![]() Join Date: Nov 2015 Location: Clarksville, TN
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 102
(Thread Starter) | Not Ranked : 0 score So due to my horrible luck and my car, I managed to pick up a 5k mile turbo from a Nator guy that got it from a Nator guy. In prepping said turbo for the arrival of my engine, I notice this ![]() The oil feed is significantly smaller than my stock K04 and I can see the shift through the journal bearing like I can in my stocker. Should I be concerned? Sent from my SAMSUNG-SM-G890A using Tapatalk
__________________ 2006 Mazdaspeed6 GT #3352 137k mi. Nav deleted for Galaxy Tab 2 mod because it was shithouse and an Auzmod to keep my sat and such (like a bawss) GenPu engine: Poor Man's EBCS ($20, can't beat it) HTP 3.5 CP-E Fuel injector seals Custom TR8 FMIC, Mazo catless DP in to 3 IN Corksport exhaust, TMM inserts Relentless P&P Intake Manifold Damond EGR delete, OCC, PCV Plate Autotech HPFP JBR RMM,weight and Shift knob Ralco Short Throw shifter ACT Stage 3 Clutch H&R Springs EVO VIII Wheels SP63 PTO caps Purple Drank e30 tuned Soon to come: Gen 2 gear swap, rear diff mounts, PMM, Holset HX35 and focus log mani with EWG |
(Thread Starter) | Not Ranked : 0 score stock turboSent from my SAMSUNG-SM-G890A using Tapatalk
![]() Join Date: Oct 2011 Location: San Leandro, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 460
Groans: 87
| Not Ranked : 0 score Updated turbo less likely to smoke?
__________________ 2018 Audi RS3 2013 CWP Mazdaspeed3 - CS Turbo 2007 Acura TSX 6MT |
| The Following User Says Thank You to tegxsi For This Useful Post: | Elrodd (03-11-2016) |
(Thread Starter) | Not Ranked : 0 score That's actually what I was thinking too, so maybe I shouldn't use my restrictor bolt then? Sent from my SAMSUNG-SM-G890A using Tapatalk
Groans: 87
| Not Ranked : 0 score If the turbo is from a gen2 then you probably don't need a restrictor bolt... I doubt it would hurt.
| The Following User Says Thank You to tegxsi For This Useful Post: | Elrodd (03-14-2016) |
| My Ebay DP | IshiKage | MazdaSpeed 3/6 - Turbo Induction | 787 | 08-31-2014 10:03 AM |
| eBay DP | zpele | Mazdaspeed3/6 General Discussion | 68 | 04-10-2012 02:14 PM |
| New ebay lip?? | jrotaryb | Exterior | 6 | 11-09-2011 09:35 AM |
| ebay fmi for MS6 | trigun22 | MazdaSpeed 3/6 - Turbo Induction | 60 | 03-29-2011 09:00 AM |
