  • 1 Post By WetzMS3
 Old 05-11-2016, 07:41 AM   #1
Maxdaspeed6's Avatar
Posts: 14   (View Stats)
Maxdaspeed6 is an unknown quantity at this point
Default weird hollow whistling noise
Hey guys I wanted your opinion on something. I have a stock 2006 ms6 and when hitting ~3000rpm I can hear a weird hollow whistling sound that isn't any sound the BPV could make. I'm guessing some sort of boost leak because that's about the range where the turbo kicks in but I'd like to have you guys' opinion too!
Maxdaspeed6 is offline   Reply With Quote
 Old 05-11-2016, 07:44 AM   #2
Are you sure there isn't a bird under your hood?
simplycmplex likes this.
 Old 05-11-2016, 07:53 AM   #3
there WAS a bird almost exactly like that one! uncanny. but it's still doing the noise.
 Old 05-11-2016, 10:40 AM   #4
Jdab's Avatar
Posts: 52   (View Stats)
Jdab is a splendid one to beholdJdab is a splendid one to beholdJdab is a splendid one to beholdJdab is a splendid one to beholdJdab is a splendid one to beholdJdab is a splendid one to beholdJdab is a splendid one to behold
Easiest thing to do would be to re-tighten everything back to the turbo and see if it still does it. Baby steps.
Corksport Stage 2 Intake; Forge V2 BPV; Corksport Trifecta Mounts; Corksport Catback; Damond Motorsports Banjo Bolt; AP V3; Autotech HPFP; Stratified Tuned
ISC N1 Coilovers; RalyArmor Mudflaps; V-Limited S204 STI Lip; Gen 2 Wheels
Jdab is offline   Reply With Quote
 Old 05-11-2016, 10:42 AM   #5
I'm in the process of doing exactly that right now. I'll let you know if I still hear it when I'm done!
 Old 05-11-2016, 04:55 PM   #6
Aright I went for a drive and it still makes the noise. Took a video, don't know if you can make out the sound, it's pretty faint. Sounds like wind whistling by. Hope it helps!
 Old 05-11-2016, 05:13 PM   #7
Jdab's Avatar
Listened to it, can't really hear anything, what are your mods?
 Old 05-11-2016, 05:21 PM   #8
Can't blame you it's not blatantly noticeable even live. I'm all stock.
Also it only happens under load if that helps. I've looked around the forum and this doesn't seem to be a very common thing.
Last edited by Maxdaspeed6; 05-11-2016 at 05:21 PM. Reason: MSF Database - Automerged Doublepost
 Old 05-12-2016, 06:50 AM   #9
Thepedigree13's Avatar
Posts: 608   (View Stats)
Groans: 64
It is your butthole whisteling from the excitement of driving one of the best Mazdas ever made.
Check to see if the previous owner did any weird "mods" to the intake path.
~2013 BLACK MS3~
COBB: (APV3//Exhaust Hangers)
SofaKingAwesome (05-12-2016)
 Old 05-12-2016, 08:01 AM   #10
I unbolted and rebolted everything up to the turbo twice since the noise started. Everything there is perfectly normal and all the pieces are in good shape, no cracks or holes. Everything from the turbo to the engine looks normal though I never took it apart to inspect. Recently cleaned the EGR and TB but the noise dates from before that.
 Old 05-12-2016, 08:16 AM   #11
MD1032's Avatar
Posts: 2,624   (View Stats)
Groans: 143
Make a boost leak tester and use it.
2007 Mazdaspeed3 GT
WetzMS3 (05-12-2016)
 Old 05-12-2016, 08:19 AM   #12
yup that's what I'm doing next. I'll let you know what I find.
 Old 05-12-2016, 09:29 AM   #13
COCKSTRONG
SofaKingAwesome's Avatar
Posts: 8,447   (View Stats)
Groans: 890
+1 loose butthole whistling
kgb (05-12-2016)
weird f'n noise BMC Gen2 MS3 General Discussion 10 09-17-2014 07:02 PM
Weird noise... alex_speed13 MazdaSpeed 3 - Engine, Transmission & Driveline 0 01-31-2013 09:46 AM
weird noise babyjake Gen2 MS3 General Discussion 12 11-30-2011 10:55 PM
Weird noise Night Wolf MazdaSpeed 3/6 - Suspension & Brakes 3 04-15-2011 10:02 AM
Page generated in 0.33311 seconds with 26 queries
