes: 95a, 80a, 70a) $95
AWR PMM Urethane
MS6
MS3
Available from:
MS6
AWR PMM Urethane MS6
MS3
AWR PMM Urethane MS3
MS6 (Yes: 95a, 80a, 70a) $172, MS3 1st Gen (Yes: 95a, 80a, 70a) $172, MS3 2nd Gen (Yes: 95a, 80a, 70a) $172
AWR TMM Urethane
MS6
MS3
Available from:
MS6
AWR TMM Urethane MS6
MS3
AWR TMM Urethane MS3
MS6 (Yes: 95a, 80a, 70a) $140, MS3 1st Gen (Yes: 95a, 80a, 70a) $225, MS3 2nd Gen (Yes: 95a, 80a, 70a) $225
Torque Solution RMM Polyurethane
Available from: Torque Solution RMM Polyurethane MS3
MS6 (Not found), MS3 1st Gen (Yes, 75a) $134.99, MS3 2nd Gen (Yes, 75a) $134.99
TRZ TMM
Available from: TRZ TMM MS3
Damond Motorsports PMM
Available from:
Damond Motorsports PMM MS3
MS6 (Not found), MS3 1st Gen (Yes), MS3 2nd Gen (Yes) $225 in black or gold mount and black or red bushing
MS6
MS3 Gen 1
MS3 Gen 2
Available from:
MS6
Turbine Tech Front Engine Mount MS6
MS3 Gen 1
Turbine Tech Front Engine Mount MS3 Gen 1
MS3 Gen 2
Turbine Tech Front Engine Mount MS3 Gen 2
MS6 (Yes) $359, MS3 1st Gen (Yes) $399, MS3 2nd Gen (Yes) $379
Available from: Turbine Tech Differential Mount MS6
MS6 (Yes) $289, MS3 1st Gen (Not found), MS3 2nd Gen (Not found)
DISIindahead likes this.
2007 MS6 - broked & gone
2006 MS6 - less broked
The Following 25 Users Say Thank You to RhoadBlock For This Useful Post:
2008speed3 (12-28-2011), ak_spray (12-28-2011), AZSPEED3 (06-09-2012), bazzarino (05-17-2012), Constantin (04-27-2012), DISIindahead (12-27-2011), dohc (01-03-2014), Ferdball (12-04-2012), flappypaddles (10-17-2013), jmhinkle (09-18-2012), karl-hungus (12-29-2011), mituc (08-13-2016), mxlplx71 (06-29-2012), OneStepBehind (08-10-2012), phate (01-13-2012), prosper0 (12-10-2015), Raider (12-28-2011), rdunny (07-03-2012), some call me...Tim (02-02-2015), speedaholic (12-24-2012), stogi1knobi (08-05-2012), Strangel (09-29-2013), uncorked11 (12-29-2011), wankular (12-28-2011), zpele (01-03-2012)
 Old 12-27-2011, 09:40 PM   #2
RhoadBlock's Avatar
Will tidy it up tomorrow. I may add the diff mounts for the MS6 later, but I already made a diff mount thread too. If anybody knows of any mounts I left out or any recommendations/suggestions let me know. Any grammar Nazis speak up too.
But for now, here you go.
The Following User Says Thank You to RhoadBlock For This Useful Post:
Big D (10-21-2014)
 Old 12-28-2011, 04:40 AM   #3
Badass! Nice work!
Corksport has rmm inserts for ms3.
CORKSPORT Rear Motor Mount Insert For Mazdaspeed 3
 Old 12-28-2011, 05:32 AM   #4
Jake5713's Avatar
Posts: 1,775   (View Stats)
Well done!!
I am here: http://maps.google.com/maps?ll=44.955562,-93.271084
-Jake
 Old 12-28-2011, 08:33 AM   #5
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
Nice job Rhoad!
Didn't see the RMM that I have installed-
the StreetUnit original-
MAZDASPEED 6 Motor Mount
340hp / 371tq
 Old 12-28-2011, 09:03 AM   #6
Two nuns and a pack mule
AtTheDriveIn's Avatar
Posts: 1,527   (View Stats)
Tt makes a front engine mount for the gen one ms3.
AtTheDriveIn is offline   Reply With Quote
 Old 12-28-2011, 10:07 AM   #7
MS3inDC's Avatar
Posts: 3,070   (View Stats)
MS3inDC is the leader of the worldMS3inDC is the leader of the worldMS3inDC is the leader of the worldMS3inDC is the leader of the worldMS3inDC is the leader of the worldMS3inDC is the leader of the worldMS3inDC is the leader of the worldMS3inDC is the leader of the worldMS3inDC is the leader of the worldMS3inDC is the leader of the worldMS3inDC is the leader of the world
Groaned at 56 Times in 37 Posts
I haz vibezzzzzzzzz
cobb ap v3 // RICHTUNE // autotech fpi // sp63 afc // cp-e nano // htp tip // nator dc fmic // nator dc PnP intake mani // hks ssqv *vta* // cs dp // su tp
jbr rmm(88duro) // jbr pmm(80duro) // cpe tm(75duro) // act 6-puck // act streetlite fw // jbr egr delete // md occ // sure ssb // nator dc sts // jbr hw shift knob
ebc red // rx-8s wrapped in conti dws 235/40s (winter) evo Xs wrapped in conti dw 235/40s (summer) www.sonictuning.com
311 whp - 345 lb/ft : Dynojet @ Moore Automotive *93 pump [4/13/13 MNM]
12.94 @ 109.00 @ Capitol Raceway *18' ASL [11/07/14]
I would wear a pink unicorn shirt, and still call someone a faggot. Since when did MSFers begin to give fucks?...
MS3inDC is offline   Reply With Quote
 Old 12-28-2011, 10:34 AM   #8
RhoadBlock's Avatar
Neutral  +1 score
Updated.
I added a bit of general info on upgrading the mounts to the OP. I'd like to get some discussion going on their reviews of the mounts. How was install? How is NVH now? How is NVH after the mount has been broken in? How much of an improvement was the mount/mounts to you?
It's great to have all the available mounts listed, but newbs are still gonna be asking "Which one is best?" etc. Let's get some feedback going so we don't have to keep seeing new Mount Threads popping up.
Force likes this.
The Following 2 Users Say Thank You to RhoadBlock For This Useful Post:
atvfreek (12-28-2011), Captainobvious (03-22-2013)
 Old 12-28-2011, 10:58 AM   #9
wankular's Avatar
Posts: 4,343   (View Stats)
I would add a sidenote about using red loctite for the CPE trans mount, in case anyone buys a used one without instructions. Avoid that whole fiasco again.
Any info on engine dampers (NRG, Ignalls, etc)?
As far as reviews, I have the original Street Unit RMM. After 1000 miles it was broken in and never really vibrated too much even from day one.
Edit: The TRZ MS3 rmm is available in two bushings - poly (street) and delrin (track). Also, if you run a Turbine Tech MS3 front mount, you probably won't be able to fit a FMIC.
2009 MS3 sport MGM
 Old 12-28-2011, 11:02 AM   #10
I'd offer the exact same review about my SU RMM as well, adding only that it simply did it's job and improved shifting quite a bit by controlling engine movement.
340hp / 371tq
 Old 12-28-2011, 11:04 AM   #11
v8 convert
p057's Avatar
Posts: 1,782   (View Stats)
p057 has disabled reputation
Groans: 220
p057 is offline   Reply With Quote
 Old 12-28-2011, 11:07 AM   #12
If anyone can snag the Turbine Tech products for a good price, do it. They are top quality so you get what you pay for. I have the front engine mount for the MS6, and now my engine and I are one. Shift thump, gone.
 Old 12-28-2011, 11:41 AM   #13
daztdMS6's Avatar
Posts: 214   (View Stats)
daztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond repute
Cool
+1 on what Ti said. Vibs are not noticable, but it controls the engine movement and improves shifting.
MazdaSpeed 6
DashHawk, CorkSport TIP & SRI, CorkSport TMIC, SU RMM, CPE rear diff mount, Perrin EBCS, TurboSmart BPV, TWM Stage 2 STS + metal bushings, Denso ITV-22, SM OCC, JBR EGR deletion & TIG, silicone boost tubes, Bilstein HD shocks, LED light bulbs, TRS clear projectors, 35W DDM Tuning HID foglights, Hawks HPS brake pads, Amsoil in the rear diff, pto & trans, factory navi, XCarLink USB.
daztdMS6 is offline   Reply With Quote
 Old 12-28-2011, 06:37 PM   #14
atvfreek's Avatar
Posts: 7,787   (View Stats)
Neutral  +1 score
I have cs Rmm inserts and they work pretty good. Basically no additional vibes.
I also just purchased a jbr 80 duro and took it out after 150 miles. A little too harsh for my taste and DD. Might through it back in and try breaking it some to see, but for now the cs inserts it is.
Tappin
2010 Speed3-PTE5858
Freek built/Freektuned
510hp420tq
11.321@129.93
 Old 12-28-2011, 06:42 PM   #15
Mizzle's Avatar
Posts: 2,829   (View Stats)
Groans: 324
There's a MS6 thing mixed in with the MS3 stuff.
 Old 12-28-2011, 08:09 PM   #16
RhoadBlock's Avatar
@Mizzle It's gotta be a mixed up link cause everything else is good, no? Which link was screwy?
 Old 12-29-2011, 12:10 AM   #17
Mizzle's Avatar
Groans: 324
Bushing - Engine Mount Replacement - 2.0inch - AWR Racing Store
after AWR PMM
 Old 12-29-2011, 04:23 AM   #18
RhoadBlock's Avatar
I was a retard last night. Def looked right over that. The bushings fit the MS6 too, but I changed the link to read MS3 instead of MS6.
 Old 12-29-2011, 06:09 AM   #19
v8 convert
p057's Avatar
Groans: 220
getting the RMM finally for my MS6.
cannot decide whether to get 70 or 88 Duro for the AWR RMM. I'd like effectiveness, but without rattling my teeth out.
 Old 12-29-2011, 06:16 AM   #20
reference point- stock rmm duro is about -10 (yes, minus ten)
used bubble gum would work better.
based on your selections and criteria, get the 70.
-however-
if you drive like an animal (LC & FFS, drag or autocross), and you can raise your idle a bit (if you haven't already), get the 88.
340hp / 371tq
Rainmens (12-15-2012)
 Old 12-29-2011, 06:32 AM   #21
patrick failman
karl-hungus's Avatar
Posts: 4,635   (View Stats)
Groans: 74
gold star! go trz if you're okay with vibes. the ladies will thank you.
 Old 12-29-2011, 06:59 AM   #22
v8 convert
p057's Avatar
Groans: 220
-however-
88 it is.
Yeah my idle is raised a fuck-ton to try and combat smoking.... doesn't really help but i like the idle anyways.
 Old 12-29-2011, 07:26 AM   #23
sounds like time for the bnoon bolt.
when I was running the oem dp I consistently whined about not wanting to take a chance on starving the turbo of oil. Amazing how going catless and becoming the city mosquito fogging service can changes your perceptions and attitudes on such things......
some due diligence later, i was unable to find any reports of oil starvation, or any damage for that matter, as a result of using the bolt. Indeed, I learned that the specs bnoon uses are considered to be standard for many turbos.
After installing the bolt, I've been able to drop my idle to 850 and still have about 98% of my smoking issue resolved. I am a fan, and encourage it's use when needed.
340hp / 371tq
ak_spray (01-03-2012)
 Old 12-29-2011, 10:14 AM   #24
RhoadBlock's Avatar
I don't recall any of that fiasco. Wasn't MS6 related so I didn't pay much attention to it. Shoot me a link to a good thread on it so I can catch up and mention it in the OP.
Also, I don't know anything about the engine dampers you speak of. I can haz infoes pleeze?
TiGraySpeed6 likes this.
wankular (12-29-2011)
 Old 12-29-2011, 10:18 AM   #25
cp-eTM xFlex Engine Mounts Recommendations and Notes
RhoadBlock (12-29-2011)
 Old 12-29-2011, 10:19 AM   #26
2011speed's Avatar
Posts: 1,497   (View Stats)
Tappin
any better shift feel with just the inserts?
FreeKtuned
fitty fitty
 Old 12-29-2011, 10:51 AM   #27
wankular's Avatar
The only thing I really know about ETD's is that they are usually only compatible with stock passenger mounts.
Here is a link to one on Street Unit:
Stiffy ETD, 2004-09 Mazda 3 & Mazdaspeed3
2009 MS3 sport MGM
The Following User Says Thank You to wankular For This Useful Post:
 Old 12-29-2011, 11:48 AM   #28
atvfreek's Avatar
Much better than stock. With the inserts we got a video of my car on the dyno, and the motor didnt move at all. I'm sure a hard shift or launch it'll move. But for DD and some spirited driving the inserts work great
2010 Speed3-PTE5858
510hp420tq
11.321@129.93
 Old 12-29-2011, 01:09 PM   #29
RhoadBlock's Avatar
mmmm....after looking at it I don't really like it. You'd be better off with just upgrading the mount itself with the the lower duro bushings if you're still worried about NVH. Especially for the price. Plus this is the mount thread, not the goofy engine damper thread lol.
Has an IRL person ever bought one for the MS3?? If we find one person who has I'll add it to the OP. Until then I won't worry about it. I've never even heard of it and I've been around the DISI forums for 5 years now.
If someone really wants it there tho, let me know. I'll put it in OP.
 Old 01-03-2012, 08:55 AM   #30
goob_os101's Avatar
Posts: 697   (View Stats)
goob_os101 is the leader of the worldgoob_os101 is the leader of the worldgoob_os101 is the leader of the worldgoob_os101 is the leader of the worldgoob_os101 is the leader of the worldgoob_os101 is the leader of the worldgoob_os101 is the leader of the worldgoob_os101 is the leader of the worldgoob_os101 is the leader of the worldgoob_os101 is the leader of the worldgoob_os101 is the leader of the world
Guess I neeed to hit up the gym...I could not get the three bolts off to install my CP-e RMM yesterday. I may have torn my nut sakz.
johnspeed3 and edmsmallcash like this.
goob_os101 is offline   Reply With Quote
 Old 01-03-2012, 08:58 AM   #31
Neutral  +1 score
Air tools are so much win. Took forever installing the RMM on my MS3, the 3 bolts had 332545342 lbs of torque at the factory. In installing a RMM on an MS3 the other day, impact gun bussed them off in .23 seconds.
Take it to a mechanic, pay $10 for it to go up on a lift and have them removed with impact, then torqued to 70 lbs, or just have them install the mount, using blue loctite on the bolt threads at reinstall.
 Old 01-03-2012, 09:12 AM   #32
goob_os101's Avatar
^ Since I am a Army Civilian I can go over to the Ft. Myer Auto Shop...$6/hr for lift and all tools you need. I put coilovers on my old Saabaru for $12
Tadweezy likes this.
 Old 01-03-2012, 09:29 AM   #33
RhoadBlock's Avatar
Damn I would KILL to have a good shop around here that rents lifts/tools. I've got the tools but I need a lift so bad. Would make my build a million times easier. But every shop I've asked won't rent lifts for liability/insurance reasons. But damn they'd make a killing off myself alone if they did.
 Old 01-03-2012, 02:43 PM   #34
goob_os101's Avatar
Ft. Myer is a Army base here in Arlington, VA. I work for the Army as a civilian so I have access to the base's auto shop.
 Old 01-09-2012, 06:30 AM   #35
v8 convert
p057's Avatar
Groans: 220
Originally Posted by p057 View Post
88 it is.
Installed RMM on friday. but i accidentally hit my hand with a hammer and i had a huge blood blister thing right between my thumb and index finger. Should have taken an hour at tops, took two since the damn blister was painfully in the way.
Also, i bought the AWR RMM. You HAVE to cut off those stupid prongs. I tried bending them away and that resulted in a ton of fail. (one of the ends of the prongs are welded on.) Pulled out my multi-tool and cut the metal away in less time than it took to debate whether or not to keep bending/prying vs cutting. That metal is relatively soft.
Once that was put in, put everything back up and drove it down the road. LOVED it. soooo smooth. and NVH was NOTHING. I mean, the tiny ass amount of vibes was so little. I am really disappointed that people were telling me to go softer. too soft.
Seriously, pussy. Now that i put 60 miles on it, i barely feel it anymore and i kinda wish i went with a higher durometer count than that...
As far as the mount itself, if you really feel that you dont care (and have the means) about cutting the prong-things at the frame and would like to save a few bucks, go the AWR mount route. get a higher durometer count. 88 is really just minimum you should go at all. i would love to jump up to 95 DM
Other than that, go the sure/cpe/SU RMM route... it's brain-dead easy.
The Following User Says Thank You to p057 For This Useful Post:
Elvinf25 (12-19-2014)
 Old 01-09-2012, 06:52 AM   #36
IshiKage's Avatar
Posts: 6,231   (View Stats)
Groans: 278
@RhoadBlock
you forgot to add the Torque Solution RMM, they are coming with the other mounts too. Love my TS. can be bought through MAPerformance
2015 Mazda 6
The Following User Says Thank You to IshiKage For This Useful Post:
RhoadBlock (02-29-2012)
 Old 01-09-2012, 01:26 PM   #37
guerrero1977's Avatar
Posts: 32   (View Stats)
guerrero1977 has a brilliant futureguerrero1977 has a brilliant futureguerrero1977 has a brilliant futureguerrero1977 has a brilliant futureguerrero1977 has a brilliant futureguerrero1977 has a brilliant futureguerrero1977 has a brilliant futureguerrero1977 has a brilliant futureguerrero1977 has a brilliant futureguerrero1977 has a brilliant futureguerrero1977 has a brilliant future
Any feedback on J Barone TMM???
guerrero1977 is offline   Reply With Quote
 Old 01-11-2012, 05:34 PM   #38
evolizzee's Avatar
Posts: 601   (View Stats)
evolizzee is the leader of the worldevolizzee is the leader of the worldevolizzee is the leader of the worldevolizzee is the leader of the worldevolizzee is the leader of the worldevolizzee is the leader of the worldevolizzee is the leader of the worldevolizzee is the leader of the worldevolizzee is the leader of the worldevolizzee is the leader of the worldevolizzee is the leader of the world
Groaned at 17 Times in 6 Posts
get used to gear noise with the JBR TMM, and plastic vibes from the JBR PMM
2011 Blue Mica 50% E85
COBB: AP, DP, SRI, TIP, OCC // Blitz Steel Mesh Filter // SURE: RMM, Boost Tubes, Counter Weight, Shift Anchors, AGS Knob // JBR: Tranny Mount, Passenger Mount// PT-P: HPFP, Rail Valve // PCV Vent // Forge BPV V1 // ETS 3.5" TMIC // NGK IXs // EGR Delete // Resonator Delete // FoMoCo Gear Oil // Castrol Syn Power 5w-40 // Koni Yellows // H&R Sport Springs // SPC Camber Arms// Spec: Stage 3+ SR Clutch, 12lb Flywheel
13.2@113mph
evolizzee is offline   Reply With Quote
 Old 02-11-2012, 04:06 PM   #39
frequencysurfer's Avatar
Posts: 232   (View Stats)
frequencysurfer is the leader of the worldfrequencysurfer is the leader of the worldfrequencysurfer is the leader of the worldfrequencysurfer is the leader of the worldfrequencysurfer is the leader of the worldfrequencysurfer is the leader of the worldfrequencysurfer is the leader of the worldfrequencysurfer is the leader of the worldfrequencysurfer is the leader of the worldfrequencysurfer is the leader of the worldfrequencysurfer is the leader of the world
Shit, my TRZ dogbone has the plastic vibrating already and after ~8k miles it's still annoying.
What duro JBR TMM/PMM did you go with? I'm thinking of doing 70 for the TMM/PMM and replacing the TRZ with the JBR dogbone...
frequencysurfer is offline   Reply With Quote
 Old 02-13-2012, 10:59 AM   #40
rednofive's Avatar
Posts: 250   (View Stats)
rednofive is the leader of the worldrednofive is the leader of the worldrednofive is the leader of the worldrednofive is the leader of the worldrednofive is the leader of the worldrednofive is the leader of the worldrednofive is the leader of the worldrednofive is the leader of the worldrednofive is the leader of the worldrednofive is the leader of the worldrednofive is the leader of the world
Neutral  +2 score
Default Useful RMM search results and RMM location video
I spent 1 hour last night and 3 hours today reading about RMM since I've only modified my MS3 with gauges, wheels, and yellow fog lights.
For those considering the job - a simple vid showing where and what needs to be unbolted:
Here's the best post I could find (IMHO):
Rear motor mount
And all these conversations were damn useful:
CP-E Rear Motor Mount Install
Corksport motor mount inserts INSTALLED!
Rear motor mount
Rear Stock motor mount mod
What motor mount should I get?
http://www.mazdaspeedforum.org/forum/foru...bushing-51562/
CP-E RMM in stock
MM inserts
http://www.mazdaspeedforum.org/forum/foru...p-first-21818/
My summary of all that great MSF feedback?
  • Want something cheap with better reinforcement and shifting improvement over stock that you might have to "re-fill" in a few ten's of thousands of miles? Corksport inserts
  • Most felt that 60A or 70-75A durometer hardness were enough to get the better shifts and launch smoothness they wanted
  • Some felt that A/C turned on with 60 or 70-75A hardness was just too much
  • Most felt that the additional vibration will go away (or they got used to) after about 1000 miles, with or without A/C on: CP-E 60A/75A or SU 62A(street)/?#?(track)
  • Many posts I found with those with CS inserts upgraded something with 60A hardness, then wish they had gotten 75 (or the like)
  • Many posts I found with those with a 60-hardness anything wanted a 75.
  • Only those that didn't care at all about vibes and claimed to want 0-wheel hop went TRZ.
  • Most common drag/track response: go TRZ.
  • Those that felt the vibes but wanted the benefits raised their idle to 850 to 1000 RPM to win the compromise
There, I hope I just saved all future MS3 noobs like me 4 hours of their life.
It helped me make up my mind...
Update from June 2012....
I've got over 1000 miles on the CP-E 75 durometer and the vibes are nothing to think about. I don't notice them much anymore unless I use my AC. Raising idle to 1000 RPM would completely remove them.
That said, vibes or no vibes, the mod is amazing. the car scoots and stays planted. I'm now able to spin the tires at will and can now feather the throttle to get the acceleration I want and even when shifting into 3rd (though I have no-season tires on, so take that FWIW). The differential is working more now and acceleration through turns is amazingly improved. I still remain shocked at how cool (and cheap) a mod this is.
A MUST DO MOD!
5
Forget coffee...I get my morning boost in 4th at 5K!
2008 Black Mica MS3
Mazda RX-8 50mm ET 18"x8" Dupli-color Graphite/Clear with 245/40/18 Continental DWS No-season Tires
CS SRI | CS TIP | TMIC | HPFP
CP-E RMM
JBR SSP (30%) | JBR SSB | JBR RSB
Koni Yellows on stock springs
rednofive is offline   Reply With Quote
The Following 14 Users Say Thank You to rednofive For This Useful Post:
ak_spray (02-29-2012), batmsp3 (01-12-2014), flappypaddles (10-17-2013), jweller (04-19-2015), loudneighbor (04-23-2012), nicholas.oday (05-11-2012), OttoSpeed (01-31-2013), RhoadBlock (02-29-2012), SC_Galoot (08-02-2012), sick_role (02-13-2012), some call me...Tim (10-05-2013), Staceye77 (06-01-2012), steevieg (10-05-2013), sxman (11-26-2013)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f10/motor-mount-thread-100696/
Mazda3 Forums : The #1 Mazda 3 Forum - View Single Post - Rmm This thread Refback 12-18-2015 12:05 PM
Rmm - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 10-06-2015 06:35 AM
Motor mount discussion - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum This thread Refback 04-06-2015 07:23 PM
How to: Left Side Trans Mount This thread Refback 06-05-2014 09:30 AM
Motor Mount Inserts vs. Rear Motor Mount Pro's n Con's Dre 2010 MS3 - Engine, Transmission & Driveline 23 05-21-2016 08:47 AM
another blowing motor thread campbell MazdaSpeed 3 - Engine, Transmission & Driveline 40 04-16-2010 08:19 PM
is transmission mount the same as motor mount? spoonher MazdaSpeed 3 - Engine, Transmission & Driveline 10 08-26-2009 02:21 PM
weakest motor mount..? what mount takes a dump first? Lvis MazdaSpeed 3 - Engine, Transmission & Driveline 29 03-02-2009 11:39 PM
Page generated in 0.67718 seconds with 39 queries
