8Likes ![]() |
![]() Join Date: Nov 2011 Location: Raleigh, NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,624
Groans: 63
(Thread Starter) | Not Ranked : 0 score One of the most discussed topics on MSF is "What turbo should I upgrade to?", a question that can be difficult to answer at best. Turbo selection is going to be based on a number of factors, the main ones being power goals and typical use of the vehicle. Supporting modifications will play a large role in turbo selection as well, but that's going to be another topic for another thread. Here we will discuss the bolt-on turbo options and turbo kits for the Mazdaspeed3 (2007-2013) and Mazdaspeed6 (2006-2007). Because the engines are the same the turbo options remain the same, however the supporting modifications to run each turbo may vary slightly (e.g. an MS3 downpipe will not fit the MS6). Again though, the details of that discussion are for another place. What constitues "bolt-on" largely depends on an individual's definition of the word. For the purposes of this thread we will treat all commercially available (not custom made, or made to order) turbo chargers and turbo kits as "bolt-ons". No fabrication is required to run any of these turbos/kits, but supporting mods will definitely vary. In this post I will cover all bolt-on turbo charger upgrades and, as best I can, list prices, required supporting mods (if a turbo manifold upgrade is necessary or a change in intake/intercooler couplers for example), vendors, and potential power output. ================================================== ====== Starting off this list are BNR turbos. BNR turbos are made by Brian Nickell Rotary (BNR), website BNRSupercars.com. BNR currently has 2 turbo options for the MS platform. BNR S1: $900 The BNR S1 turbo is as close to a stock replacement turbo as you can get. This turbo uses a Garrett GT2860 CHRA, an exhaust housing modeled after the stock Mazdaspeed housing, a stock [possibly ported] compressor housing, and a stock adjustable wastegate actuator. Benefits: This turbo is a good option for someone who needs a turbo replcement but does not want to upgrade turbos. There is some debate on the topic but it is typically agreed upon that this turbo can be run in an otherwise stock car with no tune meaning if the stock turbo fails in a car this can be substituted as a direct replacement. Downfalls: This is not a big power turbo. It will act very much the same as the stock k04 with peaky mid-range power, quick response, and possibly just a slight jump in top end. Additional Part Requirements: None Expected Power: Because this is a stock replacement turbo power output is expected to be around stock turbo levels. Expect 240-250whp on an otherwise stock car and up to ~330whp with proper supporting mods and ethanol/WMI. BNR S3: $1100 The BNR S3 is one of the most popular turbo options available for the Mazdaspeed platform for a number of reasons, the first being its price-to-performance ratio. Like the BNR S1 the BNR S3 can bolt into an otherwise stock car but this one will absolutely require a retune of the ECU to run. Unlike the BNR S1, however, the S3 offers a sigificant performance bump. A Garrett GT2871 CHRA is nestled between an upgraded turbine housing custom made for BNR and a custom, larger compressor housing with a 14psi wastegate actuator. Many times this turbo has been called "what the Mazdaspeeds should have come from the factory with." Benefits: Because the BNR S3 is relatively small but still larger than the stock k04 it is a great mid-level turbo. Throttle response will be quick, turbo lag will be minimal, and power output will get a healthy bump. Because it's the cheapest upgraded turbo outside of the BNR S1 it won't break the bank while still delivering plenty of power for most people. Downfalls: Here again this is not a monster power turbo, but that's largely the only downside. If properly setup and tuned this turbo is a great option for the majority of owners. Additional Part Requirements: Tuning solution and EBCS or MBC Expected Power: With just a couple of flow mods this turbo can make in the 320whp range with a good tune. With a full cast of support and ethanol/WMI this turbo has been pushed into the 400hp range on an aggressive tune. ================================================== ====== Next on the list, and overall the most popular range of available turbos is the ATP GT/GTX lineup. ATP Turbos are a popular option because they are readily available, offer a wide range of turbo options, mate to existing parts, and are proven commodities when it comes to installation, power output, etc... It doesn't hurt that they were one of the first to hit the market and have been around the longest. ATP turbos use Garret GT or GTX ball bearing CHRAs and compressor housings mated to ATP-designed turbine housings made with the mazda input and output flanges for stock turbo manifolds and downpipes. This exhaust housing is key to being on a bolt-on turbo as it allows buyers to use aftermarket downpipes that were originally purchased to fit the stock k04. Many of the ATP options come in both GT and GTX trim. The difference between these turbos is in the compressor wheel which is cast in the GT series and forged in the GTX. The GTX series also has improved aerodynamics over the GT turbos. The real world difference between these types of turbos is a common misconception. Many believe that the GTX turbos will spool faster than the GT but this is not the case; both turbo types will spool at roughly the same RPM on any given car and tune. The real difference is in top end efficiency where the GTX turbos will shine due to improved compressor wheel aerodynamics and lighter weight. Going in order of size.... GTX2860R: $1700 This is the smallest of the ATP turbos and utilizes a GTX28 series compressor housting with a 60mm exducer wheel. This smallest turbo will behave the most like a stock turbo of all the ATP offerings. Benefits: Lighting quick spool and almost no turbo lag can be expected from this turbo. Downfalls: Not a monster power machine. High cost for performance. Additional Part Requirements: At the very least this turbo will require a tuning solution, EBCS or MBC, and a 3" adapter for whatever intake you run. Expected Power: TBD. As far as I know there are no MSF members running this turbo. Likely output will range from 260whp to ~350whp depending on additional modifications and tuning. GTX2863R: $1700 This is the second smallest of the ATP turbos and utilizes a GTX28 series compressor housting with a 63mm exducer wheel. This small turbo will behave very similarly to the stock turbo. Benefits: Lighting quick spool and almost no turbo lag can be expected from this turbo. Downfalls: Not a monster power machine. High cost for performance. Additional Part Requirements: At the very least this turbo will require a tuning solution, EBCS or MBC, and a 3" adapter for whatever intake you run. Expected Power: TBD. As far as I know there are no MSF members running this turbo. Likely output will range from 2750whp to ~380whp depending on additional modifications and tuning. GTX2867R: $1700 This is the most popular of the small ATP GTX turbos and utilizes a GTX28 series compressor housting with a 67mm exducer wheel. This small turbo will behave very similarly to the stock turbo. Benefits: Quick spool and almost no turbo lag can be expected from this turbo. When pushed to the limits this turbo is capable of impressive numbers while maintaining great drivability. Downfalls: Not a monster power machine. Additional Part Requirements: At the very least this turbo will require a tuning solution, EBCS or MBC, and a 3" adapter for whatever intake you run. Expected Power: On an otherwise stock car this turbo should make in the 280whp range with a proper tune. When mated to a car with a high level of modification (WMI, ported intake manifold, 3" catless exhause, 3"+ intake, etc...) it is capable of over 400whp. GT2871R: $1500 This is a tried and true turbo that utilizes a GT28 series compressor housting with a 71mm exducer wheel. This turbo offers great potential for the price Benefits: Quick spool and almost no turbo lag can be expected from this turbo. For most users it is a very comparable unit to the GTX2867 that will yeild similar results for less money. Downfalls: Not a monster power machine. At the very top of its range it has less proven potential than the smaller GTX2867 due to the older technology. Additional Part Requirements: At the very least this turbo will require a tuning solution, EBCS or MBC, and a 4" adapter for whatever intake you run. Expected Power: On an otherwise stock car this turbo should make in the 280whp range with a proper tune. When mated to a car with a high level of modification (WMI, ported intake manifold, 3" catless exhause, 3"+ intake, etc...) it is capable of near 380whp. GTX3067R: $1800 (IWG) This is the smallest turbo offered in a 30 trim and utilizes a GTX30 series compressor housting with a 67mm exducer wheel. This turbo is said to spool like a 28 series and flow like a 30 series but reality is going to be somewhere in between. This is also the first in our lineup to have an EWG housing available. Benefits: Quick spool for the size and only a little turbo lag can be expected from this turbo. When pushed to the limits this turbo is capable of impressive numbers while maintaining great drivability. The relatively small wheel with the larger frame can mean huge torque numbers down low while maintaining top end power. Downfalls: More lag than a GTX28 series and more expense. Not as powerful on the top end as its big brothers. Additional Part Requirements: At the very least this turbo will require a tuning solution, EBCS or MBC, and a 4" adapter for whatever intake you run. Expected Power: On an otherwise stock car this turbo should make in the 300whp range with a proper tune. When mated to a car with a high level of modification (WMI, ported intake manifold, 3" catless exhause, 3"+ intake, etc...) it is capable of over 400whp. GT/X3071R: $1600 (GT,IWG) / $1800 (GTX,IWG) / $1983 (GT,EWG) / $2048 (GT,IWG,AntiSurge) / $2203 (GTX,EWG) Here is where we start getting into some options. The GT/X3071 turbo is a 30 trim compressor housing with a 71mm exducer wheel available in both GT and GTX options, each with either IWG or EWG. All options offer power potential substantially higher than what a stock Mazdaspeed fueling system can deliver. Benefits: This is the turbo in ATPs lineup where 400whp is a relatively easy feat. Downfalls: Turbo lag starts to really become noticeable with this level of turbo. Any of the 3071 turbos has the potential to max the fuel system abilities and make more torque than the stock bottom end can handle. Care must be taken in tuning to avoid these situations. Additional Part Requirements: At the very least this turbo will require a tuning solution, EBCS or MBC, and a 4" adapter for whatever intake you run. EWG kits come with all of the necessary parts to run that setup. Expected Power: On an otherwise stock car this turbo should make in the 300whp range with a proper tune. With full bolt-ons and no additional fueling it can just start to touch 400whp on high quality pump gas. When mated to a car with a higher level of modification (WMI, ported intake manifold, 3" catless exhaust, 3"+ intake, etc...) it is capable of nearing the 450whp range. GT/X3076R: $1600 (GT,IWG) / $1800 (GTX,IWG) / $1983 (GT,EWG) / $2203 (GTX,EWG) This turbo, regardless of exact model, may be the most popular unit for the Mazdaspeed family. The GT/X3076 is a 30 trim compressor housing with a 76mm exducer wheel available in both GT and GTX options, each with either IWG or EWG. All options offer power potential substantially higher than what a stock Mazdaspeed fueling system candeliver. Benefits: This turbo will flow more air than your stock engine can handle. It will make very big power if the support is behind it. Downfalls: Turbo lag increases a few hundred RPM from the 3071 turbos to this one. Any of the 3076 turbos will max the fuel system in the hands of a competent tuner. This turbo will still make lots of torque in the mid-high range (mid 5000 RPM). Care must be taken in tuning to avoid the dreaded ZZB. Additional Part Requirements: At the very least this turbo will require a tuning solution, EBCS or MBC, and a 4" adapter for whatever intake you run. EWG kits come with all of the necessary parts to run that setup. Expected Power: On an otherwise stock car this turbo should make over 300whp with a proper tune. With full bolt-ons and no additional fueling it can exceed 400whp on high quality pump gas. When mated to a car with a higher level of modification (WMI, ported intake manifold, 3" catless exhause, 3"+ intake, etc...) it is capable of topping the 450whp range with room to spare. GT/X3576R: $2149 (GT,EWG) / $2609 (GTX,EWG) These turbos are the big boys for this platform, 35 series units. The GT/X3576 is a 35 trim compressor housing with a 76mm exducer wheel available in both GT and GTX options, currently only available with EWG housings. These turbos are made for big power and are far more capable than a stock engine. Benefits: This turbo will flow much more air than your stock engine can handle. It will make very big power easily if your engine can keep up. High pressure ratios are expected (30psi+) from these. Downfalls: Turbo lag is the killer here, typically spooling to 20psi+ well past 4000 RPM where the stock turbo can do it under 3k. Maxing the capabilities of the stock fuel system is very easy. Torque numbers can be high but in upper RPM ranges. Stock rev limit does not leave much room for use of this turbo. Additional Part Requirements: At the very least this turbo will require a tuning solution, EBCS or MBC, and a 4" adapter for whatever intake you run. EWG kits come with all of the necessary parts to run that setup. Expected Power: On an otherwise stock car these turbos are completely unknown entities. With full bolt-ons and no additional fueling it can easily exceed 400whp on high quality pump gas. When mated to a car with a higher level of modification (WMI, ported intake manifold, 3" catless exhause, 3"+ intake, etc...) it is capable of topping the 500whp range. GT/X3582R: $1799 (GT,IWG) / $2299 (GTX,IWG) / $2199 (GT,EWG) / $2659 (GTX,EWG) These turbos are similar to the GT/X3576, 35 series units with a 76mm exducer wheel available in both GT and GTX options, each with either IWG or EWG. These turbos are made for big power and are far more capable than a stock engine. Benefits: This turbo will flow much more air than your stock engine can handle. It will make very big power easily if your engine can keep up. High pressure ratios are expected (30psi+) from these. Downfalls: Turbo lag is the killer here, typically spooling to 20psi+ well past 4000 RPM where the stock turbo can do it under 3k. Maxing the capabilities of the stock fuel system is very easy. Torque numbers can be high but in upper RPM ranges. Stock rev limit does not leave much room for use of this turbo. Additional Part Requirements: At the very least this turbo will require a tuning solution, EBCS or MBC, and a 4" adapter for whatever intake you run. EWG kits come with all of the necessary parts to run that setup. Expected Power: On an otherwise stock car these turbos are completely unknown entities. With full bolt-ons and no additional fueling it can easily exceed 400whp on high quality pump gas. When mated to a car with a higher level of modification (WMI, ported intake manifold, 3" catless exhause, 3"+ intake, etc...) it is capable of topping the 500whp range. A special note to add to this list as well is the following: Forced Performance GT3076R: $1919 This turbo is available through edgeautosport.com and is an upgraded version of the standard GT3076. The HTA GT3076 is a 30 trim compressor housing with a 76mm exducer wheel available only with and ATP EWG housing. This turbo costs substantially more than the standard GT3076 because it has been reworked by Forced Performance to be more responsive and have a higher top end than the standard turbo. Benefits: This turbo will flow more air than your stock engine can handle. It will make very big power if the support is behind it. The Forced Performance treatment will make it spool more like a GT3071 while outflowing the standard GT3076 Downfalls: Turbo lag will be noticeable. Any of the 3076 turbos will max the fuel system in the hands of a competent tuner. This turbo will still make lots of torque in the mid-high range (mid 5000 RPM). Care must be taken in tuning to avoid the dreaded ZZB. Additional Part Requirements: At the very least this turbo will require a tuning solution, EBCS or MBC, and a 4" adapter for whatever intake you run. This turbo is EWG only but does not come as a kit so an EWG, dump tube, and oil lines are required additional parts to run this turbo. Expected Power: On an otherwise stock car this turbo should make over 300whp with a proper tune. With full bolt-ons and no additional fueling it can exceed 400whp on high quality pump gas. When mated to a car with a higher level of modification (WMI, ported intake manifold, 3" catless exhause, 3"+ intake, etc...) it is capable of topping the 450whp range with room to spare. ================================================== ====== Outside of the BNR and ATP turbo offerings there are no bolt-on turbos only kits. First up are Precision Turbo kits. Precision Turbo kits are a complete bolt-on turbo kit from cylinder head to cat-back. All of the Precision kits include a CP-e EWG turbo manifold specced with a Precision v-band exhaust housing flange. Each kit also comes with Kozmic Motorsports downpipe, oil feed and drain lines, WG dump tube and EGR block-off, and a Tial or Turbosmart 44mm wastegate. Besides the above standard list of parts each turbo also has a list of available options; the buyer can select either a .64 or .82 A/R housing, B, E, S or ported S compressor housing, and either ball bearing or journal bearing CHRA. Each of these options is available with each turbo choice and the selection of exact parts spec should be determined by desired use and mating components. All Precision turbos offered for the Mazdaspeed platform feature their CEA turbine and compressor wheels which, like Garrett's GTX series, are forged and machine billet wheels that offer improved geometry and aerodynamics over older designs while cutting weight. PTE 5558: $3302 (Journal Bearing) / $3902 (Ball Bearing) This is the smallest of the Precision offerings but is still a rather large turbo. Like all precisions the ball bearing option is a costlier one but will spool faster than its journal bearing counterpart. Benefits: This turbo should be a great jack-of-all-trades turbo that will spool nicely and flow enough air for most users. Downfalls: Turbo lag will be noticeable but not distracting. Low-to-mid level torque can be a killer with a turbo this size so care must be taken to not overwork a stock engine. Additional Part Requirements: At the very least this turbo will require a tuning solution, EBCS or MBC, and an adapter sized for both the intake and selected compressor housing. It may also require an adapter elbow for the intercooler depending on the selected compressor housing and intercooler setup. Expected Power: No hard and fast data is available for this turbo but power output should be roughly similar to a GTX3076. PTE 5858: $3302 (Journal Bearing) / $3902 (Ball Bearing) This is one of the more popular Precision offerings. Similarly sized to a GTX3076, this turbo is a great daily driver and can out flow a stock engine. Like all precisions the ball bearing option is a costlier one but will spool faster than its journal bearing counterpart. Benefits: This turbo should be a great jack-of-all-trades turbo that will spool decently and flow more air than a stock engine can handle. Downfalls: Turbo lag will be noticeable. Low-to-mid level torque can be a killer with a turbo this size so care must be taken to not overwork a stock engine. Additional Part Requirements: At the very least this turbo will require a tuning solution, EBCS or MBC, and an adapter sized for both the intake and selected compressor housing. It may also require an adapter elbow for the intercooler depending on the selected compressor housing and intercooler setup. Expected Power: With a fully built setup this turbo can push well over 500whp. PTE 5862: $3302 (Journal Bearing) / $3902 (Ball Bearing) This is the smallest of the Precision offerings but is still a rather large turbo. Like all precisions the ball bearing option is a costlier one but will spool faster than its journal bearing counterpart. Benefits: This turbo is in the range of very big horsepower. Downfalls: Turbo lag will become prevalent. Low-to-mid level torque can be a killer with a turbo this size so care must be taken to not overwork a stock engine. A built engine is necessary to utilize this turbo's full potential. Additional Part Requirements: At the very least this turbo will require a tuning solution, EBCS or MBC, and an adapter sized for both the intake and selected compressor housing. It may also require an adapter elbow for the intercooler depending on the selected compressor housing and intercooler setup. Expected Power: No hard and fast data is available for this turbo but power output should be higher than the PTE5858, pushing 600whp. PTE 6262: $3325 (Journal Bearing) / $3925 (Ball Bearing) Here is where the big boys start to play. Like all precisions the ball bearing option is a costlier one but will spool faster than its journal bearing counterpart.Benefits: This turbo is in the range of very big horsepower. Downfalls: Turbo lag is prevalent. Low-to-mid level torque is reduced but overall power is going to be very high. A built engine is necessary to utilize this turbo's full potential. Additional Part Requirements: At the very least this turbo will require a tuning solution, EBCS or MBC, and an adapter sized for both the intake and selected compressor housing. It may also require an adapter elbow for the intercooler depending on the selected compressor housing and intercooler setup. Expected Power: Not much data is available but this turbo should push 700whp on a properly setup and tuned car. PTE 6266: $3325 (Journal Bearing) / $3925 (Ball Bearing) The mac daddy of bolt-on turbos. Like all precisions the ball bearing option is a costlier one but will spool faster than its journal bearing counterpart. Benefits: This turbo is run on some of the highest power Mazdaspeed cars to date. Downfalls: Turbo lag is prevalent. Low-to-mid level torque is reduced but overall power is going to be very high. A built engine is necessary to utilize this turbo's full potential. Additional Part Requirements: At the very least this turbo will require a tuning solution, EBCS or MBC, and an adapter sized for both the intake and selected compressor housing. It may also require an adapter elbow for the intercooler depending on the selected compressor housing and intercooler setup. Expected Power: With the proper additional modifications this turbo has been shown to push 800whp. ================================================== ====== Last up on our tour of bolt-on turbo options is the set of offerings from Full Race in their EFR setups. EFR turbos are Borg Warner's top of the line offering and utilize both an IWG and internal bypass valve. Full Race has created a kit that makes these turbos a bolt-on option with a turbo manifold (T25 exhaust housing) and downpipe with a v-band attachment. For the Gen2 MS3s and MS6s Full race also offers a kit with an intercooler kit and crash bar that are direct bolt-ons. This setup does not exist for Gen1 MS3s. 6258 EFR: $3950 (MS3, Without Intercooler) / $5797 (MS3, With Intercooler) / $5954 (MS6) With Intercooler) This is the smallest of the Full Race offerings. Despite its small size though, the EFR technology produces a turbo that can make large amounts of power without sacrificing spool time. Benefits: This turbo should be a great jack-of-all-trades turbo that will spool nicely and flow enough air for most users. Turbo lag will be minimal. Downfalls: This turbo won't make huge power but will be a great unit otherwise. The stock engine may be maxed on power even with this small of a turbo and high low to mid end torque is possible so care must be taken in tuning. Additional Part Requirements: At the very least this turbo will require a tuning solution and adapters for the intake and intercooler. Expected Power: Little data is available but this turbo should produce 350-400whp on a properly set up car. 6758 EFR: $3950 (MS3, Without Intercooler) / $5797 (MS3, With Intercooler) / $5954 (MS6) With Intercooler) This is the middle range turbo of the Full Race offerings. The turbo is still a relatively small unit that can produce lots of power. Benefits: This turbo should be a great jack-of-all-trades turbo that will spool nicely and flow enough air for most users. Turbo lag will be minimal. Downfalls: This turbo won't make huge power but will be a great unit otherwise. The stock engine may be maxed on power even with this small of a turbo and high low to mid end torque is possible so care must be taken in tuning. Additional Part Requirements: At the very least this turbo will require a tuning solution and adapters for the intake and intercooler. Expected Power: Little data is available but this turbo should produce 400-450whp on a properly set up car. 7163 EFR: $4145 (MS3, Without Intercooler) This is the largest of the Full Race offerings. Despite its small size though, the EFR technology produces a turbo that can make large amounts of power without sacrificing spool time. Benefits: This turbo will make big power without much effort. Downfalls: There will be a bit of lag with this turbo but it will be easily manageable. The stock engine may be maxed on power even with this small of a turbo and high low to mid end torque is possible so care must be taken in tuning. Additional Part Requirements: At the very least this turbo will require a tuning solution and adapters for the intake and intercooler. Expected Power: Little data is available but this turbo should produce 450-500whp on a properly set up car. ** @Raider; here's the thread. No pictures yet, it took me long enough to write it. I"ll edit that in a week or so when I get back from a business trip.***
__________________ Blue Pu. "Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." |
| The Following 21 Users Say Thank You to anavrinIV For This Useful Post: | Agent_Orange (02-17-2015), allo80 (04-23-2016), Code Monkey (02-16-2015), cyclist20 (02-15-2015), Design (02-17-2015), Easter Bunny (02-16-2015), hatchedspeed3 (02-17-2015), Ingle (02-16-2015), Jakeypoo (12-14-2015), Jtaylor (02-18-2015), MD1032 (02-25-2015), mooseaidz (04-20-2016), NCZ13 (02-16-2015), phecker410 (02-19-2015), Poohster (02-15-2015), Raider (02-17-2015), Sleepin6 (12-22-2015), SpeedRebirth (02-16-2015), tegxsi (02-16-2015), Tifosi42 (02-16-2015), TiGraySpeed6 (02-16-2015) |
![]() Join Date: Feb 2012 Location: davenport, iowa
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,201
Groans: 128
| Not Ranked : 0 score Bnr s2 up to 350/360hp
__________________ 09 Speed3 ,sold 2012= k04@18lbs, k&n intake, race pipe, selftune13.00@109.76 2013= BNRs2@20lbs E30 FreekedBuilt & Bolted12.63@113.75 full weight, nitto dr's 2014 06 ms6 gt3076 built bolted 2015 06 ms6 parted 2016 07 cosmic MS3 SOLDforged pistons/rods, bsd baffle, cs turbo, fmic, occ, spin on conv, catless long dp, e30, sri, cpe hpfp, rmm, ported im. |
| Not Ranked : 0 score Discontinued; you may grab a used one, there seems to be one per year popping up for sale. @anavrinIV; please note that for ms6's any turbo that cannot reuse the stock oil return line is not a bolt-on, it think only the BNR fits the bill at the time being.
| The Following 2 Users Say Thank You to Code Monkey For This Useful Post: | Easter Bunny (02-16-2015), TiGraySpeed6 (02-16-2015) |
![]() Join Date: Mar 2012 Location: Bend, Oregon
Rep Power: 670 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,489
Groans: 122
| Not Ranked : 0 score Great write up! Only one thing that stood out for me was under the GTX2863R section, it shows that you could make 2750whp, which would be awesome!
__________________ 2006 BCM Mazdaspeed 6 GT w/navi SOLD Freektune: 400whp/387awtq Mods: Cobb AP, MSD Dashhawk, GT3076r, HTP 3" SRI, FMIC w/ tr8, Wiseco Pistons (9.5:1), Manely Rods, HPFP AutoTech Intenals, NJSPEED3 Ported Intake Manifold w/ VCTS Delete, Turbosmart BPV, Grimspeed 3-Port EBCS, NGK Iridium One Step Colder Plugs, 3.0" ATP Turbo Dowpipe w/ high flow cat, Devil's Own Stage 1 Methanol/Water Injection Kit, 50/50 Methanol, ACT 6 puck sprung w/ streetlite flywheel, Block8head vent pod, Prosport Performance Boost Gauge Amber/White, Cipher Auto Harness Bar, Cipher Auto 4-point Racing Harness, BC Racing Coilovers, CP-E rear diff mount, JBR RMM 80A, SPC Front Adjustable Ball Joints, Enkei Raijin Hypersilver 18x8 +45, 225/45/18 -Autocross Setup- 17x8 +38, BF Goodrich R1 225/45/17 Other Rides: 2006 Mazdaspeed6 GT BCM: 114k miles, never modded (Totaled March 2013) 1969 Ford Ranchero: 351 Windsor, Edelbrock 600cfm, fully re-done interior (w/ Grant steering wheel, '91 T-Bird SC racing bucket seats), C-6 Automatic Trans w/ shifter kit, First, body work, then drag racing and dumping money into it. 1969 Pontiac Firebird: 4:11 gears, 28x10 ET Streets (Middle of restoration with father) 1998 Toyota Tacoma 4x4: 174k miles, 5 speed, Fiberglass Baja Front clip, 2in body lift, 4in suspension lift, 33x10 BFG All-Terrains, Custom Smittybuilt Bumpers, Custom Intake (SOLD) |
| The Following User Says Thank You to rymanmazda For This Useful Post: | Easter Bunny (02-16-2015) |
Groans: 33
| Not Ranked : 0 score There is also the Atmosphere kit from CPE with turbo sizes of 28 to 35, ewg, v-band hotside ect. Requires no customization at all
| Not Ranked : 0 score What, no pics?? I came for the turbo porn... Great write up & has been needed for a long time! Thanks!
![]() Join Date: Jun 2013 Location: Edmond, OK
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,349
When I blew my turbo last month I called BNR. I was originally going to just get an S1. Bryan didn't have any in stock. He offered an S2 turbo he had. Perhaps they are available just not openly advertised? (I went with an S3 ftw)
__________________ 2013 LSM Speed BNR S3v3 AP V3 Corksport: HPFP Internals, Injector Seals, bpv, battery box, intake manifold Full Race: Exhaust Manifold, ceramic coated for lovliness CNT:Catted DP Treadstone TR8 with Cobb piping CP-e: Stage II RMM HTP:3" intake Stratified: 3port, Guardian Angel JBR RSB, Shifter Bushings, EGR Delete/Blockoff Matt Damond:OCC, PMM, TMM UR Axleback Rice: Corksprt CF Hoodscoop & Spoiler // 12mm spacers // Bayson R lip // Bayson R GV grill // Okiefam powercoated VC, coil, and HPFP covers Tuned by PURPLE DRANK | |
| The Following User Says Thank You to cyclist20 For This Useful Post: | Code Monkey (02-16-2015) |
Groans: 63
(Thread Starter) | Not Ranked : 0 score I knew i was missing something
| Not Ranked : 0 score Please comment if this is good to go to the Knowledgebase. |
![]() Join Date: Nov 2013 Location: Killeen, Texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 724
| Not Ranked : 0 score @Raider; deff should be added. Great write up, but not too in depth to the point of headaches and confusion.
__________________ 08 TR MS3 - totaled and stocked out 1-5-2014 Daily Driver - 2016 WRX w/STI lip kit 2009 CWP MS3 1-23-2014 CXRacing FMIC with TR8 Core /// HKS Turbo Timer /// 6000k HIDs /// Yellow Fog Covers /// Cobb SRI /// Ultimate Racing TBE /// White Avid 21 18x8.5 Wrapped In Kuhmo 225-40-18s /// Short Throw Shifter /// Kozmic Motorsports EGR Delete /// Corksport HPFP internals /// CS Front Sway Bar /// /// JBR RMM, TMM, and PMM (all 80a) /// Slotted Rotors /// CS Foglight Kit /// CS License Plate Bracket /// CS Bypass Hose /// Rolled Fenders /// JBR Weighted Red Shift Knob /// Cobb AP //////![]() |
| The Following 2 Users Say Thank You to hatchedspeed3 For This Useful Post: | Raider (02-18-2015), stanley0910 (02-18-2015) |
Groans: 63
(Thread Starter) | Not Ranked : 0 score Just a note i will be updating the op next week with pictures and the cp-e atmosphere kits. I'm also considering adding outdated turbos like the bnr s2, cp-e elevate and pg upgraded turbos for anyone who might stumble across one and have questions about them. Any suggestions or objections to this?
| The Following User Says Thank You to anavrinIV For This Useful Post: | mxlplx71 (02-18-2015) |
Groans: 122
__________________ 2006 BCM Mazdaspeed 6 GT w/navi SOLD Freektune: 400whp/387awtq Mods: Cobb AP, MSD Dashhawk, GT3076r, HTP 3" SRI, FMIC w/ tr8, Wiseco Pistons (9.5:1), Manely Rods, HPFP AutoTech Intenals, NJSPEED3 Ported Intake Manifold w/ VCTS Delete, Turbosmart BPV, Grimspeed 3-Port EBCS, NGK Iridium One Step Colder Plugs, 3.0" ATP Turbo Dowpipe w/ high flow cat, Devil's Own Stage 1 Methanol/Water Injection Kit, 50/50 Methanol, ACT 6 puck sprung w/ streetlite flywheel, Block8head vent pod, Prosport Performance Boost Gauge Amber/White, Cipher Auto Harness Bar, Cipher Auto 4-point Racing Harness, BC Racing Coilovers, CP-E rear diff mount, JBR RMM 80A, SPC Front Adjustable Ball Joints, Enkei Raijin Hypersilver 18x8 +45, 225/45/18 -Autocross Setup- 17x8 +38, BF Goodrich R1 225/45/17 Other Rides: 2006 Mazdaspeed6 GT BCM: 114k miles, never modded (Totaled March 2013) 1969 Ford Ranchero: 351 Windsor, Edelbrock 600cfm, fully re-done interior (w/ Grant steering wheel, '91 T-Bird SC racing bucket seats), C-6 Automatic Trans w/ shifter kit, First, body work, then drag racing and dumping money into it. 1969 Pontiac Firebird: 4:11 gears, 28x10 ET Streets (Middle of restoration with father) 1998 Toyota Tacoma 4x4: 174k miles, 5 speed, Fiberglass Baja Front clip, 2in body lift, 4in suspension lift, 33x10 BFG All-Terrains, Custom Smittybuilt Bumpers, Custom Intake (SOLD) | |
![]() Join Date: Sep 2011 Location: Cape Town, South Africa
Rep Power: 237 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 90
| Not Ranked : 0 score I was able to post a comparison table at GT vs BNR. It is ranked in descending Genpu popularity order just like the OP's. The table describes: Boosts from (RPM) Maximum Boost (psi) Peak Pressure Ratio HP Maximum lbs / min
__________________ MS3 Gen2: AT: HPFP Int; Cobb: AP V3/ATR; CS: SRI/TIP, Catless DP; DIY: Air-box; GS: EBCS; Hankook: V12; NGK: 1 step cooler; OTC: EGR Del, OCC with VTA, PCV Plate, TP Coolant Bypass |
| Not Ranked : 0 score @anavrinIV; Should it be mentioned that ball bearings spool 15% faster than journal / roller / thrust / sleeve bearing turbos, but thrust bearing turbos (BNR) cost about half and can be rebuilt (some ball bearing turbos cannot be rebuilt)? It might be useful to say that for Garrett turbos, the first letters denote the style, the next two numbers denote the frame size and the last two numbers represent the exducer size of the compressor wheel with a final “R” for ball bearing or blank for journal bearing. However, for Borg Warner turbos, the first two numbers are the exducer hot side size and the next two numbers are the inducer cold side size in mm. You have stated that the GTX versions do not spool faster than the GT versions. ATP claims that the newer GTX is lighter, stronger CNC machined billet compressor wheel flows 10% more, makes more power, yet does not significantly add lag over the GT versions, (but cost more than GT turbos). You said that the GT2867R is the most popular of the small ATP GTX turbos. I assume that this is when comparing with other 28 trim compressors as I have seen more Genpu signatures with the GT3071R / GTX3071. Also, for Genpus the BNR S2 is more popular than the GT3076. Where are the Borg Warner S200 / S256 and S300SX 8375 S360?
![]() Join Date: Aug 2014 Location: Lehigh Valley, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 108
| Not Ranked : 0 score Kinugawa,xs power turbo's...Are these companies even considered an option on this platform as far as bolt-on turbo's or are they just stock replacements? Are they junk is the real question?
__________________ MS6 GT...REBUILD IN PROGRESS BOLTED AND BOOST PROVIDED BY... SPEED1/CORKSPORT... Last edited by Sleepin6; 12-17-2015 at 06:12 PM. |
| Not Ranked : 0 score I think it's about that time we add in the corksport and BNR s4
| The Following 4 Users Say Thank You to Djohns For This Useful Post: |
| Not Ranked : 0 score @anavrinIV;, can you add the Corksport and BNR S4? |
| The Following User Says Thank You to Raider For This Useful Post: | Sleepin6 (01-01-2016) |
Groans: 63
Will do. Forgot I wrote this post
__________________ Blue Pu. "Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." | |
| The Following User Says Thank You to anavrinIV For This Useful Post: | Sleepin6 (01-01-2016) |
| The Official Turbo Manifold Thread | Inquisitive | Gen2 MS3 General Discussion | 41 | 10-02-2019 06:34 AM |
| OFFICIAL Warranty Extension Program on turbo and VVT Actuator Thread. | SPEED6 KILLAH | Mazdaspeed3/6 General Discussion | 528 | 09-24-2017 06:36 PM |
| The Official Turbo Manifold Thread | Inquisitive | MSF KB - Mazdaspeed 3/6 - Turbo Induction | 0 | 02-05-2015 10:50 PM |
| Ebay turbo: Direct bolt on GT28 knock off (not a newb thread) | cld12pk2go | MazdaSpeed 3/6 - Turbo Induction | 26 | 12-25-2009 08:23 AM |
