 Old 05-16-2014, 06:32 AM   #1
Rob84's Avatar
Posts: 598   (View Stats)
Rob84 is the leader of the worldRob84 is the leader of the worldRob84 is the leader of the worldRob84 is the leader of the worldRob84 is the leader of the worldRob84 is the leader of the worldRob84 is the leader of the worldRob84 is the leader of the worldRob84 is the leader of the worldRob84 is the leader of the worldRob84 is the leader of the world
Default 06 speed 6 boost issue
I have and 06 speed6 like the title says, cs Sri tip. When I get on it I cannot get more than 14lbs. I'm running the cobb ots for stage 1 for the above mods. I had it leak tested at awd tuning a couple weeks ago and they said that there is no leak that they can find, the map looked "fine." But targets should be around 16.5. Not sure where to start. Any help would be greatly appreciated. I will post some logs after work tonight.
06-MS6-Cobb AP- Corksport SRI and TIP- Custom Exhaust- KMD Internals- Turbosmart BPV- Test Pipe- ETS Top Mount- JBR Boost Tubes- Cobb 3 Port EBCS-
Freektune on corn
Rob84 is offline   Reply With Quote
 Old 05-16-2014, 06:52 AM   #2
Agent_Orange's Avatar
Posts: 3,575   (View Stats)
Groans: 665
Posting a WOT log would be a good start.
Be sure to include:
Accel Pedal Position
Actual AFR
Boost PSI
Boost Air Temp.
Calculated Load
Coolant Temp
HPFP Actual Press.
Injector Duty Cycle
Intake Temp
Intake Valve Advance
Knock Retard
LTFT
MAF Volatage
Mass Airflow
RPM
STFT
Spark Advance
Throttle Position
WGDC
 Old 05-17-2014, 08:33 AM   #3
Rob84's Avatar
here is a couple logs. i forgot to change the settings of what is logged, i will get more today
Freektune on corn
 Old 05-17-2014, 09:44 AM   #4
Groans: 665
It looks like your hardware limited.
Boost Air Temps are pretty toasty due to your heatsoaked TMIC
Knock Retard is ramping up, and the ECU is pulling timing and richening the AFR to prevent detonation.
Hot air is less dense, hence your turbo has to work harder to force it into the cylinder. Boost levels take a hit and even more heat is generated.
Out of curiosity, what does your "custom exhaust" consist of?
 Old 05-17-2014, 09:48 AM   #5
Rob84's Avatar
Single exit 3" cat back to a flowmaster
Sent from my SPH-L710 using Tapatalk
Freektune on corn
 Old 05-17-2014, 10:01 AM   #6
Groans: 665
Monitor your BATs, and try to avoid going WOT when your heatsoaked like that.
You can see in the other log, BATs are about 40 degrees cooler, and there is little to no KR when you go WOT.
Other than that, you need to get HPFP internals, and then go FMIC or spray meth. Or both.
 Old 05-17-2014, 10:02 AM   #7
Rob84's Avatar
Im watching kr as im driving and just saw 6.7. So yea no more wot.
Freektune on corn
 Old 05-17-2014, 10:22 AM   #8
Groans: 665
Keep in mind, partial throttle KR is totally normal. So if you see it cruising around, no big deal.
Only at WOT does it throw red flags.
You may also want to try flashing a Stage 0 or SafeMode map.
 Old 05-17-2014, 10:51 AM   #9
Rob84's Avatar
If its this bad now its going to be really bad when its hot out in texas
Freektune on corn
 Old 05-17-2014, 11:25 AM   #10
Groans: 665
For sure. That's why the vast majority of gen 1 guys choose to go FMIC.
Without a hood scoop, you can grill burgers on that TMIC.
 Old 05-17-2014, 12:01 PM   #11
Rob84's Avatar
Nice.
Freektune on corn
Boost issue Moosheep Gen2 MS3 General Discussion 6 07-26-2013 07:04 AM
Need Help with a possible Boost Cut issue??? EddyV1987 MazdaSpeed 3/6 - Big Turbo Builds 7 04-24-2013 04:24 PM
Boost issue sriser66 MazdaSpeed 3/6 - Turbo Induction 4 03-19-2013 10:40 PM
Issue with hpfp/boost?!?! please help maf07003 Mazdaspeed3/6 General Discussion 15 02-25-2013 09:18 PM
Hypertech Boost issue? ANMSPD3 MazdaSpeed 3/6 - ECU Computer Tuning 26 05-04-2010 08:48 AM
Page generated in 0.29959 seconds with 22 queries
