![]() Join Date: Dec 2015 Location: Minnesota
(Thread Starter) | Not Ranked : 0 score I'm pulling the turbo to fix the broken downpipe studs, so and it should be easy to do the downpipe while the turbo is removed. I'm trying to decide what to buy to either stay STX legal, or to switch to DSP, and therefore whether I need a cat or not. I mostly autocross my STR prepped Miata, so I'm not building the speed to be competitive. In my club, I run a PAX indexed class, so I can swap around cars and have that still count for the season standings. Or I can always just run the speed in a different club since it will not be competitive in STX or DSP. Right now I have 17x9 wheels with 245 RE-71rs, a rear swaybar, deresonated midpipe, intake, HPFP, and e40 tune. If I ran STX, I'd just run 93 with stock boost tables. If I ran DSP, I could keep everything the same, and additionally, just run no cats. I don't want to spend much money. I'd probably go for one of the nicer high flow catted downpipes if I could find one used, but I my budget is around $200. If I did keep a cat, I'm not sure whether the better way to go is to eliminate the upstream or downstream cat. What do you guys think about these options? I'm personally leaning towards option 4 or 5 with the ebay long downpipe.
![]() Join Date: Mar 2011
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 11
| Not Ranked : 0 score I've had a CP-e DP for a few years now and the core of the CAT failed after only a couple of years worth of track days. We cut it out and welded in a new one and that's just recently failed on me as well, to the point where the core has fallen down into the pipe and destroyed my rear O2 sensor. I am swapping that out to a Cobb DP once my new turbo arrives. I have no idea if it will last any better than the Cp-e one did but I guess my main point is, if you're gonna go cheap ebay shit, don't get a CAT. |
Was the cat you replaced a metal core or a ceramic core? And do you know the brand? Looks like the stock CP-e DP has a metal core cat. @Code Monkey, but wouldn't I still need an adapter from the stock K04 turbo discharge to attach a v-band flange? | |
| Not Ranked : 0 score Catted or catless, get a v-band DP and you will hopefully never have to deal again with broken DP to turbo studs.
| The Following User Says Thank You to Code Monkey For This Useful Post: | Pu Manchu (09-02-2017) |
| Not Ranked : 0 score Yes, but the adapter is really short so it is super easy to install it on the turbo as you have easier access to all the five studs, Mazdaspeed6 example here. Then you simply connect the rest of the DP via v-band.
![]() Join Date: Nov 2015 Location: nyc
Groaned at 64 Times in 26 Posts
| Not Ranked : 0 score Nice
__________________ TopFlightInc! NYC 2011 speed 3 GT daily driver Mods: big turbo , fuel internals , sure short shifter , forge BOV , FMIC , JBR motor mounts all around , BC coil overs , staggered advan wheels 18 x9.5 25+ offset front 18x 10.5 15+ offset rear , 3in catless down pipe , occ , Custom 3inch intake , Cobb strut bar ,Cobb v3 ,vtcs delete stock intake mani , |
![]() Join Date: May 2013 Location: CO
Rep Power: 2407 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,487
![]() Join Date: Aug 2013 Location: Ft Myers, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 34
Nice Sent while probably pooping
__________________ CS TIP/SRI CS RMM CS Sexy Steering Wheel CS Springs & Struts CS Shirt Throw Shifter CS Shifter Bushings CS TBE CS Boost Tubes CP-e TMIC HKS BOV in resirc DM Vented OCC DM TMM DM PMM DM SSP Autotech Internals Custom E33 Freaktune | |
| The Following User Says Thank You to Jonb82 For This Useful Post: | monkey.bones.007 (10-12-2017) |
| Recommendation | TheHitman | Drag Racing | 1 | 04-16-2011 12:13 AM |
| AP Map Recommendation | Tomas | MazdaSpeed 3/6 - ECU Computer Tuning | 15 | 04-19-2009 07:09 AM |
| new mod recommendation! | jlocurto | Mazdaspeed3/6 General Discussion | 29 | 09-23-2008 08:57 AM |
