MAZDASPEED Protegé
> MSP - General Lounge + New Member Welcome
 Old 04-17-2013, 04:02 PM   #1
Twinrotor's Avatar
Posts: 2   (View Stats)
Twinrotor is an unknown quantity at this point
Default New MSP Owner.
Converting from some other crappy forums full of idiots....
Less b/s more cars.
The MSP. Had a few additional holes in the block when I bought it.
Motor. Weisco pistons (thermal coated), K1 Long rods, precision 5252E with billet compressor wheel, Precision 650cc injectors, walboro pump, Perrin fuel rail, DocB oil pump and external regulator, stock flywheel, Comp Clutch stage 4, AEM FIC-6. Planning on having the motor finished and put in the car in the next few weeks. Then its onto wiring, and plumbing all the fuel/oil lines.
Current Daily is a '03 SVT Focus. Stock with the exception on no cats throttle body and a tune.
Tow pig is a '03 Gmc Yukon.
This is how it spends a lot of its time.
The Garage queen, 94 MX-3 with KLZE 5 speed swap.
And finally the departed 87 Rx7 that I built over about 5 years driving it everyday for 7 years. Finally took its own life in May of 2011. Last pass it made down the track was the fastest pass the car ever saw. Parted it out and sold everything to fund the MSP.
I think I broke it
Twinrotor is offline   Reply With Quote
 Old 04-17-2013, 04:07 PM   #2
Booosted2010's Avatar
Posts: 54   (View Stats)
Booosted2010 has a brilliant futureBooosted2010 has a brilliant futureBooosted2010 has a brilliant futureBooosted2010 has a brilliant futureBooosted2010 has a brilliant futureBooosted2010 has a brilliant futureBooosted2010 has a brilliant futureBooosted2010 has a brilliant futureBooosted2010 has a brilliant futureBooosted2010 has a brilliant futureBooosted2010 has a brilliant future
Groaned at 3 Times in 1 Post
Always loved the MSP, good luck with the build and welcome.
Booosted2010 is offline   Reply With Quote
 Old 04-17-2013, 04:33 PM   #3
jbmazda6's Avatar
Posts: 1,230   (View Stats)
jbmazda6 is the leader of the worldjbmazda6 is the leader of the worldjbmazda6 is the leader of the worldjbmazda6 is the leader of the worldjbmazda6 is the leader of the worldjbmazda6 is the leader of the worldjbmazda6 is the leader of the worldjbmazda6 is the leader of the worldjbmazda6 is the leader of the worldjbmazda6 is the leader of the worldjbmazda6 is the leader of the world
@Dcmason22;
I think you'll like this!
Looking forward to seeing more pics of the build
JBR: Whale Penis, SSP+Weight+Bushings+Knob, Boost Tubes, Bypass Valve Hose, TMM, PMM, RMM, OCC, TIG's, Small Battery Tray
Other: Stratified 3-Port EBCS, Stratified Guardian Angel, Cp-e Catted Downpipe, Cp-e Top Mount Intercooler, Cp-e Rear Diff Mount, Autotech Internals, H&R Coilovers
Sponsored By: JamesBaroneRacing.com
jbmazda6 is offline   Reply With Quote
 Old 04-17-2013, 04:36 PM   #4
Twinrotor's Avatar
Thanks, since it will be raining here tomorrow, I plan to spend some quality time with the blasting cabinet. motor is about 75% done. Things just take forever when you were not the one that took it apart.
Another pic from fitting the inter cooler.
Page generated in 0.26167 seconds with 22 queries
