 Old 05-03-2018, 09:04 PM   #1
KamloopsDan's Avatar
Posts: 64   (View Stats)
KamloopsDan is a name known to allKamloopsDan is a name known to allKamloopsDan is a name known to allKamloopsDan is a name known to allKamloopsDan is a name known to allKamloopsDan is a name known to all
Default EBCS Noise
Hey,
I was wondering if anyone else has noticed that their electronic boost controller noise is more prominent when the engine is cold? I have a MSP6 for what it's worth.
I have recently had an S4 & 3.5" intake installed and still getting used to all the noises that this setup brings. One thing I am still struggling with is the GrimmsSpeed EBCS noise that is mounted on the firewall.
When the car is cold I cannot hear a peep (denser air maybe) but as soon as the engine gets up to temperature I can hear the fluttering sound. Is this normal?
Thanks
KamloopsDan is offline   Reply With Quote
 Old 05-04-2018, 06:28 AM   #2
GroceryGtr's Avatar
Posts: 472   (View Stats)
Its perfectly normal for you to hear clicking sounds from the EBC. Remember it is an on/off actuated unit so the the clicking is telling you its cycling. Mounting location plays a big role in how much you hear it, but to be honest you'll get used to it fairly quickly. I have mine on the firewall as well and barely notice it anymore.
Do you mean a fluttering sound from your bov?
 Old 05-08-2018, 10:14 AM   #3
No I mean the flutter of air being controlled by the EBCS. I have managed to quieten it by adding some rubber washers and a piece of foam. It's all good, I am used to it now. I only really hear it in 1st & 2nd gear. Once I get up to the high rpms the other noises take over!
1st world problems eh?
 Old 05-08-2018, 12:31 PM   #4
Police - Grammarhead
Vansquish's Avatar
I mounted my EBCS to the bracket that holds the TIP to the engine. There's plenty of rubber between there and the passenger compartment.
Throttle noise/ engine noise under28world 2010 MS3 - Engine, Transmission & Driveline 9 05-04-2015 06:25 PM
Whining noise post GS Ebcs install Mfinlay04 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 7 10-02-2012 04:25 PM
bearing noise vs wheel noise? drag0nfire Mazdaspeed3/6 General Discussion 14 06-20-2012 07:32 PM
Lotus and Harman partner on noise-cancelling, noise-creating tech Haltech Automotive News 0 04-16-2009 05:00 PM
Page generated in 0.24996 seconds with 22 queries
