  • 1 Post By turboKart
 Old 03-23-2008, 06:46 PM   #1
Death-From-A-Mile's Avatar
Posts: 1,371   (View Stats)
Death-From-A-Mile is the leader of the worldDeath-From-A-Mile is the leader of the worldDeath-From-A-Mile is the leader of the worldDeath-From-A-Mile is the leader of the worldDeath-From-A-Mile is the leader of the worldDeath-From-A-Mile is the leader of the worldDeath-From-A-Mile is the leader of the worldDeath-From-A-Mile is the leader of the worldDeath-From-A-Mile is the leader of the worldDeath-From-A-Mile is the leader of the worldDeath-From-A-Mile is the leader of the world
Groans: 87
Default How to install an oil catch can?
I am debating doing this to see if it solves my new found smoking problem. Does anyone have a link for a How To thread specifically for the MS3 or MS6. I know that the PCV is down by the intake manifold but dont want to start tearing it apart until I have a better idea of what I am getting in to.
Would you suggest I give this a try first or head straight to the dealership?
Death-From-A-Mile is offline   Reply With Quote
 Old 03-23-2008, 07:06 PM   #2
NYpest's Avatar
Posts: 1,889   (View Stats)
NYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the world
Get a hold of whoosh!!! He wrote up a great out line on the CC install....P.S. you need to remove the intake mani to get at the PCV
NYpest is offline   Reply With Quote
The Following User Says Thank You to NYpest For This Useful Post:
Death-From-A-Mile (03-23-2008)
 Old 03-25-2008, 11:11 AM   #3
whoosh@Realtune's Avatar
Posts: 1,459   (View Stats)
whoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the world
Groaned at 39 Times in 23 Posts
PM sent
whoosh@Realtune is offline   Reply With Quote
The Following User Says Thank You to whoosh@Realtune For This Useful Post:
NYpest (03-25-2008)
 Old 09-13-2014, 10:29 AM   #4
grade247's Avatar
Posts: 58   (View Stats)
grade247 has a spectacular aura aboutgrade247 has a spectacular aura about
Still have that write up whoosh?
grade247 is offline   Reply With Quote
 Old 09-13-2014, 11:02 AM   #5
Sid3wayS's Avatar
Posts: 6,790   (View Stats)
Groans: 97
Damn son bringing this back from the crypt. For a good how to go onto jbr dite under support and look for the occ instructions.
TEAM LUXURY
The Following 2 Users Say Thank You to Sid3wayS For This Useful Post:
Code Monkey (09-13-2014), igve2shtz (09-19-2014)
 Old 09-13-2014, 06:03 PM   #6
turboKart's Avatar
Posts: 321   (View Stats)
turboKart is the leader of the worldturboKart is the leader of the worldturboKart is the leader of the worldturboKart is the leader of the worldturboKart is the leader of the worldturboKart is the leader of the worldturboKart is the leader of the worldturboKart is the leader of the worldturboKart is the leader of the worldturboKart is the leader of the worldturboKart is the leader of the world
Groaned at 8 Times in 4 Posts
Default nice cartmanCoon
@Sid3wayS I noticed you have racoon in your mazda - me too.
I have nothing to say about cc, other than do it.
Sid3wayS likes this.
'09 MGM MS3 - 'MaZcedes'
* Cobb A/P * CP/e S2 RMM * Autotech/6oost3d/McMaster-Carr HPFP Internals * JBR PowerPath SRI/TIP * ATP Catless DP * Cobb XLE BPV * Bilstein B8 Sprint Shocks * JBR 32mm Rear Sway Bar *
STRATIFIED...proper - ZFZMF!
turboKart is offline   Reply With Quote
 Old 09-13-2014, 05:39 PM   #7
Big Dog's Avatar
Posts: 730   (View Stats)
Groans: 89
Groaned at 9 Times in 9 Posts
It was not difficult. Time consuming but not difficult. Clean your valves, EGR, intake, throttle body, and put in a brand new OEM Mazda PCV Valve. While there add in a JBR Stage 2 Catch Can.
2007 MS6 GT:
HTP 3" Full Intake, CS TMIC, AutoTech Internals, APv3, Forge Version 2 BPV(Blue+1 Shim), CP-E Catted DP, Whiteline RSB, CP-E Rear Diff mount, CP-E RMM, CS transmission mount insert, JBR Stage 2 OCC, JBR Boost tubes and recirc hose, Bilsteins B6's all around, Techna-Fit SS clutch and brake lines with ATE fluid, FreekTuned!
 Old 09-13-2014, 05:44 PM   #8
grade247's Avatar
All set guys thanks. Sorry for reviving a dead thread was found via yahoo search. Doing a search via phone on tapatalk doesn't give many threads pertaining to what I was looking for. I ran a all-star performance vented can. For the price it was a good buy
PG manifold install ms3guy22 MazdaSpeed 3 - How-To's 27 08-28-2012 08:34 PM
How-To: Install Cobb Springs + Impressions. Sacrilicious MazdaSpeed 3 - How-To's 24 05-25-2010 02:14 AM
My Custom FMIC Install/Setup Performance Racing MazdaSpeed 3/6 - Turbo Induction 5 04-02-2008 05:44 PM
how NOT to install a TWM Short throw shifter CMESCOOT MazdaSpeed 3 - Engine, Transmission & Driveline 20 04-01-2008 09:06 AM
Catch can installed but I am still smoking Death-From-A-Mile MazdaSpeed 3/6 - Turbo Induction 21 03-28-2008 12:28 PM
Page generated in 0.29339 seconds with 27 queries
