 Old 11-11-2013, 09:16 AM   #1
projectr13b's Avatar
Posts: 33   (View Stats)
projectr13b is a jewel in the roughprojectr13b is a jewel in the roughprojectr13b is a jewel in the rough
Default FMIC Kit questions
Been searching, reading and watching things this morning and still have a few questions. I have an 09 speed3, currently stock.
So, I've been looking at kits and am considering the CX Racing kit. Seems solid from what I read and won't kill my wallet. Just have a couple of questions about the kit and front mounts in general.
So, without a HPFP I'm not expecting massive gains with this being my first mod, but I do get stuck in traffic pretty often and I've heard a FMIC will really help with heat soak problems, just curious if others can confirm.
I'm curious if the core is going to effect my radiator's cooling ability, or is it negligible?
Also, how big of a core will fit in the stock bumper without a lot of modification?
And finally, the kit comes with a recirculating BOV. I've read that recirculating is the way to go with this car. Should I use the new BOV, or try to keep the stock bypass?
Also, will a recirculating BOV cause that psshhhhhh noise while driving? I'm trying to keep my car looking pretty stock and sleeperish. I would prefer not to draw attention to myself because of a BOV.
I'm still pretty new to turbo cars. Thanks for any advice you guys can throw my way on the FM kit.
projectr13b is offline   Reply With Quote
 Old 11-11-2013, 09:27 AM   #2
smoogs12's Avatar
Posts: 7,731   (View Stats)
Groans: 423
Horrible first mod. Keep reading.
To answer a couple of your questions however...
Keep your stock bypass. Stick with an IC that is the size of a tr8 or smaller.
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
The Following 6 Users Say Thank You to smoogs12 For This Useful Post:
El_Diablo (11-11-2013), Kdawg207 (11-11-2013), Mochi (11-11-2013), OverBoosted (11-11-2013), Raider (11-11-2013), trancehead (11-12-2013)
 Old 11-11-2013, 09:34 AM   #3
OverBoosted's Avatar
Posts: 1,608   (View Stats)
^This, you won't get much out of the fmic until you have supporting mods. I would suggest a little more research on what the "best" first mods are.
The route I took after much research on this site was sri, tip, and Cobb AP. Up next will be hpfp internals and then maybe a fmic. Oh and don't forget about the rear motor mount. it should definitely be one of the first few.
projectr13b (11-11-2013)
 Old 11-11-2013, 09:41 AM   #4
ABolewski's Avatar
Posts: 1,279   (View Stats)
I don't think a cx racing fmic is a bad choice for a first/early mod. VA is no Texas or Nevada, but it can still get pretty hot, and to answer your questions:
Don't use the BOV that comes with the kit, it's shitty and you're stock one will work fine. FMIC will not heat soak at all really, and it will usually raise your coolant temps a negligible amount. The CX racing core is good for your rather-stock car, and will fit without any permanent modification to your car.
Get involved with your local Nator chapter and check out some other peoples cars. But I think a little FMIC kit like the one you're interested is good because heat soak is the devil. Opinions are like assholes, and most of the people on this forum are assholes.
(sold)
The Following 2 Users Say Thank You to ABolewski For This Useful Post:
mxlplx71 (11-11-2013), projectr13b (11-11-2013)
 Old 11-11-2013, 09:56 AM   #5
Thanks guys. I'm still reading up on what to do and when to make some decent power. Looks like they are selling these kits cheap and will be for a while, so not really as time sensitive as I was thinking. Found them on eBay, but they are selling it for roughly the same price through their site.
Original plans were RMM, SRI and AP, then maybe a full exhaust and the front mount. I'll likely keep going that way then.
 Old 11-11-2013, 10:13 AM   #6
smoogs12's Avatar
Groans: 423
Heres a freebie...
AP
Internals
Intake
RMM
DP
E85 or Meth
Tune
Thats all you need for >300hp
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
The Following 2 Users Say Thank You to smoogs12 For This Useful Post:
Kdawg207 (11-11-2013), projectr13b (11-11-2013)
 Old 11-11-2013, 10:18 AM   #7
jk_ms3's Avatar
Posts: 1,390   (View Stats)
Groans: 40
FMIC shouldn't really be your first mod. There's a LOT of other things that will give you a performance boost before you need it. I know someone who's pushing 330hp on a stock tmic.
I'd suggest going rmm --> AP --> sri/tip --> internals --> dp or rp --> and then consider a fmic, etune, or something.
EDIT: I'm late to this party, it seems. Darn it for starting a reply and then being interrupted at work. But even still, the info is solid. Just keep reading and you'll be all good.
On deck: VG Sharkfin Antenna
The Following User Says Thank You to jk_ms3 For This Useful Post:
 Old 11-11-2013, 10:30 AM   #8
lol It's cool. thanks for the info though.
 Old 11-11-2013, 10:42 AM   #9
Tetsubo's Avatar
Posts: 123   (View Stats)
Tetsubo has a reputation beyond reputeTetsubo has a reputation beyond reputeTetsubo has a reputation beyond reputeTetsubo has a reputation beyond reputeTetsubo has a reputation beyond reputeTetsubo has a reputation beyond reputeTetsubo has a reputation beyond reputeTetsubo has a reputation beyond reputeTetsubo has a reputation beyond reputeTetsubo has a reputation beyond reputeTetsubo has a reputation beyond repute
I personally went with this kit for my Gen2 minus the core. I was able to get just the piping kit and bpv for $320 and picked up the Treadstone TR8 core from edge super cheap when they had the Halloween sale. I would definitely recommend going with a Treadstone if you have any plans on BT or any decent power. I live in Houston and am always in traffic on the way to work and this helps.
1993 S/C Miata
(TOTALED)2013 Mazdaspeed3 w/ Tech Package
93 Octane w/ a splash of E
436 WHP/ 406 Torque
Engine:
ATP GTX3076r, 3' Long Catless Downpipe (wrapped) || Cobb Accessport V3 (Freek tuned), 3 port boost controller || HTP 3.5 intake system || Bosch 3 bar map sensor, Bitwise Motorsports Bosch MAP Sensor Connector || CX Racing piping || Treadstone tr8 intercooler core || Synapse DV BPV || Cp-e Turbo manifold(Ceramic coated and wrapped), Tranny and Passenger mount || Kozmic Dump pipe (Ceramic coated and wrapped), EGR block off plates, OCC || Tial MVR 44mm Waste gate || Corksport 70 duro RMM, CBE || Autotech Internals || Ported & Polished Intake Manifold || Rotella T6
Suspension:
TB Performance Traction Bar V2
Looks:
Corksport Hood strut kit || Rally Armor Mudd Flaps || SU Blacked out Badges || Plasti dipped Fog Bezels || Nextmod Front Lip
Tetsubo is offline   Reply With Quote
 Old 11-11-2013, 02:37 PM   #10
Good to hear. Thanks for the advice man
The Following User Says Thank You to projectr13b For This Useful Post:
Koke382 (11-11-2013)
 Old 11-11-2013, 07:07 PM   #11
skiptowncat's Avatar
Posts: 1,592   (View Stats)
Are you saying the cx would be no good for a 3071? I've been offered one super cheap but don't know wether to buy it or stick with my su tmic, I'll be spraying meth as well of that makes a difference.
Tuned with by
 Old 11-12-2013, 04:39 AM   #12
Tetsubo's Avatar
The core on the CX is set up a bit different(fins and what not) than any real quality. This is what I have read and I had the monies to get a Treadstone along with the piping kit. Meth is definitely going to keep you cooler so you may be able to get away with it. If you have a AP watch your BATs on Pulls and idles. Heatsoak was a bitch for me due to stop and go traffic.
Another note too, look on ebay for some thermal wrap. I picked up a roll of Titanium for about 30 bucks shipped.
1993 S/C Miata
436 WHP/ 406 Torque
Engine:
Suspension:
Looks:
The Following User Says Thank You to Tetsubo For This Useful Post:
skiptowncat (11-12-2013)
 Old 11-12-2013, 05:34 AM   #13
anavrinIV's Avatar
Posts: 4,490   (View Stats)
Groans: 63
Buy a treadstone, make your own piping. Save money and win harder.
Blue Pu.
The Following 2 Users Say Thank You to anavrinIV For This Useful Post:
projectr13b (11-13-2013), skiptowncat (11-12-2013)
 Old 11-12-2013, 12:49 PM   #14
I think I'll run the cx for a bit but order a trl8 when it comes to spring next year.
Tuned with by
The Following User Says Thank You to skiptowncat For This Useful Post:
 Old 11-13-2013, 06:39 AM   #15
jreams's Avatar
Posts: 37   (View Stats)
jreams is a splendid one to beholdjreams is a splendid one to beholdjreams is a splendid one to beholdjreams is a splendid one to beholdjreams is a splendid one to beholdjreams is a splendid one to beholdjreams is a splendid one to behold
my route was
intake + AP (COBB stage 1 OTS)
internals + etune
downpipe/racepipe
TIP
fmic
and idk if it was placebo but the FMIC made a huge, noticebale difference for my car. kept my car over 75 degrees cooler during a 2-3 pull.
TurboXS: Downpipe, Racepipe, Catback, FMIC
C-PE: RMM, TIP, Nano Intake
AutoTech Internals, Custom Tuned
jreams is offline   Reply With Quote
The Following User Says Thank You to jreams For This Useful Post:
 Old 11-13-2013, 07:13 AM   #16
Originally Posted by jreams View Post
my route was
internals + etune
downpipe/racepipe
TIP
fmic
This is starting to looks more like my route.
Stupid question, but where does the TIP connect to other than the turbo?
 Old 11-13-2013, 07:45 AM   #17
magicka's Avatar
Posts: 520   (View Stats)
The TIP connects the turbo to the flex section/tube coming off the back of the MAF sensor housing. With a SRI, it's Inlet ->short, straight silicone -> MAF sensor housing -> silicone bend -> TIP
2009 CWP MS3 GT
The Following User Says Thank You to magicka For This Useful Post:
 Old 11-13-2013, 07:50 AM   #18
Ok cool. That's what I was thinking. Thanks
 Old 11-13-2013, 08:01 AM   #19
jreams's Avatar
Yeah I have a modified CPE Nano intake for my TurboXS front mount. Need a more permanent solution though.
FMIC questions Fabsx MazdaSpeed 3/6 - Turbo Induction 20 05-09-2012 01:59 PM
FMIC Questions kpsoerensen MazdaSpeed 3/6 - Turbo Induction 31 02-14-2011 11:32 AM
cpe fmic questions JmkC MazdaSpeed 3/6 - Turbo Induction 13 08-13-2009 05:40 PM
CPE FMIC Install Questions bykeryder4life MazdaSpeed 3/6 - Turbo Induction 9 02-07-2009 01:16 AM
FMIC questions Frankie3mps MazdaSpeed 3/6 - Turbo Induction 11 07-21-2008 08:44 AM
Page generated in 0.39428 seconds with 29 queries
