| MazdaSpeed 3/6 - Wheels & Tires HaveMazdaSpeed 3 - Wheels & Tires - Have a question about wheels or tires? Need a calculator to figure out offsets? We have them in here |
![]() Join Date: Mar 2018
Rep Power: 0 ![]() Thanks: 0
(Thread Starter) | Not Ranked : 0 score Hey guys, Going to be picking up a set of Sparco Assetto Gara's (18x8, 45mm offset), just want to make sure, if i stick to 215 45 18 there wouldnt be any rub correct? (Using 100% stock suspension). Never changed wheels before but just want to make sure. Otherwise if there is a better different size tire i should run that would appreciated too! Just want to make sure there's no rub! EDIT: on a gen 1, stock suspension! Thanks! Last edited by arvint123; 04-01-2019 at 03:45 PM. |
![]() Join Date: Oct 2015 Location: Central Jerz
| Not Ranked : 0 score Theres a thread here all about fitment for wheels and tires. I dont have the link handy tho. I don't know what car this is all happening on but I would assume and say you will not rub. That wheel width and offset doesnt stray that far from stock. For an official answer, search for the thread.
__________________ 2010 MS3 - Tuned By Nishan Autotech Fuel Pump Internals OBX R Custom Exhaust Cobb SF Intake & TIH w. Blitz Filter CP-e TMIC Corksport Dual VTA BPV JBR 88 Duro RMM |
![]() Join Date: Feb 2012 Location: Li ny
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,290
Groans: 74
| Not Ranked : 0 score 215 on a 8 inch rim with a 45 aspect ratio? Any reason why the odd combo? Hope that question isnt much of a strechhhh.
__________________ MECP 2012 BM PTE 5858 Vband .82ar // Tial EWG // CPE Mani // 3" Turboback // JBR Under route hot pipe // MD ST mani+spacer with PI // Siemens 60lb Injectors // Splitsecond inj controller // JBR 88 duro RMM/TMM // MD PMM // TWM Full replacement shifter // JBR CC // Autotech FP Internals // SP63 SB/Manley rods SP63 pro pistons // Treadstone FMIC TR824 // FoMoCo Tranny Jizz // South Bend Clutch Stage 3 enduro// GFB Respons // FJ 4" intake // WMI 100% VPM1 // Air Lift 1000 in rear // N2MB WOT BOX Rfinkle tune in progress The Brooklyn beater: 2005 1.8 Auto Sentra |
(Thread Starter) | Not Ranked : 0 score Haha i get what you mean, pretty knew to tires and wheels did some searching and it sounds like 225/45/18 would be a safer choice haha. Just want to make sure there's no rub since i think the stock is 18x7.5 and this is a 18x8 and going from a 215 oem tire size to 225. |
(Thread Starter) | Not Ranked : 0 score Well went on to order them and they are out of stock and graphite grey is discontinued too so switching wheels, I did some reading and checking and want to triple check, https://www.americastire.com/buy-whe...unlite/p/13735 Would these fit on just fine? (using 225/45/18)...The only thing that bothers me is: Hub Bore Size :73 I know on the sticky it said ours is 67.1mm bore...would it still be ok? Assuming i can just buy hub centric rings if im really paranoid right? (Sorry, really new to wheels and fitment) been reading the sticky a bit and got a good amount out of it. |
Groans: 74
| Not Ranked : 0 score Listen man put down the credit card and spend a long time reading this. The Ultimate "Will They Fit" Thread - Everything you need to know about wheels, spacers and tires for your MS If you want to go full faggot mode look here. OFFICIAL AGGRESSIVE OFFSET THREAD
| New 18x8 Sparco Assetto Gara rims | swampthigger | Wheels & Tires - METRO GREY | 29 | 11-13-2017 09:03 AM |
| Awesome or retarded: Sparco Assetto ORANGE | eliminator | Wheels & Tires - COSMIC BLUE | 45 | 03-09-2013 01:01 PM |
| Sparco Assetto Gara Gold 18x8 +45 | BlckMs3 | Wheels & Tires - BLACK | 21 | 03-01-2013 06:53 PM |
| Green sparco assetto...will they fit? | DRITISDASHT | Wheels & Tires - BLACK | 10 | 02-16-2013 12:02 PM |
| Paris 2008: Fiat 500 Abarth Assetto Corse | Haltech | Automotive News | 0 | 10-05-2008 02:40 PM |
