 Old 10-19-2009, 07:30 AM   #1
the_caruch's Avatar
Posts: 698   (View Stats)
the_caruch is the leader of the worldthe_caruch is the leader of the worldthe_caruch is the leader of the worldthe_caruch is the leader of the worldthe_caruch is the leader of the worldthe_caruch is the leader of the worldthe_caruch is the leader of the worldthe_caruch is the leader of the worldthe_caruch is the leader of the worldthe_caruch is the leader of the worldthe_caruch is the leader of the world
Default My Review: cp-e catted downpipe
I'll try to get pics/ exhaust video up asap.
edit: got a CEL today on the way to work (highway) without even getting it checked i can bet it's saying that my cat is "below efficiency" but is just detecting more emissions since..well.....it IS a high flow cat happened on the last car i owned too after a downpipe.
Just finished up installing the cp-e catted downpipe yesterday on my speed 3. The install was ok...not the best...but ok. Just time consuming , but everything went on great. No bolts were seized (including both o2's) so that made it better. I made sure to put anti-seize on the bolts so any future removal will be easy.
Install
The install difficulty wasn't bad. I'm usually one to pawn this work off to my brother who works on cars for a living but decided to tackle this myself. So while the install has it's "moments" if I can do it, you can too. For me, I'd say this is a 6 out of 10
Things i ran across
The rear o2 connector (the one connected to the wiring harness) I had to break free from the bracket that it was stuck against so the connector would reach to rear o2. Otherwise is was way too tight to fit on in the stock location. the rear o2 bung needed to be about 1/2 inch more up the exhaust to fit without breaking the connector free. (I've heard complaints about this before) It took a while but eventually I got it plugged in.
I also forgot to unbolt the stock downpipe bracket that is bolted to the frame (hence why the downpipe kept getting stuff trying to put it in place). it's a big thick piece of metal, be sure to take that thing out
Don't forget the order of which you remove/re-install things...such as remembering to re-install the intercooler bracket first and then the top manifold heat shield. etc, etc.
LABEL YOUR BOLTS, meaning i put them in separate plastic baggies for each section and wrote on them with a sharpie "heat shield" "downpipe studs" "power steering bracket" it makes for such an easier re-install when you know which bolts are which.
After you unwind the front o2 wire from the clips and spiral holder be sure to bend them flat against the stock downpipe heat shield so they don't get caught everywhere when you are removing it.
Don't get hit in the face with a 14mm socket while under the car when your dad drops it
Quality
Awesome. I bought this used with just a couple hundred miles on it so everything was in great shape. The welds were perfect and everything lined up.
My only complaint is the rear o2 bung is slightly too far down the exhaust.
Performance
Very nice. The SOUND is amazing. I have the HKS hi-power exhaust and it brings a lot more "burble" or rumble out of the exhaust.
Performance is great! I haven't gone the 50-60 miles for the ECU relearn yet but it definitely spools a heck of a lot faster and just feels like it runs through the gears faster even under normal city driving. The sound in the upper RPM's is incredible, you hear the engine so much more and then tone has changed and it just sounds plain mean
Overall
I recommend this to anyone, the install REALLY isn't that bad, but if you are not too good at car work (like myself) devote a day for this job.
cp-e CAI, cp-e Turbo Inlet, cp-e catted DP, cp-e HPFP, cp-e flashes, cp-e Standback w/PNP, cp-e FMIC, TRZ RMM, TS Compact BOV (full re-circ), DDM 55W 6k HID's, Cobb RSB. HKS Hi-Power Exhaust, OCC
the_caruch is offline   Reply With Quote
The Following 2 Users Say Thank You to the_caruch For This Useful Post:
jonnyspeed3 (06-05-2013), RedMS3 (05-14-2014)
 Old 06-05-2013, 07:04 PM   #2
jonnyspeed3's Avatar
Posts: 6   (View Stats)
jonnyspeed3 will become famous soon enoughjonnyspeed3 will become famous soon enough
Very nice review this will definetly be my next purchase.
-2012 mazdaspeed3/black mica.
MODS: COBB AP STAGE 2/ CORKSPORT SRI/TIP/ TURBOSMART 50/50 BOV/ CP-E 75duro/ AT HPFP/ RALLY ARMOR MUDFLAPS/ 600K HID'S LOW/FOGS/ TWM BIG TYPE R SHIFT KNOB/ CORKSPORT CBE/ CORKSPORT RACEPIPE.
soon to come:
-FMIC
-twm STS
-corksport downpipe
-cp-e safe seals
-gtx3071r
-E-tune
jonnyspeed3 is offline   Reply With Quote
 Old 06-05-2013, 07:09 PM   #3
faeker's Avatar
Posts: 5,091   (View Stats)
Groans: 731
Neutral  -2 score
good job on rezzing a fucking 3 and a half year old thread that nobody gives a fuck about anymore. fuck you.
Mods: stock
 Old 06-05-2013, 07:26 PM   #4
 Old 06-05-2013, 07:28 PM   #5
faeker's Avatar
Groans: 731
.........this guy..........
has the interior I wish i could do. Bastard.
Mods: stock
Code Monkey (06-05-2013), daafisch (06-05-2013)
 Old 06-05-2013, 08:00 PM   #6
twenty5psi's Avatar
Posts: 213   (View Stats)
You should pick up a CP-E Standback for your next mod.
2013 MS3 VRM w/Tech
CPE Catted downpipe SPL Ftaz1 Custom Performance Engineering (cp-e.com) 17 02-04-2010 08:17 AM
catted downpipe? tbone Mazdaspeed3/6 General Discussion 3 02-03-2009 04:00 PM
cp-e catted downpipe bova MazdaSpeed 6 - Engine, Transmission & Driveline 10 12-01-2008 11:16 PM
Page generated in 0.27882 seconds with 24 queries
