![]() Join Date: Feb 2011 Location: Somerset, PA
Rep Power: 145 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 70
Groaned at 3 Times in 1 Post
(Thread Starter) | Not Ranked : 0 score I also seafoamed my car and got a cel, I checked it with my DH. It was a misfire code which is understandable but I also got another one, something about a bad MAP sensor. I dont remember the code. I was seeing 15.x stock and now 17.x with HT. Seems to me the boost levels are correct and everything else seems to be fine so I dont know whats going on. Any ideas?
__________________ 2006 Mazdaspeed 6 - Velocity Red Mica - #5129 - Totaled 2006 Mazdaspeed 6 GT - Titanium Gray Metallic - #3820 |
| Not Ranked : 0 score if you dont write down the code its hard to help you. also 15.9 and 17.1 arent unusual for hotter/colder days. the ECU till target the boost it needs to hit a load target.
| Not Ranked : 0 score Its also usually the other way around, your boost gauge probably isnt correct.
![]() Join Date: May 2009 Location: Chicago, IL
Rep Power: 10249 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,116
Groans: 136
| Not Ranked : 0 score I got an intake temp DTC that told me my MAP sensor was bad. --- - Tapadatass
__________________ |
__________________ 2006 Mazdaspeed 6 - Velocity Red Mica - #5129 - Totaled 2006 Mazdaspeed 6 GT - Titanium Gray Metallic - #3820 | |
| What are the symptoms of your clutch going | long101 | Mazdaspeed3/6 General Discussion | 24 | 09-02-2012 12:43 PM |
| Sensor 1 low input(Knock sensor)? | SpeedKAF | MazdaSpeed 3/6 - Turbo Induction | 0 | 07-02-2011 10:30 AM |
| Failin VVT symptoms ? | jracer | Mazdaspeed3/6 General Discussion | 0 | 11-20-2010 12:25 PM |
| What are the symptoms of a Boost Leak? | Arrowpoint | MazdaSpeed 3/6 - Turbo Induction | 7 | 03-11-2009 09:26 PM |
| Symptoms of an exhaust leak? | Baseballpler | Mazdaspeed3/6 General Discussion | 10 | 01-19-2009 08:55 PM |
