  • 1 Post By keymaster
 Old 02-27-2013, 03:38 PM   #1
Zeya's Avatar
Posts: 992   (View Stats)
Zeya is the leader of the worldZeya is the leader of the worldZeya is the leader of the worldZeya is the leader of the worldZeya is the leader of the worldZeya is the leader of the worldZeya is the leader of the worldZeya is the leader of the worldZeya is the leader of the worldZeya is the leader of the worldZeya is the leader of the world
Default Serpentine Belt
Owner's manual doesn't say. Can't find confirmation in a thread search. Parts websites yield differing circumferences.... Can someone please verify for me that this is the proper serpentine belt?
Dayco 5060910 Serpentine Belt : Amazon.com : AutomotiveDayco 5060910 Serpentine Belt : Amazon.com : Automotive
Size: 91" long by .82" wide with six ribs
Thanks in advance.
2008 MS3 GT ~ Cobb SRI, Cobb turbo inlet, CPE rear motor mount, Koni FSD shocks
Zeya is offline   Reply With Quote
 Old 02-27-2013, 03:47 PM   #2
helmetface's Avatar
Posts: 5,685   (View Stats)
Groans: 219
Cross check it at rock auto . com or onlinemazdaparts
 Old 02-27-2013, 03:56 PM   #3
Zeya's Avatar
Thanks, I found confirmation at rockauto. Looks like it will work.
The Following User Says Thank You to Zeya For This Useful Post:
helmetface (02-27-2013)
 Old 02-28-2013, 07:19 AM   #4
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
lmfao at checking part compatibility at rock auto.
That belt is actually kindof short, the Gates belt is slightly about 0.5" longer which makes it easier to install. OEM is also about 0.5" longer iirc.
2006 Mazdaspeed 6
jack_hammer (04-03-2013)
 Old 03-31-2013, 11:34 AM   #5
Zeya's Avatar
For anyone reading this thread in the future, I ended up getting the belt in the first post and it is in fact too small. I don't know what the proper part number is (I took all my parts to the shop and they ordered me the right belt).
06Speed6 (03-31-2013)
 Old 03-31-2013, 09:00 PM   #6
Speeeeeed
06Speed6's Avatar
Half an inch does make a difference
2006 Mazdaspeed 6
 Old 03-31-2013, 09:46 PM   #7
keymaster's Avatar
Posts: 397   (View Stats)
keymaster is the leader of the worldkeymaster is the leader of the worldkeymaster is the leader of the worldkeymaster is the leader of the worldkeymaster is the leader of the worldkeymaster is the leader of the worldkeymaster is the leader of the worldkeymaster is the leader of the worldkeymaster is the leader of the worldkeymaster is the leader of the worldkeymaster is the leader of the world
TWSS
06Speed6 likes this.
2007 Mazdaspeed 6 GT
keymaster is offline   Reply With Quote
The Following 3 Users Say Thank You to keymaster For This Useful Post:
06Speed6 (04-01-2013), jack_hammer (04-03-2013), mWindu (04-13-2013)
 Old 04-03-2013, 01:41 PM   #8
jack_hammer's Avatar
Posts: 6,822   (View Stats)
Groans: 549
you might should read this before buying from rock auto.
Rock Auto - What doesn't fit??
that's exactly what i thought when i read that.
OP - oreilly and advance both show the manufacturer part numbers. you can also go to the manufacturer websites and check as well. they usually have the parts listed there.
it's fun to do bad things
 Old 05-24-2016, 12:09 PM   #9
GroceryGtr's Avatar
Posts: 472   (View Stats)
Neutral  +1 score
reviving a dead thread for future searchers. Dayco/Goodyear brand you need to get the 915 length, the listed 910 is too short by a mile. Same for the bargain driveworks brand from advance 915K6 is the correct fit. you can use a 918 length but you wont have a ton of room left on the ole tensioner for stretch.
The Following 2 Users Say Thank You to GroceryGtr For This Useful Post:
KnowUhhTee (07-29-2016), Zeya (05-24-2016)
MS6 Serpentine belt - lessons TR4guy MazdaSpeed 6 - Engine, Transmission & Driveline 5 12-09-2013 01:01 PM
Routing the serpentine belt Spectrum24x Mazdaspeed3/6 General Discussion 4 10-08-2012 06:20 PM
Serpentine belt 07Speed3007 MazdaSpeed 3 - How-To's 19 02-12-2011 08:01 PM
08 MS3 Serpentine belt question?? gamma500 MazdaSpeed 3 - Engine, Transmission & Driveline 8 01-09-2011 06:49 PM
Page generated in 0.32455 seconds with 25 queries
