  • 1 Post By MSMS3
 Old 07-09-2015, 04:25 PM   #1
boostedspeed6's Avatar
Posts: 4   (View Stats)
boostedspeed6 is an unknown quantity at this point
Default downpipe question
my 07 speed 6 has a catless downpipe no front cat just rear cat . and still no engine light but seems to be running rich as i changed the oil and its smelled like fuel . could my car have been tuned by previous owner i have no records of the history
boostedspeed6 is offline   Reply With Quote
 Old 07-09-2015, 04:40 PM   #2
Wildcat's Avatar
Posts: 113   (View Stats)
Wildcat has a reputation beyond reputeWildcat has a reputation beyond reputeWildcat has a reputation beyond reputeWildcat has a reputation beyond reputeWildcat has a reputation beyond reputeWildcat has a reputation beyond reputeWildcat has a reputation beyond reputeWildcat has a reputation beyond reputeWildcat has a reputation beyond reputeWildcat has a reputation beyond reputeWildcat has a reputation beyond repute
Oil smelled like fuel? Not good man. The only solution is to run w/o any oil and let the gasoline lube the engine on it's own--slippery stuff.
'16 Mustang GT // MBRP Street catback // 35 lb. Steeda clutch assist spring // Diode Dynamics LEDs // Ford Racing knob // Sound tube delete // Matte black dipped wheels & emblems // Tinted tail, head, marker lights //
'13 CWP MS3 // Cobb Accessport V3 // Autotech HPFP Internals // CS SRI & TIP // CP-E Stage 2 RMM // Amazon (Manzo) Racepipe // CP-E TMIC // Forge V2 BPV // Cobb Knob (+3 hp) // Stratified Flash Tune w/ boost-based logic // SOLD
Wildcat is offline   Reply With Quote
 Old 07-09-2015, 05:56 PM   #3
You should really read up on common disi issues
Wildcat (07-09-2015)
 Old 07-11-2015, 03:48 PM   #4
MSMS3's Avatar
Posts: 2,826   (View Stats)
Oh, man, where to begin? More info, please. How long have you had this car? What other mods does it have? Please tell me you have NOT been running a catless dp without upgraded fuel pump internals and a proper tune.
Houston, we have a problem.
Atticaz likes this.
 Old 07-15-2015, 10:16 AM   #5
qkrthnu2's Avatar
Posts: 131   (View Stats)
qkrthnu2 has a reputation beyond reputeqkrthnu2 has a reputation beyond reputeqkrthnu2 has a reputation beyond reputeqkrthnu2 has a reputation beyond reputeqkrthnu2 has a reputation beyond reputeqkrthnu2 has a reputation beyond reputeqkrthnu2 has a reputation beyond reputeqkrthnu2 has a reputation beyond reputeqkrthnu2 has a reputation beyond reputeqkrthnu2 has a reputation beyond reputeqkrthnu2 has a reputation beyond repute
FYI - This kind of post (Questions from an obviously uninformed Mazdaspeed owner) tends to attract a lot of bashing. I'll try to offer you some help, but you will really do yourself a favor if you spend several hours reading through the sticky threads at the top of various sub-forums here and searching for topics if you still have more questions.
  • Downpipe
    The previous owner didn't do you any favors by installing this. Assuming that the requisite supporting modifications have not been installed and tuning has not been performed, there's a good chance that this has caused engine damage.
  • Fuel in Oil
    This is a bad symptom. It could be a sign of various problems (piston ring damage, injector seal leak, PCV system malfunction, HPFP malfunction, etc), or it could simply be that the oil change interval was too long, Direct Injection engines tend to end up with more fuel making its way into the oil compared to Port Injection engines.
    Before worrying about this, I would do a relatively short oil change interval, 1000-1500 miles, and then see how the oil looks/smells or better yet pay the $25 for an oil analysis so you know for sure how much fuel is present ( Blackstone Labs )
  • Suggestions
    Buy an oil analysis - $25
    Buy a Cobb Accessport - $200(used) - $$650(new) - Don't load any maps.
    Buy an e-tuning service from one of the many reputable tuners here on MSF - ~$150-$300
    The tuner can likely determine based on log data and the oil analysis if there are any mechanical issues which need to be addressed.
_______________________________________________
Driver Mods - Mid Ohio Three Day Racing School
2006 Mazdaspeed 6 GT - 130k+ miles. Daily driver (Actually my Wife's car)
Shooting for a reliable 350 AWHP.
Surefire Remanufactured Engine Installed @ 135k.
Mods: BNR S3 Turbo \ Grimmspeed EBCS \ Guardian Angel \ Cobb AccessPort \ Bosch 3 Bar MAP sensor \ AWR RMM \ TurbineTech FMM \ Corksport HPFP \ cp-e Injector seals \ Autolite XP5263 plugs \ Ebay Circuit Werks DP \ Stock CBE \ HTP 3" Intake w/ DIY CAI \ cp-e TMIC \ DIY boost tubes \ Primary & Secondary EGR delete \ Bilstein Shocks \ 215/45ZR -18 Continental ExtremeContact DWS
PERM dual PVC plate and two Damond Motorsports catch cans. Full vacuum setup w/ VTA for over pressure.
PERM #1 -> DM OCC V1 -> DM PCV valve -> Check Valve -> Intake Manifold.
PERM #2 -> DM OCC V2 w/ VTA -> Check Valve -> Tee -> Valve Cover & TIP.
The others:
2009 BMW 135i - N54 - JB4 w/ backend flash \ SRI.
1998 VW GTI VR6 - 248k miles (stock clutch!) when wrecked (not my fault)
1995 Jeep XJ - 4.0 - AW4 \ Lift/Tires etc. 230k miles. Rust bucket / winter beater.
1995 Honda del sol VTEC - DIY hodge podge turbo setup \ self tuned w/ Neptune. 2550lbs ~270whp \ 150k+ miles on stock bottom end (4th clutch though) \ knock limited on 93 octane.
qkrthnu2 is offline   Reply With Quote
Downpipe Question JFord Gen2 MS3 General Discussion 4 04-20-2013 07:50 AM
Downpipe Question sidekick CorkSport 19 02-19-2013 04:51 PM
Downpipe question Stangcobra MazdaSpeed 3 - Engine, Transmission & Driveline 4 07-29-2012 05:58 PM
MS6 Downpipe question r0cknry MazdaSpeed 3/6 - Turbo Induction 11 04-20-2011 08:10 AM
Page generated in 0.27346 seconds with 24 queries
