 Old 09-06-2013, 06:26 PM   #1
MrShark's Avatar
Posts: 289   (View Stats)
MrShark is the leader of the worldMrShark is the leader of the worldMrShark is the leader of the worldMrShark is the leader of the worldMrShark is the leader of the worldMrShark is the leader of the worldMrShark is the leader of the worldMrShark is the leader of the worldMrShark is the leader of the worldMrShark is the leader of the worldMrShark is the leader of the world
Default Thoughts on my datalog?
This is a pull in 4th from ~45 to ~100
Corksport SRI/TIH
COBB AP 2+CS+TIH 93 V231
(internals are waiting to be installed later this month)
A: Throttle position maxes out at 77.22% even though it was floored?
B: My peak boost is less than the taper down boost in notes?
Is there a consensus on comparing maps? X mph in X gear and roll into it or stomp on it? I have a Cp-e TMIC on the way and am going to get a test pipe then get an e-tune but is there anything I can do in the meantime? Do I need a MAF calib or something?
2006 MS6 GT BCM
Cobb OTS - Corksport SRI/TIH/CAB -AT Internals -- JBR Boost Tubes - JBR RMM - Sure Shortcut - TWM Desert Eagle
A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster. - Jeremy Clarkson
MrShark is offline   Reply With Quote
 Old 09-06-2013, 06:35 PM   #2
[R]usty's Avatar
Posts: 2,204   (View Stats)
77 is floored.
Boost is variable by car. Could be +/- 2psi.
Logs look good. Car seems to be solid. Don't do anything else without internals.
2010 Mazdaspeed3 w/tech
Agent_Orange (09-06-2013), MrShark (09-06-2013)
 Old 09-06-2013, 06:50 PM   #3
Agent_Orange's Avatar
Posts: 3,575   (View Stats)
Groans: 665
As rusty said, log looks good. Fuel pressure is good, AFR's are solid, trims seem to be in order and zero knock.
You don't want to roll the throttle on for WOT logs, just start logging and stand on it. You may also want to add accel pedal pos. and Injector duty cycle to your logging parameters.
Internals are a MUST before you run that TMIC.
h0ckeyman (09-07-2013), MrShark (09-06-2013)
 Old 09-06-2013, 07:47 PM   #4
MrShark's Avatar
Thanks for the replies, I was definitely going to wait on installing the internals before tossing the intercooler on.
2006 MS6 GT BCM
New Log, Seeing Some KR. Thoughts? Sqc049 2010 MS3 - ECU Computer Tuning 7 04-28-2012 10:43 AM
Thoughts on these? rey_06 MazdaSpeed 3/6 - Wheels & Tires 13 03-28-2012 08:18 PM
thoughts (tsw) ispypsi MazdaSpeed 3/6 - Wheels & Tires 0 03-24-2009 10:51 PM
Page generated in 0.24892 seconds with 23 queries
