![]() | | #41 | ![]() |
![]() Join Date: Mar 2008 Location: Lawrenceville GA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2
| Not Ranked : 0 score
__________________ [SIGPIC][/SIGPIC]www.myspace.com/rican219 MODS: TWM Short Shifter Stage 2, CPE downpipe Highflow Cat, Corksport 3 inch Catback, SU motor Mount, HKS BOV VTA, Spin on Oil filter conversion, Greddy Turbo timer, H&R Springs, Sport Max wheels, Corksport Strut Tower Brace, Corksport FMIC,Turbine Tech Front Engine Mount, Turbine Tech Rear Diff Bracket and Bushings, PROcede EMS, 2871r, Dash Hawk |
![]() | | #42 | ![]() |
| Banned ![]() Join Date: Mar 2008 Location: LaLa Land
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,321
Groaned at 196 Times in 127 Posts
(Thread Starter) | Not Ranked : 0 score Ive called corksport and got nothing but welll umm yea umm other cars arnt throwing the code. I told them that i am not the only one with this problem and i even suggest that the reason this code is being thrown and the car is running like shit is becuase the maf housing is too big. The only asnwer i got is that they have a speed 3 with the same problem that his been to their shop multiple times. They are aware of it but frankly arnt doing much about it. All they gotta do is create a smaller maf housing pipe. Instead of 2.8 in diamter make it 2.6 PROBLEM SOLVED CORKSPORT! On to my private ghetto testing. I siliconed a coupler into the maf housing to reduce the size to rougly 2.5x. Car runs WONDERFUL, cel went away, dead spots went away every single problem went away. However there is a 'downfall' to this. My car use to hold 17psi and not the boost is holding like stock...hold 15.x drops downt oe 14.x. I dont mind this one bit because Im on the stock boost control system. Ill just wait till for cobb and call it a day! |
![]() | | #43 | ![]() |
| Can you have a new MAF housing made from pipe instead of a coupler now that you know it works? Probably get a batch made and sell them off.
![]() | | #44 | ![]() |
![]() | | #45 | ![]() |
| Go right to a machine shop, they will be able to pull that off for you in a heartbeat.
![]() | | #46 | ![]() |
(Thread Starter) | Not Ranked : 0 score i gotta talk to some poeple around me...ill see what i can do about this. I mean it dont see it costing more than 100 bucks. Cut the maf housing out, weld a new smaller one in. |
![]() | | #47 | ![]() |
| Yea, its not a big job at all to cut it and weld it. What i was implying is you could also have these manf'd yourself and sell them off as well. Im sure people would buy them to do their own IC's and SRIs.
![]() | | #48 | ![]() |
(Thread Starter) | Not Ranked : 0 score This would be a corksport specefic piece. The way the cs kit is set up is that the maf housing attaches tot he airbox which is where the tmic use to sit. It wouldnt work with anythign else besides the CS kit |
![]() | | #49 | ![]() |
Groans: 370
| Not Ranked : 0 score Did you email CS and ask/let them know about their MAF housing being too big? |
![]() | | #50 | ![]() |
| Banned ![]() Join Date: Mar 2008 Location: On this planet (Washington)
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 436
| Not Ranked : 0 score Laloosh hit me up, I will post some pictures of our kit when I get it on the car. |
![]() | | #51 | ![]() |
![]() Join Date: Mar 2008 Location: West Palm Beach, Fl
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5
| Not Ranked : 0 score I'd be interested in what you come up with too!
__________________ Ribs. I had ribs for lunch. That's why I'm doing this. sleeper3 - 2.234, 8.742 @ 84.18, 13.365 @ 106.75 (I/IN/IC/MM) |
![]() | | #52 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 31
| Not Ranked : 0 score looks like i'm staying with my top mount which will be here next week.
__________________ Black Mica '07 Mazdaspeed3 Mods:CP-E FMIC - ProtegeGarage Tubular Exhaust Manifold - TurboXS Hybrid BOV, Downpipe, and Custom Catted Racepipe - mrlilguyCDFP - ATP 3" Turbo Inlet - ATP Boost Cut Killer Module - CP-E Rear MM - WelderWerkz Short Shifter - AEM UEGO Wideband - ProSport Blue Boost/EGT/Oil Pressure Gauges - GReddy Full Auto Turbo Timer - PimpWheels Black/Red Edition - Falken Azenis RT-615 - Yakima Roof Rack w/ Fairing Reppin' ProtegeGarage for life! |
| The Following User Says Thank You to mrlilguy157 For This Useful Post: | occschemguy (03-12-2008) |
![]() | | #53 | ![]() |
(Thread Starter) | Not Ranked : 0 score After fixing the maf housing in a ghetto way im really happy with this kit. Boost temps are WAY down compared to the ets top mount. Ets top mount going from 1-5th i would see 200 degree post intercooler temps. Right now im seeing low 160s once i hit 5th. Then again the top mount was tested at 18 psi and right now im only seeing 15. Another cool thing about this set up is the air intake temps, im only about 4-5 degree above amb once i get rolling |
| The Following User Says Thank You to Laloosh For This Useful Post: | occschemguy (03-13-2008) |
![]() | | #54 | ![]() |
![]() Join Date: Mar 2008 Location: Orange County Ca.
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,353
| Not Ranked : 0 score im with you on this i think! |
![]() | | #55 | ![]() |
![]() ![]() Join Date: Mar 2008 Location: Boise, Idaho
Rep Power: 1905 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 229
__________________ 2008 Mazdaspeed3, Fully built then fully parted. Sold 2007 ccsb Silverado, 3/5 drop Procharged, longtubes, 10psi Daily Mazdaspeed 12.5 @109 k04 stock ecu 18psi pump gas stock motor 311whp 11.7 @120 atp gtx3071r ap tuned 22psi 30/70 e85/pump stock motor. 422whp |
![]() | | #56 | ![]() |
did u see any psi loss when u mouned it? | |
![]() | | #57 | ![]() |
| Not Ranked : 0 score I'd say about 3 lbs? I mean 18-15 is three...
![]() | | #58 | ![]() |
| Not Ranked : 0 score hey laloosh, can you send me some info on exactly what you did with the MAF housing? I just picked one up today.. killer deal and am going to get the whole MAF housing thing over and done with before the car is even back to me. thanks
__________________ On motor #3 Turbo #2 Now have a SSM 08 STi!! |
![]() | | #59 | ![]() |
![]() Join Date: Mar 2008 Location: Kirkland, WA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 342
Groans: 87
| Not Ranked : 0 score Killer deal for sure!!!! |
![]() | | #60 | ![]() |
(Thread Starter) | Not Ranked : 0 score The kit on your car first, see if you have any problems. If your car runs like shit and throws a cel post it in here and ill tell you what i did. |
![]() | | #61 | ![]() |
![]() Join Date: Mar 2008 Location: Pittsburgh, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17,174
Groans: 45
| Not Ranked : 0 score well i just finished installing my kit for my ms6, wasn't the greatest fitment but i got it all together. when i started it up the first couple times it died while trying to idle. after about the third time the rpms bounced around a bit then it levels out. did you have any problems like this? i am running recirc so i'm not sure whats wrong. it seems like anytime i start it up it will bounce around and then level. i have no CEL's. i did have to use a 2.5" coupler in between the pipe off the turbo and the one that goes down in the fender cause corksport doesn't mention in the instructions that you need a new coupler for the turbo inlet to the turbo. so i called them up and they told me to just use one of the 2.25" from a tube that was easily accesible cause they sent me a new one for that spot. so i'm not sure if the 2.5" coupler there is causing sort of a bottle neck giving problems to idle. but i needed a coupler to put there for now. so once it idled i took her out for a spin. got into some boost but once i hit about 12psi i got this weird squealing noise, i might also contribute this to that coupler or i might have a look at the pipe going into the throttle body and make sure that clamp is on right because the way the pipe goes from 2.25" to 2.75" its tough to get the clamp on right. |
![]() | | #62 | ![]() |
(Thread Starter) | Not Ranked : 0 score my car died the first couple of times trying to start it as well. Let me know if you throw a cel |
![]() | | #63 | ![]() |
Groans: 45
| Not Ranked : 0 score did it idle rough once it did start? |
![]() | | #64 | ![]() |
(Thread Starter) | Not Ranked : 0 score absolutly, it sounded liek it was misfiring. |
![]() | | #65 | ![]() |
Groans: 45
| Not Ranked : 0 score well i got 2 CEL's P2177 and P2187 |
![]() | | #66 | ![]() |
(Thread Starter) | Not Ranked : 0 score good ole 3 inch maf housing. I still dont know how corksport advertises this kit. |
![]() | | #67 | ![]() |
Groans: 45
| Not Ranked : 0 score here i did a log of my idle too. i think i have a leak somewhere. why both codes? |
![]() | | #68 | ![]() |
(Thread Starter) | Not Ranked : 0 score trust me you dont have a leak anywhere. |
![]() | | #69 | ![]() |
Groans: 45
| Not Ranked : 0 score do you think it could be the bigger coupler size i have in temporarily as well? wonder why the other guys with this kit aren't experiencing issues. |
![]() | | #70 | ![]() |
(Thread Starter) | Not Ranked : 0 score it has nothing to do with a bigger coupler. Half hte cars that have this kit throw cels and run like complete ass |
![]() | | #71 | ![]() |
Groans: 45
| Not Ranked : 0 score i also get a studder while driving i can feel. |
![]() | | #72 | ![]() |
Groans: 45
| Not Ranked : 0 score did you see how my log all the values are bouncing around. |
![]() | | #73 | ![]() |
(Thread Starter) | Not Ranked : 0 score let me guess the stutter is right before your are about to build boost aka btwn -5 and 0 |
![]() | | #74 | ![]() |
Groans: 45
| Not Ranked : 0 score yup. i went and did notice i had a few loose clamps so i tightened them all up. had to replace one of the 3" ones cause it just didn't fit right. and then i also noticed the hose for the PCV vent was kinked so that might be the P2187 code. |
![]() | | #75 | ![]() |
(Thread Starter) | Not Ranked : 0 score your wasting your time, its the maf housing |
![]() | | #76 | ![]() |
Groans: 45
| Not Ranked : 0 score ok, i'll call them up monday and see what they say and i'll make sure i tell them others have that problem too. |
![]() | | #77 | ![]() |
![]() | | #78 | ![]() |
Groans: 45
| Not Ranked : 0 score any reasoning to the wierd squeal noise i got at around 12psi of boost? |
![]() | | #79 | ![]() |
(Thread Starter) | Not Ranked : 0 score no clue...maybe a pipe is rubbing |
![]() | | #80 | ![]() |
Groans: 370
| Not Ranked : 0 score laloosh: what did corksport say about the incorrect MAF housing when you called? It sucks they can't get something as simple as that right. |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f11/corksport-front-mount-intercooler-74/ | ||||
| Mazda Speed Forums: Mazdaspeed High Performance Forum with Gallery, Specs, discussion & more | This thread | Refback | 03-25-2008 04:47 PM | |
| Corksport Ram Air Box | bova | MazdaSpeed 3/6 - Turbo Induction | 3 | 04-08-2010 06:42 PM |
| Corksport FMIC Kit | bova | MazdaSpeed 3/6 - Turbo Induction | 22 | 06-12-2008 08:44 PM |
| Going all corksport exhaust it looks like... | Haltech | MazdaSpeed 3 - Engine, Transmission & Driveline | 20 | 03-26-2008 11:22 PM |
| CorkSport DP + Vibrant | SLS MS3 | MazdaSpeed 3 - Engine, Transmission & Driveline | 9 | 03-24-2008 10:57 AM |
