![]() Join Date: May 2013 Location: San Ramon, CA
Rep Power: 0 ![]() ![]() ![]() Thanks: 23
__________________ 2009 Mazdaspeed 3. ~ Autotech Internals ~ JBR RMM ~ JBR SRI/TIP ~ Forge V2 BOV ~ Cobb Access port V2 |
![]() Join Date: Jul 2012 Location: Tampa, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,432
| Not Ranked : 0 score You need 10wNew turbo.
__________________ '08 Speed3 - Cobb sri/cp-e rmm/18x8 RX-8 rims (DynoJet @ 254 whp/295 wtq) '99 Miata - Ground Control coilovers/Bilstein Sports/Racing Beat F&R sway bars/Go Miata strut tower brace/Jackson Racing header/MSM muffler/15x7 Kudo Racing wheels |
![]() Join Date: Aug 2012 Location: Hartland, WI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,583
Groans: 42
| Not Ranked : 0 score Dude, it should have taken you lesser time to search than to write an entire post. You're in the god damn right section and didn't see the sticky? |
![]() Join Date: Nov 2010 Location: South Haven, MI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,824
Groans: 75
| Not Ranked : 0 score Or PM Matt Damond and get a restrictor bolt
__________________ Franken Turbo, built motor, meth. DIY parts: Shift Knob, Shift Plate, Shift Bushings, Battery Tray, EBCS, RSB, probably more. "Your signature should just say, I'm the shit." -LynzeC |
![]() Join Date: Jan 2012 Location: Milwaukee, WI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 975
| Not Ranked : 0 score 5w-40 shell rotella t6. You will need higer idle and restrictor bolt. Going catless will kill those shit seals no matter what you do. Fucker.
__________________ Black Mica 2006 Speed6 GT | 62,000 Miles Cobb AP | Stratified Tune Stage 1 OTS | JBR Stage II Intake | cp-e 3'' Straight Exhaust | JBR RMM | SURE AGS 600 Gram Shift Knob | SURE Anchors | SURE Return | SURE SSP/Weight | All Redline Fluids | Shell T6 | Forge V1 ms6db.com I'm Registered. Are You? |
![]() Join Date: Jun 2009
| Not Ranked : 0 score Going catless did NOT kill my turbo seals. Now at 93,000 miles, all but the first 10,000 on catless 3" dp/rp. No turbo smoke. Ever. Can't generalize. Some smoke others don't. Seems to be no real rhyme or reason. I do have idle raised, always run synthetic oil, but no smoke even if I flash back to stock tune.
| Not Ranked : 0 score But I agree that T6 is the preferred oil. Period. OP: learn to search. Nothing here, move along.
| smoking turbo help | Jordanms3 | 2010 MS3 - Troubleshoot/Diagnostics | 10 | 01-07-2011 04:04 PM |
| ANOTHER Smoking Turbo... | div2 | MazdaSpeed 3/6 - Turbo Induction | 23 | 10-22-2008 07:27 PM |
