MAZDASPEED Protegé
> MSP - Engine, Transmission & Driveline
 Old 03-08-2015, 07:44 PM   #1
TitaniumProtege1's Avatar
Posts: 1   (View Stats)
TitaniumProtege1 is an unknown quantity at this point
Default Lots of smoke
Ok so im new to the turbo game and bought an 03.5 msp for 2500 dude said it had a bad turbo and he bought a new one but it had to be installed so i installed it because the car was lacking power and smoking clouds of smoke on start up really light blue/white smoke so i did my research and found bad turbo seals so put in the slightly used 40k turbo the turbine had a little side to side movment but was told that was ok? after getting back together it still smokes clouds of smoke boost and vac is normal 6 p.s.i boost and 20-22hg vac why is it still msoking like tis could this one have a bad turbo seal as well the oil was change a week ago and coolant remains fine no milky oil so maybe valve guid seals idk but the smoking stops after it has warmed up and i drive it a little but its alot of smoke what do you guys think?
TitaniumProtege1 is offline   Reply With Quote
 Old 03-12-2015, 09:55 PM   #2
Illa Noize's Avatar
Posts: 122   (View Stats)
Illa Noize is a splendid one to beholdIlla Noize is a splendid one to beholdIlla Noize is a splendid one to beholdIlla Noize is a splendid one to beholdIlla Noize is a splendid one to beholdIlla Noize is a splendid one to beholdIlla Noize is a splendid one to beholdIlla Noize is a splendid one to behold
Check valve stem seals. Also check if there's oil residue in cold pipe. That is a significant sign that the turbo is going bad.
Illa Noize is offline   Reply With Quote
LOTS of white smoke and another question FatalSinz 2010 MS3 - Troubleshoot/Diagnostics 16 03-16-2015 02:55 PM
Issue with 09 ms3 - lots of smoke, barely revs sean00 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 7 03-19-2014 08:12 PM
Lots of smoke, possible bad turbo meelo88 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 7 02-28-2014 06:56 PM
Burning oil bad/ Lots of white smoke 2ndGenM$3 2010 MS3 - Troubleshoot/Diagnostics 44 05-21-2011 05:10 AM
Track day.. lots of black / dark smoke out of exhaust under acceleration Huligan MazdaSpeed 6 - Engine, Transmission & Driveline 8 12-23-2010 08:38 PM
Page generated in 0.22817 seconds with 21 queries
