 Old 11-24-2018, 02:18 PM   #1
mazda_speed_6's Avatar
Posts: 84   (View Stats)
mazda_speed_6 is just really nicemazda_speed_6 is just really nicemazda_speed_6 is just really nicemazda_speed_6 is just really nice
Neutral  +1 score
Default 17×9.25
Hey guys just wanted to share my rim tire set up and get some advice. Just picked up some 17×9.25 +36 offset any one have any advice on tire size I'm thinking 235 40 I wanted to run 245/45 17 but it looks like I'll have rubbing issues on the suspension side I'll be rolling the fender for sure. Just finished test fitting the rim and every thing cleared.
2006 MS6 sri/tbe/cpe diff mount/TS bpv/AT internals/jbr motor mounts/COBB acessport/stratified ots map/act 6 puck
mazda_speed_6 is offline   Reply With Quote
 Old 11-24-2018, 02:26 PM   #2
Clearance on the suspension side
 Old 11-24-2018, 03:59 PM   #3
MSF's Punishing Member
Pu Manchu's Avatar
Posts: 2,992   (View Stats)
Groans: 546
why
94 M
MS6
IS350
 Old 11-24-2018, 04:34 PM   #4
Why what?��
 Old 11-24-2018, 05:07 PM   #5
SSinstaller's Avatar
Posts: 3,989   (View Stats)
Groans: 60
Why bother with 9.5" wheels and then run a tire that will fit on an 8" wheel.
The Following User Says Thank You to SSinstaller For This Useful Post:
mazda_speed_6 (11-24-2018)
 Old 11-24-2018, 05:20 PM   #6
I got these for track use and wanted to run a 245 or 255.
But when I test fitted them they cleared every thing good no problems my fear is if I go with a 245 or 255 the tire will rub on the hub knuckle. So I came here to see if any one has any advice or runs the same rim specs?
 Old 11-24-2018, 05:53 PM   #7
Groans: 60
Your issue will be the rear fenders. My wheels are 18x8" +48 and even with a only a 1" drop and the fenders rolled I would rub occasionally with 235/40/18.
There are a few people running wide setups, but they're using fender flares.
 Old 11-24-2018, 06:15 PM   #8
O shit so I was worried about the wrong side it's the rear fenders that are gonna give me problems. I wonder since I'll be on a smaller rim if it'll give me a little more room to run 245? I saw a guy running 255 on 17×9 +48 offset with spacers on the front only I wonder how he got those to work.
 Old 11-25-2018, 10:49 AM   #9
Natey's Avatar
Posts: 536   (View Stats)
12mm = almost a half inch more poke, plus his wheels were narrower, so he had nearly an inch more room than you do.
The Following User Says Thank You to Natey For This Useful Post:
mazda_speed_6 (11-25-2018)
 Old 11-25-2018, 11:06 AM   #10
I didn't even snap about that my offset pushes my wheel out more flush with fender witch is the look I was going for. So if I wanna go wider than 235s I'm gonna need a good fender pull or fender flares.
Any one ever run a taller tire than a 40 series like a 45? Is a 45 tall tire to tall for are cars I saw on the ultimate will they fit thread that the most common was a 40 tall tire.
 Old 11-28-2018, 11:22 PM   #11
Pu Manchu's Avatar
Groans: 546
i thought most track guys build around a tire, not a wheel?
94 M
MS6
IS350
 Old 12-16-2018, 05:27 PM   #12
I was building around Hoosiers 245/45 17 but found a good deal on these wheels for black Friday figured they would work with just a fender roll but I was wrong
 Old 12-18-2018, 12:14 PM   #13
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,811   (View Stats)
I build around a penis.
cyclist20 (12-20-2018), Db09ms3 (12-18-2018)
 Old 12-18-2018, 12:22 PM   #14
If I use 235/40 do you think they would do good with just a roll or will I need to pull the fender as well trying to avoid pulling the fender but if I have i will
Last edited by mazda_speed_6; 12-18-2018 at 12:22 PM. Reason: MSF Database - Automerged Doublepost
 Old 12-18-2018, 01:48 PM   #15
Groans: 60
No. You need to get wheels that fit. IMO a 235 is too narrow for a 9.5" wheel, and even that will still have issues with a +36 offset.
 Old 08-21-2019, 08:42 PM   #16
Got my car aligned at big O and the alignment guy had never seen adjustable ball joints before so there main mechanic came to talk to me and wanted to charge me $90 a hour to adjust the ball joint and said it would take him a couple of hours to do it so I told them just fix the toe on the car. the camber settings are pretty even on all four tires my question is do you guys think these setting will kill my tires fast? I know the toe would of killed the tires quick but I really don't know the effect of camber I plan to take the car to another shop that specializes in race cars/lowered cars and won't give me problems about the SPC ball joints but for know I have to drive around like this
 Old 08-21-2019, 09:40 PM   #17
Groans: 60
Toe eats tires, the camber will be ok in the short term, but should be fixed. Hours to adjust balljoints is bullshit. If you have the standard SPCs the max range is only +1.5 deg which would be about perfect in the front.
Why didn't they fix your rear camber? The oem adjustment has enough range to get you back to spec from your starting point.
mazda_speed_6 (08-21-2019)
 Old 08-21-2019, 09:55 PM   #18
Right it took me about 1 and half hour to install them I'm sure they just saw it as a way to wax me for some cash. I didn't even waste my time arguing with them I could tell nothing was gonna make the guy admit it wouldnt take a couple of hours. Guaranteed I would of spent 300+ dollars for that alignment if I would of let him adjust it.
 Old 08-21-2019, 10:04 PM   #19
Groans: 60
Why didn't they fix your rear camber? The oem adjustment has enough range to get you back to spec from your starting point. They have to release the tension on the lateral link. Then adjust the cam bolts for the camber adjustment. Then set the toe with the lateral link.
 Old 08-22-2019, 06:48 AM   #20
I'm assuming they didn't know how, the alignment mechanic tells me were gonna pull your car off the rack it's done so I go inside to pay and the lady at the front desk tells me they couldn't make any adjustments to the rear because its a solid axle. At that point I said these people are fuckin stupid so I told her it's not a solid axle the sheet shows they fixed the toe, so I told her since you guys only fixed toe and didn't touch camber can I get some kind of discount they cut the price down 20 dallors.
Page generated in 0.38666 seconds with 24 queries
