 Old 07-05-2009, 05:34 AM   #1
prince igor's Avatar
Posts: 3   (View Stats)
prince igor is an unknown quantity at this point
Default Need some advanced technical data about 2.3L DISI Turbo (L3-VDT)
Hello.
i don't if i posted in the right section of the forum,hope it will be ok.I am in need in some advanced technical data regarding this engine.I am making a simulation for my diploma project and in order to complete this simulation I need some data.
Info that i need are the following:dimensions of the intake-exhaust valve,the diameter,valve lift let's say from 5" to 5" crank rotatation(" = degrees),3-angle specification of the valve seat ,turbochargher type (name,dimensions of inducer-exducer both for kompressor and turbine,injectors - flow,number of holes of the pintle-head....
Any information is of any help...just to be acurate.
I had found a manual for the Mazda 3 MPS but i was disapointed when I found that there are no info or drawings regarding the cross-section of the cylinder head (i can aproximate the dimensions of the intake-exhaust ports),the timing diagram,the dimensions for the intake-exhaust valve,the injector characteristics are only available for the NA engine not for the TC engine.
If some one can help me with some data,drawings,the help is very appreciated.
THX.
igor
prince igor is offline   Reply With Quote
 Old 07-05-2009, 06:34 AM   #2
fhaze's Avatar
Posts: 552   (View Stats)
fhaze is the leader of the worldfhaze is the leader of the worldfhaze is the leader of the worldfhaze is the leader of the worldfhaze is the leader of the worldfhaze is the leader of the worldfhaze is the leader of the worldfhaze is the leader of the worldfhaze is the leader of the worldfhaze is the leader of the worldfhaze is the leader of the world
Groaned at 9 Times in 9 Posts
The Factory Service Manual should have what you are looking for.
Goodbye 06MS6 you were a great car.
2011 STi Limited w/ NAV Plasma Blue Pearl, Escort 9500ix, Invidia Catted TBE 3" Q300 Ti Tip, Cobb CAI + Box, AP Stage 2+ 93, Kartboy SS w/ Bushings, Rally Armor Flaps.
303whp/330lbft Pro-Tuned @ EFI Logics
“A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens, and you go faster.”
--Mr. Clarkson
fhaze is offline   Reply With Quote
 Old 07-05-2009, 06:47 AM   #3
I found a manual but I can't find any info (even the timing diagram).
Where I can find a Factory Service Manual for L3-VDT?
 Old 07-07-2009, 07:18 AM   #4
NEC
subparpunk03's Avatar
Posts: 1,267   (View Stats)
I think this is the compressor map for our turbo:
http://i260.photobucket.com/albums/i...g?t=1198288557
Its a Borg Warner K04.
Not sure how much it helps, buuuut at least its something.
I think someone around here had gotten flow #s for the injectors, but I don't recall exactly. Direct injection is a new ballgame and there are like only 2 rigs in the US capable of flow testing direct injectors and I think they probably belong to Ford and BMW cause they each cost bigtime money. I don't think the manuals have flow #s for the ms3.
2006 Lotus Elise: Toy car
2007 Mazdaspeed 3: *sold*
2005 Corolla XRS: *sold*
 Old 07-07-2009, 09:52 AM   #5
THX for the response.
I shall try to find the injector flow in this forum.
MazdaSpeed 2.3L DISI Turbo Blown Engine Resource Thread JimmyMac MazdaSpeed 3 - Engine, Transmission & Driveline 1441 06-25-2019 06:11 PM
Mazdaspeed 2.3L DISI Turbo Blown Engine Resource Thread Kennosuke MazdaSpeed 6 - Engine, Transmission & Driveline 1 04-27-2009 01:26 AM
q"s for all big turbo disi cars ms3guy22 MazdaSpeed 3/6 - Turbo Induction 9 02-23-2009 11:26 AM
A-DATA 4GB Micro SDHC Class 6 Flash Card Model Turbo microSD $14.49AR Haltech Hot Deals Section 0 04-02-2008 12:50 PM
A-Data Turbo 8GB SDHC Card $27.49 Haltech Hot Deals Section 0 04-01-2008 03:40 PM
Page generated in 0.26534 seconds with 22 queries
