![]() Join Date: Feb 2013 Location: Oak Ridge, TN
Rep Power: 88 ![]() Thanks: 32
Groans: 60
| Not Ranked : 0 score Unless its giving you problems or you want taller gearing, nothing much to do with the transmission.. If you want to be 100% certian you could pull it apart and check the actual gearsets.
(Thread Starter) | Not Ranked : 0 score Thanks, Installer, for your thoughts. I've learned all lessons the hard ($$$) way so far with this car....my Mazdarati , and don't want to schooled again at this late date. Just snoopin' around to benefit from what others might have experienced. |
| Differences between a ms6 trans and a ms3 trans? | alex_dewitt_ms3 | MazdaSpeed 3 - Engine, Transmission & Driveline | 6 | 07-28-2016 08:24 AM |
| Build my engine or built longblock? Built trans? | Mustangkr500 | Mazdaspeed3/6 General Discussion | 24 | 07-22-2016 12:17 PM |
| trans pto rear diff build | Matx | MazdaSpeed 6 - Engine, Transmission & Driveline | 5 | 08-24-2012 01:22 PM |
| Suggestions (ECU, trans, rear end, etc) for MZR build | DarkPasseng3r | Gen2 MS3 General Discussion | 5 | 06-06-2012 04:54 PM |
