Miata MX-5
> Miata - Forced Induction
Like Tree7Likes
 Old 01-27-2015, 11:40 AM   #41
Boostin'likeAboss's Avatar
Posts: 1,792   (View Stats)
I'm looking at mx-5's more and more everyday....
I just cant get over how badass it must be to have the same whp as my car, but weigh 1,000lbs less.
I really like the style of a white hard top NC, coupled with a FM SC kit....
but this NA is BAMF, everyone says the NA is the way to go and I enjoy turbo's more than SC's....
If you want to post more videos I'm sure no one would complain
08 cwp ms3
The Following User Says Thank You to Boostin'likeAboss For This Useful Post:
Tyhackman15 (01-27-2015)
 Old 01-27-2015, 01:08 PM   #42
Tyhackman15's Avatar
Posts: 1,742   (View Stats)
Tyhackman15 is the leader of the worldTyhackman15 is the leader of the worldTyhackman15 is the leader of the worldTyhackman15 is the leader of the worldTyhackman15 is the leader of the worldTyhackman15 is the leader of the worldTyhackman15 is the leader of the worldTyhackman15 is the leader of the worldTyhackman15 is the leader of the worldTyhackman15 is the leader of the worldTyhackman15 is the leader of the world
I'll have more videos and pictures to come once spring is here. Quite a few track days planned, and I'm sure I'll do the occasional auto-x in between.
SOLD 2008 MS3 17x8 Evo 9's, 235 v12
1995 Miata 1.8L w/ FMII GT2560R @11psi, FM stage 2 clutch/flywheel, FM Frame rail braces, FM high capacity radiator/fans, RB Sway bars, Racing beat exhaust, Fat cat Coilovers, Jongbloed 15x9, Wilwood 4 wheel BBK, Rollbar, Hardtop, TDR Racing seat
2001 Saab 9-3 Viggen 2.3T Stage 3+ bro, SRI, 3" DP, ETS FMIC, 17x8 BBS RK2's, Full chassis bracing / sway bars, Forge BPV, Winter/DD
Tyhackman15 is offline   Reply With Quote
The Following User Says Thank You to Tyhackman15 For This Useful Post:
Boostin'likeAboss (01-27-2015)
 Old 01-27-2015, 01:14 PM   #43
And I have some good comparison data for when I'm back at Blackhawk with my new tire setup. GPS data from last fall, best lap I managed was a 1:28.8. Novice group was a mistake, so much traffic.
 Old 02-08-2015, 06:47 PM   #44
Tire plans changed, one more year on street tires (probably a good thing since I'm a noob). Found some brand new 225 rivals on 6uls for a solid deal. Sadly they're 15x8s so they'll be getting street duty and the rivals will go on my 15x9 jongbloeds.
Comparison pic next to a normal tire to show the toy car status of a miata lol.
 Old 02-08-2015, 08:41 PM   #45
And to show that the number on the tire is irrelevant..lol. that's a 225 rival next to a 235 comp2, both on 8" wide wheels.
Code Monkey (02-08-2015)
 Old 02-12-2015, 01:18 PM   #46
Neverlift's Avatar
Posts: 4,699   (View Stats)
Groans: 1,143
I am not sure which is softer, my dick or your sidewalls after seeing that pic lol.
Past Mazdas & Speeds
Tyhackman15 (02-12-2015)
 Old 02-12-2015, 01:25 PM   #47
^ That's an easy guess.
Neverlift likes this.
 Old 02-12-2015, 01:39 PM   #48
Haha, well don't you worry. The tires will be on 9's before they ever see the road.
 Old 03-02-2015, 01:22 PM   #49
I need some opinions. If you could pick up a 110k 1.8l and 5 speed for $600, would you? It would be for nothing more than a backup in case of catastrophic failure.
Motor: ARP head studs, an OEM Mazda MLS headgasket, and had the head redone. The cylinder head was resurfaced, degreased, pressure checked, had a valve job, and had one valve replaced. Engine has approximately 110k on it. I also replaced the timing belt, water pump, and all top end gaskets, all done 7k miles ago
Trans has a freshly rebuilt shifter, stock clutch.
Thoughts? Good price?
 Old 03-02-2015, 01:27 PM   #50
Slap some 15x9's on it and 225 tires.
Quoted for lolz. Almost a year after you saying this...
File Type: jpg 11006374_10152700111063008_5065631857730511063_n.jpg (107.6 KB, 12 views)
Code Monkey (03-02-2015)
 Old 03-03-2015, 02:27 PM   #51
@Code Monkey;
@Neverlift;
@Spencer@CorkSport;
Thoughts? I'm not familiar with pricing on this kind of stuff..
 Old 03-03-2015, 03:27 PM   #52
If the guy has all the documentation and you can verify the engine is running and has good compression, it is a decent deal.
 Old 03-03-2015, 03:34 PM   #53
SpencerC's Avatar
Posts: 2,159   (View Stats)
@Code Monkey;
@Neverlift;
@Spencer@CorkSport;
Just the motor? Or the full car? Full car YES. Just motor and transmission... Worth it but not necessarily a killer price to just sit in the garage. AKA I'd say yes if I was doing a swap right now, I'd say no if it was just a backup.
Neverlift (03-03-2015), Tyhackman15 (03-03-2015)
 Old 03-03-2015, 04:38 PM   #54
Neverlift's Avatar
Groans: 1,143
I will second Spencer the Love Dispensers' response. It's not a great price, about what I would pay if I needed a 1.8 + trans right away.
SpencerC (03-03-2015), Tyhackman15 (03-03-2015)
 Old 03-03-2015, 06:22 PM   #55
Yeah that's just motor and Trans. No car. I'll see if I can talk the guy down to $500 or so. Otherwise I'll hold off. My motor should be healthy, only about 30k on it. Knock on wood
SpencerC (03-04-2015)
 Old 03-04-2015, 06:23 PM   #56
SpencerC's Avatar
Ya hold off. Or get a lower price. It really is up to you and the amount of extra mental safety knowing you have it sitting there. For me, that isn't as important. These engines are bullet proof though with a turbo it changes it a bit.
Tyhackman15 (03-04-2015)
 Old 04-06-2015, 08:20 AM   #57
225 on a 9 vs 205 on an 8. Much camber lol.
 Old 04-06-2015, 08:28 AM   #58
Neutral  +1 score
Can't wait to try these tires out. For now I'm stuck with the 205's until I can get the damn fenders rolled.
Oh and a big +1 to Flying Miata's kit. I didn't touch the car all winter, just kept a tender on the battery in my basement. Went out, threw a cap full of oil in each cylinder to help with the dry start, and she fired right up. Drove it home without issue. Can't beat that.
The Following 4 Users Say Thank You to Tyhackman15 For This Useful Post:
Chief_Wiggum (04-06-2015), Mauro_Penguin (07-02-2015), Neverlift (04-06-2015), Nliiitend1 (04-06-2015)
 Old 05-01-2015, 07:59 AM   #59
Half way through rolling the fenders for the 225 Rival / 9 combo. They will be going on their maiden voyage tomorrow (just street duty, but still excited).
These 205 neogen's are surprisingly grippy in a straight line with regard to wheel spin, not so much in the turns lol.
 Old 05-01-2015, 11:19 AM   #60
Neverlift's Avatar
Groans: 1,143
Neogens are a really communicative tire. You know exactly what they are doing at all times. Great budget tire, but only 300 treadwear iirc, so slip should be expected.
 Old 05-01-2015, 07:56 PM   #61
Test drive went great, no rubbing yet but I'm sure I'll find a way to. Absolutely love how aggressive it looks with 225s
The Following 2 Users Say Thank You to Tyhackman15 For This Useful Post:
Code Monkey (05-01-2015), Neverlift (05-01-2015)
 Old 05-03-2015, 05:32 AM   #62
With a passenger in the car on rough country roads, didn't rub once. Surprisingly easy to fit 225s on 9s. Loved the way it drove, can't wait to get them on the track.
Code Monkey (05-03-2015)
 Old 05-13-2015, 09:32 AM   #63
Well my stock coilpack is dying, screw spending $300 on a new one, time for LS2 coils. Wish me luck lol.
 Old 05-27-2015, 08:32 PM   #64
It was a good day. She fired up first try with these beastly coils.
Code Monkey (05-27-2015), mrmonk7663 (05-27-2015)
 Old 05-27-2015, 08:40 PM   #65
aaronc7's Avatar
Posts: 8,057   (View Stats)
Groans: 370
LS powahhhh
Tyhackman15 (05-28-2015)
 Old 05-27-2015, 10:27 PM   #66
mrmonk7663's Avatar
Posts: 2,997   (View Stats)
Do you have a part number list for what was needed for the LS coils and is it on stock ECU or MS?
2011 Speed3-BT and shit
TEAM LBN BEERS -- FYCN
TEAM MUMFORD -- FYCN
 Old 05-28-2015, 06:43 AM   #67
I run hydra, same process for MS3 though. All you need are the coils and some wire, here's how I set them up. Wasted spark just like factory, only adjustment are the dwell times. And your factory plug wires have to be crimped down to fit the LS studs.
mrmonk7663 (05-28-2015)
 Old 05-28-2015, 07:18 AM   #68
Gr8Speed's Avatar
Posts: 5,702   (View Stats)
I can't wait to have you riding my ass the whole way around the track this weekend lol
 Old 05-28-2015, 07:53 AM   #69
Get that pointer finger ready lol. But they're still calling for rain...so that blows
 Old 05-28-2015, 07:59 AM   #70
Gr8Speed's Avatar
I'll be like the dick in the RSX last weekend that wouldn't give me the point and instead was just overdriving the hell out of it and almost lost it multiple times.
 Old 06-01-2015, 06:39 AM   #71
Autobahn was a success, no good pics of the car yet. Only one close call, which @Gr8Speed; was riding along for lol. It was fun watching the corner guys force mustangs to give a miata the point by
Gr8Speed (06-01-2015)
 Old 06-01-2015, 06:58 AM   #72
Gr8Speed's Avatar
Photos up on the website already?
 Old 06-01-2015, 07:44 AM   #73
No they just have a small album on facebook right now.
 Old 06-30-2015, 08:28 PM   #74
Had another hpde at black hawk farms. Trimmed 2 seconds from last year. Still braking too early, the more seat time the better. Gotta have more confidence in these wilwoods.
Gr8Speed likes this.
Gr8Speed (07-01-2015), Micha (07-04-2015), Neverlift (07-01-2015), Nliiitend1 (07-01-2015)
 Old 07-01-2015, 08:49 AM   #75
Nliiitend1's Avatar
Posts: 5,749   (View Stats)
Blackhawk is a lot of fun. I haven't been there in years, but I've been itching to get back up there soon...
...maybe I will later this season - in an ND.
Stance is not a verb.
2008 MS3 GT
2016 MX-5 Club
Micha (07-04-2015), mrmonk7663 (07-01-2015), Tyhackman15 (07-01-2015)
 Old 07-07-2015, 11:03 AM   #76
Fancy Wilwood rotors are toast. As of right now the plan is to upgrade to an 11.75" kit (current is 11" rotor) and run good old fashioned (2 piece) blanks with the same dynalite calipers. Replacement cost will then be $50 a side vs $180 a side.
Code Monkey (07-09-2015), Nliiitend1 (07-07-2015)
 Old 07-09-2015, 06:46 AM   #77
On further inspection, rotors are still good but turns out it had wilwood E pads, not rated for anything over 1000 degrees or so, explains the heat issues. So I'm upgrading to 11.75 anyway and will be running dtc60s. 11" kit is already sold. Ducting seal at the front of the car will be improved as well.
 Old 07-16-2015, 10:22 AM   #78
Got some decent pictures from Blackhawk. The new 5.0's can go around a track, they are no joke.
Code Monkey (07-16-2015)
 Old 07-16-2015, 10:23 AM   #79
Gr8Speed's Avatar
Unless brandon is driving them
Tyhackman15 likes this.
HardHitter's Flyin Miata II Build Thread HardHitter Miata - Forced Induction 17 08-03-2013 09:37 AM
Flyin' Miata V8 Targa MX-5 Miata Haltech Automotive News 1 03-02-2013 06:31 AM
Flyin' Miata gets the documentary treatment Haltech Automotive News 0 08-10-2012 05:10 PM
Flyin' Miata at Targa Newfoundland, Part 4: Off to Gander Haltech Automotive News 2 09-15-2011 10:01 AM
Autoblog to compete in Targa Newfoundland with Flyin' Miata Haltech Automotive News 0 07-14-2011 05:40 PM
Page generated in 0.56447 seconds with 29 queries
