 Old 08-09-2013, 08:29 PM   #1
torq's Avatar
Posts: 82   (View Stats)
torq has a reputation beyond reputetorq has a reputation beyond reputetorq has a reputation beyond reputetorq has a reputation beyond reputetorq has a reputation beyond reputetorq has a reputation beyond reputetorq has a reputation beyond reputetorq has a reputation beyond reputetorq has a reputation beyond reputetorq has a reputation beyond reputetorq has a reputation beyond repute
Groaned at 6 Times in 3 Posts
Default Leakdown test question
Been chasing down the various leaks in my boost system and had a quick question.
We found that if we straight up pressurized the intake, the valve cover gasket would leak violently at 15 psi, I realize it won't see this pressure normally but it seems off, is that normal?
We then decoupled PCV return from the crankcase to the intake and then plugged the end on the intake so that we wouldn't pressurized the valve cover directly. I switched to the stock BPV and recirc for testing.
We pressurized the system to 20psi and it slowly leaked out the valve cover return that we had left open, if you hold your finger over it you can hold it for about 10 seconds or so before you have to release and hear a pretty big whoosh. My brother was surprised at the amount of pressure building up in the valve cover. Is this normal?
Thanks in advance.
Cobb AP Autotech HPFP Internals JBR RMM,SSP,Stage2 OCC. RSB CS Racepipe, SSB ETS TMIC Stratified Guardian Angel NGK Step Colder Plugs HTP 3" full intake. Michelin 245/40/18 Pilot Super Sports TSW 18x8.5+45 Nurburgring Wheels Swift Spec-R Springs Koni Yellow Struts/Shocks GFB BOV
torq is offline   Reply With Quote
Test Pipe Question theMANIMAL 2010 MS3 - Engine, Transmission & Driveline 10 07-21-2013 05:33 PM
Test Pipe Question allen624 MazdaSpeed 3 - Engine, Transmission & Driveline 8 04-24-2012 05:10 AM
Installed UR Test Pipe...question? mrmonk7663 Gen2 MS3 General Discussion 22 07-27-2011 09:29 PM
test pipe question awdfun MazdaSpeed 3/6 - Turbo Induction 9 01-05-2011 11:05 PM
Evo X test drive question. SgtP Mazdaspeed3/6 General Discussion 16 12-25-2010 02:01 PM
Page generated in 0.22686 seconds with 20 queries
