 Old 09-27-2018, 06:54 AM   #1
jtimms6's Avatar
Posts: 22   (View Stats)
jtimms6 is on a distinguished road
Default CEL p2009 and low boost
I’ve been getting a CEL for code p2009 which is the IMRC and it says the part could be bad or have a bad connection or a bad vacuum line on the part. Has anyone else had this problem or know where and what to look at first? Also I’ve been having low boost getting around 13-13.5 however on the highway if I drop to 5th to pass someone and sometimes even coming out an exit in 4th the car will peak at about 14-14.38 psi. I don’t think I have a boost leak because I can build boost haven’t had the chance to do a boost leak test but I also don’t understand why I’m higher gears I can build more boost? Is the car under more of a load in a higher gear? And does anyone know or think the two issues could be related to each other? Thanks guys let me know what you think.
DC sports cai
Test pipe w stock catback
Stage 1+ 93 octane tune
Cobb AP
jtimms6 is offline   Reply With Quote
 Old 09-27-2018, 07:45 AM   #2
Jeff23spl's Avatar
Posts: 2,233   (View Stats)
You IM is separated in 2 set of runner and it move on and off with a vaccuum actuator. It could be a bad solenoid, a vac live, a tear in the actuator diaphragm or just rust/dirt in the moving parts...
You car get more load in higher gears and get more time to build boost than in lower gears...
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
P2009 Code IzzysAuto 2010 MS3 - Troubleshoot/Diagnostics 5 11-13-2016 05:05 PM
CEL P2009 no idea what it is Highestrich4 MazdaSpeed 6 - Engine, Transmission & Driveline 7 06-12-2016 09:46 PM
P2004 P2009 codes angiehbrown MazdaSpeed 3/6 - Troubleshoot/Diagnostics 4 01-31-2016 08:27 PM
DTC P2004, P2009 f-castrillo 2010 MS3 - Troubleshoot/Diagnostics 24 07-14-2015 07:27 PM
P2004 P2009 codes Sphinx1983 Mazdaspeed3/6 General Discussion 1 05-20-2015 08:44 AM
Page generated in 0.23028 seconds with 21 queries
