| MazdaSpeed 3/6 - Wheels & Tires HaveMazdaSpeed 3 - Wheels & Tires - Have a question about wheels or tires? Need a calculator to figure out offsets? We have them in here |
(Thread Starter) | Not Ranked : 0 score I ordered two NT-01's to see if they will work for me. Does anyone have any experience with NT-01's on speed3's that are over 400hp? Im sick of asking people for 50-60 rolls... hahahaah running 18x8's with 235/40's. I know most of you will say wider tires/rims... but thats not an option right now. I would have radials and or slicks if I had the money.
__________________ Precision 6466, Golden Eagle Sleeves, Headgames Motorworks Head Fastest ET: 11.776 @ 123.161(35r setup, 7000ft DA, 450hp uncorrected) 3M Matte Blue Metallic Wrapped 860whp/677wtq 2016 Ford F150, XLT, 4x4 Supercrew 2.7 V6 Ecoboost |
| Bob Ross Fanclub ![]() Join Date: Jan 2009 Location: SEFL
Rep Power: 4333 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,534
| Not Ranked : 0 score The NT01s will work well when hot. When cold they won't be much different than the NT05s. Besides that, they're fairly expensive tires and won't last long at all. When wet, also get ready for some fun.
__________________ |
| The Following 4 Users Say Thank You to Tomas For This Useful Post: |
(Thread Starter) | Not Ranked : 0 score Thanks I don't drive the car in wet weather, so I wont have to worry about that haha. Guess ill be ding burnouts for roll races... haha I'm also thinking like 20-25psi. Ill experiment.
| Not Ranked : 0 score Yeah. Not really much you can do. Even if you had the NT05 drag radials you'd want to heat them up before a run. There is just only so much you can do with FWD. A multiple clutch plate type LSD such as the OS gicken LSD would do a better job but that's a lot of money. That's what I am doing once I get a new clutch and swap the tranny.
![]() Join Date: Dec 2011 Location: Irvine, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,122
Groaned at 22 Times in 12 Posts
| Not Ranked : 0 score Swap the tranny you say?
__________________ - - -2007 MS3 - Sold - -2015 BMW m235i - Painfully stock and incredibly comfortable. |
| Not Ranked : 0 score Yeah. It's one of my fav things to do.
![]() Join Date: Mar 2008 Location: Brea, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 103
| Not Ranked : 0 score OP - I also run NT-05's. Good summer tire but even I have traction issues at times running the K04 and you're BT so yeah, you need more sticky. Problem is at that 235/40/18 size and without looking at drag radials your stuck looking at road racing tires which are stickier than the NT-05's but don't have the sidewall flex that drag radials have. If I were in your position rather than spending over $200 per tire for the Nitto NT-01, get some cheaper sticky road race tires that will give you almost the same grip as the NT-01's but for half the price. Your going to burn through any tire you get in a season anyways so why not save the $100 per tire? 595 RS-R Racing - OnlineTires.com I know you can't compare treadwear ratings between different brands but it's interesting to look at what you get for the money: NT-01 for $210 ea @100UTOG vs the Federal 595 RS-R's are $121 ea @140 UTOG |
| The Following 4 Users Say Thank You to jv92red For This Useful Post: |
| Not Ranked : 0 score ^^ that's an interesting tire. Do you have any personal experience with them? Looks sort of similar to the RS3s from Hancook.
![]() Join Date: Mar 2011 Location: Bradenton, Florida
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 143
| Not Ranked : 0 score Suspension would be my biggest concern, tires will just cover up what the suspension lacks, the problem in FWD is weight transfer, all the weight shifts off the driving tires when you mat it, so until you get that under control especially in a high hp application like yours, you are going to have problems. Maybe run as stiff of a spring as possible in the rear? Or even helper bags in the rear springs? We had to do this in my firebird as well as put limiters on the front to stop the car from traveling upwards and instead make the inertia move forward sooner, it make like a 3/10ths difference just by limiting travel upwards. But experimentation is needed regardless on this platform, if eibach would make drag springs for the rear of this car that were solid, I'd bet we would have numerous 3's pushing 10's, tires are only 50% of the equation.
__________________ 2010 CBM Speed 3 (Daily) Muffler Delete Sure Aeros TRZ Poly RMM 14.11 @ 100 2.1 60' 1986 Firetird 350 Chevy (2 Bolt Main) Stock Bottom End Edelbrock E-tec 200 Heads (Port, Polish, Decked) JE Pistons Ford 9" Rear End 4.30 Gears Stock Suspension 11.29@113.8 mph, 1.54 60' |
| The Following User Says Thank You to IPuOnU For This Useful Post: | 09speedaddict (08-02-2012) |
| Not Ranked : 0 score I don't. Just the cheapest, stickiest tire I could find on the web in the 235/40/18 size the OP is running. Being in SoCal I would be fine running sticky tires year round but not enough tread life for me as I'm more of a cheap ass when it comes down to making compromises. My next set after my NT05's wear out soon will probably be the MAXXIS MA-Z1 Victra in the 235/40/18 size. Can get these for around $100 ea and should hopefully perform close to the NT-05's but at $50 cheaper per tire. Maxxis is a Taiwanese company who have been in the game for over 40 years. I may be cheap but I won't compramize on safety. I have found tires comparable to my NT-05's and these MAXXIS MA-Z1 Victra for below $90 ea but I gotta draw the line somewhere. |
| The Following User Says Thank You to jv92red For This Useful Post: | Tomas (08-02-2012) |
![]() Join Date: Feb 2009
Rep Power: 151849 ![]() Thanks: 55,993
Groans: 1,443
| Not Ranked : 0 score Ratings, reviews and specifications for Nitto NT-01 tires $195 each shipped from Discount Tire Direct. That's where I got mine. I had these in 245/45-17 and they still spun in 3rd, but not as violently. I had them at 20psi.
__________________ Evo VIII - 9.93 @ 150.05 - CAI and LEDs Beanfab / Tuned by Nishan |
| The Following 5 Users Say Thank You to doubleflusher For This Useful Post: | Bucker (08-03-2012), Dano (08-03-2012), Easter Bunny (01-28-2014), PapaSmurf (08-02-2012), SarcasticOne (08-02-2012) |
(Thread Starter) | Not Ranked : 0 score Thats were I bought mine, but had to stay with 235's since the 245's on 18's were $50 more a tire. They came in yesterday and im getting them mounting tomorrow. I am also at like 440whp uncorrect at this altitude... so im about 60-70whp less then you had... hopefully that will help me out.
![]() Join Date: Apr 2009 Location: Danbury, CT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,851
Groans: 58
I ran NT-01's last season for time trials and cold I was able to get them to spin some in second. I could only imagine what a BT MS3 would do. Once they had heat though they stuck. EDIT: For what it's worth, mine were still gripping well up until I corded them. | |
| The Following User Says Thank You to daafisch For This Useful Post: | Tomas (08-02-2012) |
| Not Ranked : 0 score ^ Would have been nice if he got to compare RS3s to NT01s. Especially on their ability to handle heat which for road racing is really the biggest factor on the MS3. I run the RS3s at -2.0 camber in the front at about 35 psi hot but on 9.5" rims and they hold up better than the NT05s I had before.
(Thread Starter) | Not Ranked : 0 score fuck I want those NT03+M's... haha what wheel size are those? 17x9.5?
| Not Ranked : 0 score yup. ET45
Groans: 58
(Thread Starter) | Not Ranked : 0 score How you fitting those fuckers? Just a nice roll and some small spacers up front? Sent from my flying tapadildo
![]() | | #19 | ![]() |
Rep Power: 10779 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,334
| Not Ranked : 0 score does anyone have any experience with the conti DW? im trying to figure out why i wanna spend 850+ dollars on the hooseirs that i cant even drive to the track on and will only use 4-5 times a year lol
![]() | | #20 | ![]() |
Groans: 1,443
| Not Ranked : 0 score The Continental DW's are a 340 TW. Not a very sticky tire. Even with AWD, you'll spin the shit out of these.
![]() | | #21 | ![]() |
the evo V12's are 280 and i could do a full 1st gear burnout for as long as i kept my foot on the pedal. at mason-dixon i was on the DWS's which are 540 and i was barely able to get them to spin. i had identical 60's of 1.71 and 1.72 respectively for both tires. from what i have been reading online the mustang/vette owners really like them for street tires and said they hook up decent so thats why i was asking.
__________________ 2006 Mazdaspeed 6 GT Black Mica #4126 KILLAH Built/SPEED PERF6RMANC3 (SP) 10.6:1 Pistons ~ SP 11mm H11 Head Studs ~ K1 rods ~ SP CNC Head Work ~ Crower 65lb Valve Springs ~ Fully Keyed/Pinned Motor ~ GTX35R w/Tial .82AR Hotside ~ JMF IM w/1000cc PI Injectors ~ SP 75mm TB ~ SP In-Tank FP w/Dual DW300's ~ AEM FPR ~ SP Custom PI Fuel kit ~ CPE 4" MAF ~ CPE SAFEseals ~ TR1035 FMIC ~ CPE Atmosphere DP/Ex Manifold/Oil/Water Lines ~ Tial MV-R EWG VTA'd ~ Denso ITV-24's ~ CPE Dual CBE ~ CPE BT TIP ~ CPE RMM ~ JBR TMM ~ JBR PMM ~ TTFMM ~ CPE RDM ~ Sonic Tuning CO's ~ LED Tails ~ Sonic Tuning HID's ~ Whiteline RSB ~ ACT 6 Puck w/unicorn dust First K04 in the 12's First MS6 in the 11's Certified RichTune E-Tuner | |
![]() | | #22 | ![]() |
| Master of Hard Parts ![]() Join Date: Sep 2011
Rep Power: 734 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 79
Groaned at 8 Times in 2 Posts
| Not Ranked : 0 score I've had the Conti DW mounted for about a year now. They handle very well and grip decently at the 400-415WHP range. However, anything more than this and they're going to slip like crazy. I'll enjoy these for another 10,000 miles or so. By that time, I'll have more fuel, better suspension, and will need some sticky sticky. In the end, I think they'e a pretty great daily driver tire for the money.
__________________ Hard Parts Engineer - Mazda Expert Group 2009 MS3 Sport - Built Motor//Twinscroll 35R//Everything Else - SOLD! 2008 Toyota Tacoma TRD Sport 4x4 - Current Daily Until Next Turbo Car |
![]() | | #23 | ![]() |
yea but you only have 2 wheelz lololz what size are yours?
| The Following User Says Thank You to superskaterxes For This Useful Post: | Evan@COBB (08-03-2012) |
![]() | | #24 | ![]() |
![]() Join Date: Jan 2012 Location: Central IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 19,219
Groans: 118
| Not Ranked : 0 score I dont have experiance with the DW, but i have the DWS on my car now. Granted i am not much over stock power levels. any kind of hard acceleration in 1st and 2nd with traction crontrol off is just a giant burnout. With traction control on 1st is still pretty worthless but 2nd i at least get decent forward motion, more of just a chripping than a straight up burnout.
__________________ Damond Built Speed 6 |
![]() | | #25 | ![]() |
![]() | | #26 | ![]() |
| Not Ranked : 0 score if money is no object.....I ran the Yoko Advan A048s and they are a sticky as fuck..TW of 65 BUT $308 each...lol They are DOT approved road racing rubber just a hare below R. I am on NT-05 now and meh they are fairly good but I can rip them lose at will 1-3rd. 4th holds good but not before I tapered my boost onset. Bringing boost on ASAP broke them lose in 4th on occasion. I am looking at running NT-01s in the front as their price point is between 05 and A048s. I like the looks of those R compound tires listed here as a $100 option.
![]() | | #27 | ![]() |
| Not Ranked : 0 score fuck, i guess i should just be glad i bought and MS6 and not an MS3 hahaha the hoosiers are $213 shipped and the conti DW like $125 so theres a significant price difference. my biggest constraint is weight, the contis are 20lbs, hoosiers 18lbs, and the next lightest DR (BFG/hankook/ect.) is like 23lbs. the wheels i just bought are 10 lbs lighter per corner then stock so im trying to be as critical as possible with weight (esp because the tire is the farthest out from the hub which will have the largest effect on unspung weight)
| The Following User Says Thank You to superskaterxes For This Useful Post: | Bucker (08-03-2012) |
![]() | | #28 | ![]() |
(Thread Starter) | Not Ranked : 0 score NT05's are fairly prices and I don't think u would have a problem with them on AWD. Sent from my flying tapadildo
![]() | | #29 | ![]() |
| Not Ranked : 0 score 5mm up front and monster roll in the rear.
![]() | | #30 | ![]() |
![]() Join Date: Oct 2012 Location: Long Beach, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 255
| Not Ranked : 0 score Thread from the dead. Bump on the nitto nt01's anyone daily driving these?
__________________ Bnr s3/Act 6 puck/sure full 3inch intake/cobb fmic/cobb downpipe/grimmspeed ebc/3 bar map/hks catback/autotech hpfp internals/turbosmart bpv/bc coilovers/jbr trilogy mounts/ngk one step colder plugs/ms6 rims on nt-01 tires. 24 psi E85 freektuned. Freektuned e85 Focus st as the daily. |
![]() | | #31 | ![]() |
![]() Join Date: Feb 2016 Location: McKinney, TX
Rep Power: 0 ![]() ![]() Thanks: 2
| Not Ranked : 0 score Here's a little teaser. Track day is Saturday, I'll post all my footage shortly after. Last edited by tgood3131; 03-21-2016 at 08:21 PM. |
| The Following User Says Thank You to tgood3131 For This Useful Post: | Jsn_Rob (03-22-2016) |
![]() | | #32 | ![]() |
![]() Join Date: Nov 2015 Location: Flint and Livonia MI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 30
| Not Ranked : 0 score Zombie thread? Auto X or road course?
__________________ 2007 MS3 True Red HKS BOV-K&N CAI-APV3-CS TMIC CS Short Throw-Whiteline Bushings-CS Rear Bar 1968 Mustang Built 289 w/ factory heads Built C4 Bulit 8" posi Runs low 14's at 100 flat |
![]() | | #33 | ![]() |
| Not Ranked : 0 score Road course, Eagle Canyon Raceway out in Denton. Got Corksports drop in turbo as well as TBE. Hoping the car will do well, we shall see.
__________________ 2006 Titanium Gray Metallic Mazdaspeed 6 #333 H&R Coilovers Whiteline Rear, Racing Beat Front Sway AWR End Links SPC Ball Joints Corksport Rear Brace Bar Corksport Skid Tray JBR TMM, PMM, CPE RMM CPE RDM, Sure FDM Stoptech Slotted Rotors Carbotech AX6 Pads Cobb BPV Cobb AP V3 JBR Tru 3.5 Intake ETS TMIC Bridgestone Potenza RE71 215/45/18 Cobb Pro-Tuned |
![]() | | #34 | ![]() |
| Not Ranked : 0 score Car did great but unfortunately the Nitto's didn't fit. I'm going to get the fenders rolled to see if that will allow it to work. The drop in turbo and turbo back exhaust though added WAY more hp than previous so I was overall really happy with how the car did. I'm going to post a separate thread for the track videos.
![]() | | #35 | ![]() |
![]() Join Date: Jun 2012 Location: Vancouver, BC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 155
| Not Ranked : 0 score Gonna bump this as search hasn't given me much. For those that have ran NT01 in autocross, what tire pressures do you recommend? I run 40psi on my Bridgestone S-04 and they don't roll over too much, I want to have a good ball park to work with without having to trial and error too much. Not enough runs and they are only counting first 3 runs for competition use.
__________________ 2009 CWP MS3 | JBR short shift plate, JBR shifter bushings, CP-e stage 2 RMM, JBR RSB, JBR Wide-Path, CS downpipe, UR catted test pipe, Cobb cat-back, Forge BPV V1, Swift Spec R springs, Bilstein B8, Whiteline KCA428 ALK, Whiteline Bumpsteer Correction, Corksport injector seals, Weds Sports SA55M 18x8 +48, Bridgestone S-04 245/40/18, BLOX Limited 490g shiftknob Dyno'ed at 277whp/290lb-ft on 91 piss |
![]() | | #36 | ![]() |
| Not Ranked : 0 score Finally got the fenders rolled and had my first track day with the NT-01's. Here is video to give you an idea of their handling capability. I apologize ahead of time for the shitty camera angle, didn't think the rear view mirror would take up as much space as it did. All of the mods are listed in the description of the YouTube video so you can find more information there about my setup. Only had one time where the car lost control, right around the 12 minute mark. Other than that these tires handled everything I threw at them.
__________________ 2006 Titanium Gray Metallic Mazdaspeed 6 #333 H&R Coilovers Whiteline Rear, Racing Beat Front Sway AWR End Links SPC Ball Joints Corksport Rear Brace Bar Corksport Skid Tray JBR TMM, PMM, CPE RMM CPE RDM, Sure FDM Stoptech Slotted Rotors Carbotech AX6 Pads Cobb BPV Cobb AP V3 JBR Tru 3.5 Intake ETS TMIC Bridgestone Potenza RE71 215/45/18 Cobb Pro-Tuned Last edited by MS3Shadow; 06-22-2016 at 05:22 PM. |
![]() | | #37 | ![]() |
| Not Ranked : 0 score what tire size are you running?
![]() | | #38 | ![]() |
| Not Ranked : 0 score 245/40/18
![]() | | #39 | ![]() |
| Not Ranked : 0 score Correct. Wheels: 18 x 8.5, 45 offset TSW Nurburgring Matte Gunmetal Tires: 245/40/18 Nitto NT-01 Alignment was about -2.2 rear and -1.9 front Also, if you ever run Nurburgring's at the track, make sure and take your center caps out before going. The heat completely warped the plastic inside the center cap and caused all four to come out during one session lol.
![]() | | #40 | ![]() |
![]() Join Date: May 2015 Location: Greensboro, NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2
Groaned at 19 Times in 6 Posts
| Not Ranked : 0 score best bang for your buck on traction in my opinion is firestone firehawk indy 500, the new style. they are rebranded re0003 from eu market. got some awesome reviews, decided to try them and i am not disappointed at all. i do not have the power you do nor do i track the car. may be worth at least taking a look at. price is also very good! tire rack is the cheapest i found.
__________________ 2012 Mica Black Speed3, 3" CS intake/TIP, CS MZR bypass valve, CS hpfp internals, CS 3 port EBCS full interupt, NGK 1 step colder plugs, Ebay catless DP, 2nd cat delete, resonator delete, Custom Magnaflow axle back, CS OCC, EGR delete, throttle body coolant bypass, CS 70 duro RMM, firehawk indy 500 225/40/18, DM SSP, rear adj control arms, 3.5" shift extender, MofiyStreet 450oz ball shift knob, Purple Drank Tuned 93 map/Purple Drank Tuned E30 map, 295/337 dyno jet heatsoaked at 150 BAT, 314/362 vdyno at 100 BAT |
| Reviews wanted for nt555r's and nt-01's | Boosted Beluga | MazdaSpeed 3/6 - Wheels & Tires | 75 | 04-29-2012 11:09 AM |
| Nitto NT-05 followed by more goodies... | AJ713 | MazdaSpeed 3/6 - Wheels & Tires | 33 | 06-23-2011 11:25 PM |
| nitto invo? | k0m | MazdaSpeed 3/6 - Wheels & Tires | 8 | 10-07-2009 12:24 AM |
| Nitto NT-05 | Nliiitend1 | MazdaSpeed 3/6 - Wheels & Tires | 38 | 09-10-2009 07:58 AM |
