 Old 09-17-2018, 12:16 AM   #1
Solarsurge's Avatar
Posts: 577   (View Stats)
Originally Posted by delbertdrew View Post
hi folks,
I'm here as the mechanic (father) of a 2010 speed3 owner (daughter). I've been on here as a guest in the past, and for the most part, it's been very helpful.
Now I'm searching diligently for answers to the excessive smoking when started, and for way to long after its been started. There is also a problem with stalling when stopping. But, as suggested, I'm weeding through the many posts before i throw my hands up. I've found 3 different "fixes" so far, and they all seem very convinced that theirs is the real solution.
Intake valve seals, oil restriction bolt, drain tube. It's exhausting and a bit frustrating at times. Think I'll just redo it all
K, I'm done ranting Thanx
Smoking from the tailpipe can only be one of two things (aside from engine problems). It's either oil burning from leaking seals in the turbo (turbo is worn out) or a bad head gasket (coolant vapor). Head gasket failures are EXTREMELY uncommon on our platform unless you're heavily modified. So, my money would be on the turbo. Restrictor bolts may subdue the smoke, but that's not fixing the problem. In fact, it's making it worse because all that does is reduce the lubrication of the journal bearing in the turbo further. The correct fix is to take off the turbo inlet pipe and inspect the turbo for shaft play and oil in the compressor housing. If it knocks side to side and has all sorts of oil in the housing, it's time to replace the turbo before it grenades and makes it time to replace the entire engine.
FYI: For future reference, this is definitely not the correct thread to address your issue. Start a new thread next time in the troubleshooting section.
The MS6 Intercooler Thread RhoadBlock MazdaSpeed 3/6 - Turbo Induction 36 03-19-2019 03:44 PM
LTA Intercooler Concept Thread J-Liss Mazdaspeed3/6 General Discussion 164 02-24-2014 10:48 AM
Preliminary Tune Completed SweetJP MazdaSpeed 3/6 - ECU Computer Tuning 4 10-17-2011 06:01 PM
Exhaust Completed Airman3454 Gen2 MS3 General Discussion 0 06-19-2011 01:19 PM
Guess my whp - Dyno Completed aaronc7 Miata - Forced Induction 98 06-08-2011 02:00 PM
Page generated in 0.24380 seconds with 21 queries
