![]() Join Date: Jul 2018 Location: Asheville, NC
![]() Join Date: Jun 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,505
| Not Ranked : 0 score Can you post a data log replicating the condition?
(Thread Starter) | Not Ranked : 0 score Okay, i took these last night when it was happening. Thanks |
![]() Join Date: Oct 2011 Location: San Leandro, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 460
Groans: 87
| Not Ranked : 0 score I don't see anything out of the ordinary... What is your setup? Did you ask Stratified about it?
__________________ 2018 Audi RS3 2013 CWP Mazdaspeed3 - CS Turbo 2007 Acura TSX 6MT |
(Thread Starter) | Not Ranked : 0 score I haven't yet but they will probably take a week or so to reply and if something is wrong I want to fix it as soon as i can. The weather also recently got colder, could that have anything to do with it? |
![]() Join Date: Oct 2015 Location: Central Jerz
| Not Ranked : 0 score I also have a hybrid BPV and one time I got flutter when i forgot to reconnect the recirculation hose to the top of the BOV. Could be something as simple as that, did you check your connections?
__________________ 2010 MS3 - Tuned By Nishan Autotech Fuel Pump Internals OBX R Custom Exhaust Cobb SF Intake & TIH w. Blitz Filter CP-e TMIC Corksport Dual VTA BPV JBR 88 Duro RMM |
| Not Ranked : 0 score When is the last time your BPV was serviced? I'm wondering if the valve is opening and bleeding off boost. Maybe weak or broken spring? Damaged seal?
| Not Ranked : 0 score Definitely check that, 90% sure its a bpv related problem
| Not Ranked : 0 score can your noise be the one of a leak instead ? if it doesn't work by fixing the bpv, i would do a piping pressure test... Surging happen at spool if the intake restriction is too high or if discharge to the engine offer too much restriction or both added together. It can also happen if the BPV don't open when you let off gaz. In any case, the wheel shaft is moving side to side trying to let the pressure escape and this make a lot of load on the thrust bearing and everything untill the wheel touch the case at high speed and something break. I'm not sure if fluter can be part of the surge or if it is just when the BOV is pulsating open/close between too much pressure and not enough against the spring....The last case would be almost just a sound. All that to say none of them should happen at wot at 5000rpm so i think it is something else like a leak.
Groans: 87
| Not Ranked : 0 score Too much pops and bangs will kill cats. You still haven't listed any of your mods...all we know is that you have a TurboXS hybrid valve.
If my cats did get killed would it cause this? UPDATE: Switched to stock BPV, no change Last edited by Dennisaliy; 11-08-2018 at 04:58 PM. Reason: MSF Database - Automerged Doublepost | |
(Thread Starter) | Not Ranked : 0 score Got this video, not as loud on camera but still audible |
| Not Ranked : 0 score really looks like a leak
(Thread Starter) | Not Ranked : 0 score Just did Boost leak test and put on stock inlet pipe on. No difference. My other question, if my cats blew out could it cause something like this? Thanks All |
(Thread Starter) | Not Ranked : 0 score UPDATE: Got 2 CEL codes, p0421 and c1938, fuel trims now also jump up to 16.4% |
![]() | | #19 | ![]() |
P0421 is the low cat temp code we see when running catless without a raised bung on a catless downpipe. It means your primary cat has probably failed.
![]() | | #20 | ![]() |
(Thread Starter) | Not Ranked : 0 score Okay thanks, so this is a dumb question but that's the second cat right? |
![]() | | #21 | ![]() |
Something is wrong with the first cat or sensor. You could just have a dirty or bad sensor.
![]() | | #22 | ![]() |
(Thread Starter) | Not Ranked : 0 score Okay, I'll check the sensor first, thanks! |
| The Following User Says Thank You to Dennisaliy For This Useful Post: | MSMS3 (11-19-2018) |
![]() | | #23 | ![]() |
| Not Ranked : 0 score Could be the sensor for the code but it won't help for the noise you heard while a leaking cat would be heard at all time... How did you process for the boost leak test ? Did you replace the intake by a tube connected to an air pressure source and check for leaks under 15-20psi ?
![]() | | #24 | ![]() |
![]() | | #25 | ![]() |
(Thread Starter) | Not Ranked : 0 score Hey guys so i was at a stoplight and decided to give it a little WOT because its been a while and it started going then started fluttering THEN lost power. i noticed AFR's went really low. I've been really busy in school so i haven't been able to check the O2 sensor or downpipe yet. i got it captured on a log. Please let me know what you guys think. Do i need to bite the bullet and take off the downpipe or could it be something else? maybe a EGR valve stuck open? Intercooler with a leak? the boost leak tests ive been doing have been inconclusive. i pressure it up at the turbo at 20 psi and hear no leaks and the pressure slowly lets out. quickly at first then much slower, maybe from 20 to 10 psi in 30 sec then a minute to about 2-3 psi where it stays. is this normal? if not how can i find the leak if it makes no noise (couldn't feel it either) thank you to everyone who has helped this far. |
![]() | | #26 | ![]() |
(Thread Starter) | Not Ranked : 0 score Could it be my wastegate actuator? |
![]() | | #27 | ![]() |
| Not Ranked : 0 score Add smoke to the inlet before pressurizing.
![]() | | #28 | ![]() |
![]() | | #29 | ![]() |
| Not Ranked : 0 score That might work. The problem with Vape is that it's water vapor, not smoke. By the time it reaches the leak...it will have precipitated or dissolved into the air.
![]() | | #30 | ![]() |
(Thread Starter) | Not Ranked : 0 score Okay, I'll try to get a friend over that smokes. I did find out just now that the wastegate actuator IS faulty so I'll change that in a few days when it comes in then do the smoke test. |
![]() | | #31 | ![]() |
| Not Ranked : 0 score Keep us updated so everyone can know what the fix turns out to be. Maybe the rubber/synthetic diaphragm in the actuator has a leak. That would explain the symptoms. I hope it is that simple. The basic part is cheap, usually under $50, although you can spend more for OEM and up to $200 on fancy billet ones or ones with special adjustment capabilities. Just be sure to match the arm adjustment length to be the same as your old one and then it is pretty much plug and play.
__________________ 2017 Audi Q5 3.0 T (supercharged) Stage 2+ EPL tune, JHM overdrive crank pulley, EPL supercharger pulley, ZF8 TCU tune, aFe/034 intake, modified air box. 480 hp. Sunlight Silver '08 MS3 GT Mods: (Sold 1/25/2019 after 10+ years of ownership) BNR Stage 1 (to fix smoking K04 turbo), TurboXS 3" Catless DP/RP "Stealthback" into stock CBE, Vibrant 3 inch Ultra Quiet Resonator in RP section, Magnaflow 3 1/2" exhaust tip, Mazdaspeed CAI w/air straightener and K&N conical filter, NGK 6510 Iridium IX one step colder plugs, Hypertech tune, Autotech HPFP internals, Stock BPV (works perfectly), Yokohama Advan Neova AD08R's (stock size on stock rims); Hawk HPS pads; SURE RMM; Grimmspeed EBCS (2 port mode), Bilstein B6's, SPC rear camber arms. Last edited by MSMS3; 12-18-2018 at 11:49 AM. |
![]() | | #32 | ![]() |
(Thread Starter) | Not Ranked : 0 score Will do, right now I'm in the process of tearing out the whole turbo, downpipe etc, I'm going to inspect each part because if it's not the wastegate then I dont want to have to go back there again |
| The Following User Says Thank You to Dennisaliy For This Useful Post: | MSMS3 (12-18-2018) |
![]() | | #33 | ![]() |
| Not Ranked : 0 score Not a bad idea to make sure that the wastegate, itself, opens and closes freely, and that the hoses are not leaking. A good time to test the actuator, arm and wastegate motion it is with the turbo off a on the workbench and applying air pressure to the diaphragm. Be sure not to apply more that 18-20 psi, or you may actually blow a good diaphragm. I don't recall the pressure at which the arm starts to move, maybe 10-12 psi (depending on spring pre-set) and then the arm travel increases with increase in pressure until it reaches maximum extension.
![]() | | #34 | ![]() |
| Not Ranked : 0 score when i tested a k04 it was around 12 but i didn'T use 100% certified testing instruments....lol the gate itself is suppose to remain very hard to move by hand so it help to put some pressure in it to install the rod on the flapper arm... check for housing crack, wheel damages and bearing play but there should be minimal play. You can probably find online by a search what is an acceptable play...It will be slightly different if you still have oil in the journal or if it get dry.
![]() | | #35 | ![]() |
(Thread Starter) | Not Ranked : 0 score Okay thanks! I know I have some play when I would wiggle the compressor wheel around but its doesnt seem like alot |
![]() | | #36 | ![]() |
| Not Ranked : 0 score btw if you see baked oil on the downpipe side, it may be because it smoke...
![]() | | #37 | ![]() |
| Not Ranked : 0 score Was it ever asked what your wastegate preload is? Or perhaps it's not adjustable. IDK.
![]() | | #38 | ![]() |
![]() | | #39 | ![]() |
![]() Join Date: Nov 2018
Rep Power: 0 ![]() Thanks: 5
| Not Ranked : 0 score Check the hot side coupler if you have tmic. Hot side piping couplers if fmic. Would double check intake couplers and piping. Pinhole leaks in bov hoses. Check for shaft play in the turbo and boost solenoid, map/boost sensor hoses on on the intake mani(dont think that would cause noise). |
![]() | | #40 | ![]() |
(Thread Starter) | Not Ranked : 0 score I took my 2nd dat off and found my first cat inside of it in peices. I think I found my problem |
| Stock turbo flutter/surge? | Yatta | 2010 MS3 - Turbo Induction | 0 | 05-13-2013 05:19 PM |
| Turbosmart Dual Port Flutter/Surge/Flutterdump? | ChimmyChong | 2010 MS3 - Turbo Induction | 22 | 07-22-2012 10:01 AM |
| Turbosmart Dual Port Flutter/Surge/Flutterdump? | ChimmyChong | MazdaSpeed 3/6 - Turbo Induction | 1 | 01-10-2011 09:29 AM |
| Boost Gauge Flutter | bova | MazdaSpeed 3/6 - Turbo Induction | 21 | 04-13-2009 11:00 AM |
| Compressor surge or bpv flutter | phailerider | MazdaSpeed 3/6 - Turbo Induction | 43 | 04-20-2008 04:42 PM |
