 Old 09-28-2013, 05:46 PM   #1
GeorgeTaper's Avatar
Posts: 74   (View Stats)
GeorgeTaper has a brilliant futureGeorgeTaper has a brilliant futureGeorgeTaper has a brilliant futureGeorgeTaper has a brilliant futureGeorgeTaper has a brilliant futureGeorgeTaper has a brilliant futureGeorgeTaper has a brilliant futureGeorgeTaper has a brilliant futureGeorgeTaper has a brilliant futureGeorgeTaper has a brilliant futureGeorgeTaper has a brilliant future
Default JBR TIP Install Issue
Maybe im being retarded. But every thing ive seen on how to do this ismt clearing this up at all.
I have my stock turbo inlet pipe which next the turbo side has two connections. Both of which I removed. I put my new JbR TIP on and there is on a spot to reconnect one of the connections. To the boost solenoid. I understand there is a spot on my COBB SRI to connect this to. But it is nowhere near long enough. Wtf!
2009 MS3 BLACK MICA GT PACK - Cobb SRI, Autotech HPFP, Cobb AP, JBR TIP, SU TMIC, ATP Catless Longpipe, JBR 88 Duro RMM, JBR EGR block off, JBR thermal gasket, Motorcraft oil, NGK 1 step colder plugs.
GeorgeTaper is offline   Reply With Quote
The Following User Says Thank You to GeorgeTaper For This Useful Post:
3starmagnum (09-28-2013)
 Old 09-28-2013, 05:53 PM   #2
breakfstincluded's Avatar
Posts: 3,588   (View Stats)
you have the revised valve cover breather for smoking turbo fix it looks.
There's not too many aftermarket tips that have their breather hole thing located in the back... HTP, CS and I think JBR used to have one on their non-silicone intakes, I'm not sure why they changed that...
Sure sells a solution that's just a slilicone tube that goes from the valve cover breather to the SRI breather hole. You can probably find something similar for much cheaper at a hardware store, just remove those plastic fittings and put the hose over the pipe. I hate to use a SURE example, but here is a picture just for reference, I am AFFIRMATIVE you can find a cheaper solution in a store, it's just tubing and a connector.
If you have that kind of valve cover, it was probably in effort to prevent or stop smoking turbo
 Old 09-28-2013, 05:53 PM   #3
2.0t03speed's Avatar
Posts: 1,302   (View Stats)
Time to make the hose longer
Sent from my Galaxy S3 using Tapatalk 4 Beta
 Old 09-28-2013, 05:56 PM   #4
Very much appreciated thank you. Just got a new pil catch can in. May have to sacrifice some of that piping if it fits.
This was very irritating after tearimg everything out. Lol
 Old 09-28-2013, 06:15 PM   #5
I had the smoking turbo revision as well and had to plan this out, so I understand the predicament lol
I'll be switching to an HTP intake though so I can retain the benefits of having the breahter closer to the turbo vs near the intake filter
 Old 09-28-2013, 06:21 PM   #6
How good of a seal does this need to have. I mean what happens if its blocked off? Im losing my mind right now
 Old 09-28-2013, 06:28 PM   #7
some people simply put a tiny breather filter on the valve cover pipe and block off the one on the intake and they do fine. IMO it's not ideal, but people say it works great.
Not sure if you could find one locally.
CPE's intake setup comes iwth one i believe
 Old 09-28-2013, 06:32 PM   #8
Run a hose from the intake to the valve cover. One with a 5/8 ID.
Easter Bunny (09-28-2013)
 Old 09-28-2013, 06:33 PM   #9
I have searched the whole garage for one. Guess im gonna have to reinstall stock tip intercooler battery and cobb sri. Drive to home depot. Get some tubing. Drice back. And take it all back off.
Fml.
I feel like ive spent my whole life doing this.
I installed jbr thermal throttle body gasket and coolant bypass and blocked off my egr today.
Hours.
 Old 09-28-2013, 06:40 PM   #10
Welcome to modding.
Agent_Orange (09-28-2013), breakfstincluded (09-28-2013), Cheapspeed (09-28-2013), Easter Bunny (09-28-2013), Hush (09-28-2013), Pointless (09-28-2013)
 Old 09-28-2013, 06:45 PM   #11
Welcome to modding.
Im having fun with it! Its pretty simple stuff until this. Just couldnt figure it out lol. Thanks for all the help peeps.
Neighbor let me borrow his neon. Off to the depot.
I have am oil catch can and 88 rmm to go in but finishing that tonight is ambitious
JBR (09-28-2013)
 Old 09-28-2013, 07:26 PM   #12
Fits perfect
JBR (09-28-2013)
 Old 09-28-2013, 07:31 PM   #13
Nice....Disaster narrowly averted.
 Old 09-28-2013, 07:33 PM   #14
Next is occ and rmm. I have a tie up betweem gettimg up early and gettimg started before the leMons race. Or tonight. Hmm.
MS6 Sure Sidewinder install issue LTHorn Mazdaspeed3/6 General Discussion 1 04-14-2013 09:32 PM
Issue After SRI/TIP Install MS3BPS2286 2010 MS3 - Troubleshoot/Diagnostics 22 09-25-2012 01:41 PM
RDM install with FDM issue SpeedRebirth MazdaSpeed 6 - Engine, Transmission & Driveline 10 07-18-2012 07:48 PM
Downpipe Install Issue CCC 2010 MS3 - Engine, Transmission & Driveline 29 06-07-2010 01:19 PM
Issue after DP Install MS3KO MazdaSpeed 3/6 - Troubleshoot/Diagnostics 14 03-04-2010 11:20 AM
Page generated in 0.35231 seconds with 24 queries
