| MazdaSpeed 3/6 - Wheels & Tires HaveMazdaSpeed 3 - Wheels & Tires - Have a question about wheels or tires? Need a calculator to figure out offsets? We have them in here |
(Thread Starter) | Neutral : +7 score This should work for the Gen2 guys too. I don't think your wheel fitment is much different than the Gen1. You Genpu fags are more than welcome to make your own wheel thread tho, if you're too gay to intermingle with us. As accepting as I am of aggressive stretching & the hellaflush scene, this is going to be the functional fitment thread, since MSF is 95+% hardcore function > form based. I DO NOT want to see any function vs form or hellaflush bashing/arguing or any shitting on people in this thread. Guys with stretching, aggressive offset/width wheels questions, there's already a thread for you. OFFICIAL AGGRESSIVE OFFSET THREAD. Its got lots of pics, and the guys in there will be more than happy to help you understand what you can "fit" and how much work it'll take. Myself included. The MS3 is a bit different in what you guys can fit than my MS6, but they're not too far off. I'm hoping to get lots of traffic from both MS3 & MS6 guys to help you with your fitment questions on your respective model. Hell, even your opinions on what looks good and doesn't. /intro. tl:dr Stock Wheel Specs Our bolt pattern is 5x114.3. Hub bore is 67.1mm. Since the Gen2 should fit similar to the Gen1 this applies to you guys too. ** Stock MS6 Wheels: 18x7 | +55mm offset | 23.5lbs ** Stock Gen1 MS3 Wheels: 18x7 | +52.5mm offset | ~24lbs ** Stock Gen2 MS3 Wheels: 18x7.5 | +52mm offset | 24.6lbs Use these for reference when using the following sites. Links from the Wheel Gods Before you ask ANY questions...you've GOT to check these sites out. They are from the wheel gods and were extremely helpful when I was trying to figure out what wheels & tires I wanted to go with. The first one was my favorite because it gives you a primitive overlay of your current setup and potential new setup. It's also the only site that lets you compare aggressive stretches. The other two are great references as well. WillTheyFit.com Wheel / Tire Size Comparer Wheel Offset Calculator Wheel/Fitment Terminology Offset - "The offset of a wheel is the distance from its hub mounting surface to the centerline of the wheel." - TireRack.com Camber - "Camber is the tilting of the wheels from the vertical when viewed from the front of the vehicle." - Wheel Camber Explained How to Read Tire Sizes Calculating tire Dimensions ![]() https://www.rimsntires.com/specspro.jsp Wheels Generally 8-8.5" wheels are accepted as mildly aggressive and a healthy size wheel for us. Whether you want to run 17s, 18, 19s, or bigger tho is on you. 16s are the smallest you can run with the factory brakes. Right around a +35 offset is accepted as a fairly aggressive yet acceptable offset for these cars. Should sit you close to flush with the fenders without going overboard. Remember the lower the offset the further from your strut/closer to your fender the wheel will be. Higher offset draws the wheel inside the well closer to the strut. You're going to need to break out a tape measure/ruler to see how much offset & width you're willing to run. Just for the record...zero and negative offsets are ridiculous. Even for the Aggressive Thread. Here's an awesome thread that's loaded with links on the effects of wheel sizes. You may enjoy some of these. They may even help you decide whether or not the wheels you're looking at are the best for you. Effects of Wheel Size/Weight on Vehicle Performance Tires The most common tire size run on MSF is probably 225/40 or 235/40 for aftermarket wheels. Some have run as wide as 255/40 with wheels wide enough for them. For stock wheels, 225s are ok. 235s are a bit wide for the 7" wide stockers but it has been done. There's plenty of wheel width/tire width charts online for you to see if a tire size is ok for your wheel. Fender rolling will likely be necessary for anything wider than 225/40. Especially if your car is lowered at all. But remember as @driver311 points out, once you start adding power, 225s and 235s just aren't going to get you any traction. At least for you MS3 guys. As for brands, that's a personal preference. Feel free to discuss your experiences with what you've run. How did they grip, corner? Perform in wet conditions? How long did they last? Did they rub? Etc. Spacers Some people simply want more of a flush look without having to buy a whole new set of wheels. Or they have a set of wheels in mind that they like, but they'll sit too close to the strut to run safely. Spacers are the answer for that. Lots of people - domestics, imports, trucks, even offroaders have taken advantage of spacers. For our cars, you want to get hubcentric spacers. This simply means the spacer centers itself on the hub rather than by the studs. Our hub bore is 67.1mm. There's 2 types of spacers to consider now. Both can be seen in the following pic. The thinner ones on the bottom are basic spacers - no studs in them. They can be purchased in virtually any width. You typically don't need to install extended studs for anything 5mm or less. Some say up to 8mm is fine, but imho that's pushing it. You want your lugnut to be firmly secure on your stud, and with an 8mm spacer, you may not get enough threading. For anything larger than 5mm (10-15m are common, up to 25mm or thicker) you will need to install extended studs. The ones on the top have studs built in them. These are typically 15mm or wider. This allows you to run a wide spacer without needing to install extended studs. You bolt this spacer on your hub, then trim your factory studs down with an angle grinder or some cut off tool. The studs can't stick out any further than the spacer or your wheel will not sit properly. Post up your pics with wheels and specs listed, lowered or not, if you rub and if you rolled fenders or not. Here is information pertaining to wider wheels and the amount of "poke" they will have compared to a stock setup Gen 1 18x8 et50 (14.7mm more poke than stock) 18x8.5 et45 (26.1mm more poke than stock) 18x9 et40 (37.4mm more poke than stock) 18x9.5 et33 (50.8mm more poke than stock) 17x8 et50 (14.7mm more poke than stock) 17x8.5 et45 (26.1mm more poke than stock) 17x9 et40 (37.4mm more poke than stock) 17x9.5 et33 (50.8mm more poke than stock) Speed6 18x8 et50 (14.7mm more poke than stock) 18x8.5 et45 (26.1mm more poke than stock) 18x9 et40 (37.4mm more poke than stock) 18x9.5 et33 (50.8mm more poke than stock) 17x8 et50 (14.7mm more poke than stock) 17x8.5 et45 (26.1mm more poke than stock) 17x9 et40 (37.4mm more poke than stock) 17x9.5 et33 (50.8mm more poke than stock) Edit: If you find any information you'd like added to the OP, or find any misinformation or grammatical errors be sure to "mention" me with said information.
__________________ 2010 black mica speed3 The go: Depo racing: downpipe (100 cell count), custom: FMIC. HTP: 3.5" intake, under route piping. JBR: shortshifter, RSB. Autotech: HPFP internals. Go fast bits: hybrid BPV, VMR: 18x8.5 V710s, Bridgestone: potenza re760 245/40/18, KW: v3 coilovers,SPC: camber arms, freektuned, Damond Motorsports: dual OCC, PMM, PCV plate, RMM, TMM, EGR delete, FoSt mani, Corksport: battery box(fuck this thing), injector seals, Cobb: EBCS, AP v3. AEM: methanol. Seibon: carbon fiber hood. UR: catback. Bosch: 3bar. BNR: s4, DNP: EWG manifold, Tial: 38mm mvs EWG. The show: 5% tint all around, 50% tint windshield, rally armor mudflaps, Sony XAV64BT touchscreen headunit, katskin leather interior, CPE relocation plate, Maisonvi weighted shift knob, Corksport hoodscoop, black housing headlights. Soon:built motor Last edited by Djohns; 02-04-2016 at 10:08 AM. |
| The Following 119 Users Say Thank You to Djohns For This Useful Post: | 2.3speed06 (09-15-2014), 2008MS3H (01-06-2012), :: Gusto :: (06-18-2013), ABQ Speed6 (02-10-2014), ak_spray (06-11-2012), anavrinIV (01-06-2012), Andrew (07-19-2016), apawk (08-20-2012), Apollo (09-01-2012), Archer92 (09-11-2013), aromig (07-04-2015), bmfms3 (02-02-2012), BobbleHead (07-28-2012), breakfstincluded (02-10-2012), Broxer (02-13-2012), burntRice (02-19-2012), captain slow (01-06-2012), Constantin (05-23-2012), Cujo (02-09-2013), dastpe (01-06-2012), david001wj (02-02-2014), dead-zone (09-13-2012), Dezine (05-17-2014), donjohnk (06-12-2013), doubleflusher (01-06-2012), Downmented (02-18-2013), Easter Bunny (06-09-2012), Ebdiggity (03-11-2014), Evan (07-15-2013), f-castrillo (05-17-2012), fcbrandon (04-17-2012), Fobio (04-06-2012), fueledbysean (02-27-2014), fywdyl (01-18-2012), galens47 (01-06-2012), Garrettcx (05-29-2018), Gitcherex (12-19-2015), GLORIFIEDBOZO (01-18-2012), GrayWolfX (12-05-2017), h4bs (02-27-2012), hartlch (01-31-2014), helmetface (02-22-2012), herzloglover (04-04-2015), hnda etr (02-13-2012), Ingle (02-25-2012), jack_hammer (03-10-2013), jax ms3gt (02-28-2015), Jellikit (07-15-2015), Jetech (05-09-2013), jgarmo (10-13-2015), Jlw75ck5 (05-06-2015), jmhinkle (04-02-2013), joefromkocomo (01-21-2020), jrsmith (04-21-2014), JTMS3 (01-18-2012), jtt (07-23-2012), Juyoung (12-07-2012), Kat Radical (12-30-2014), Kellerspeed3 (07-07-2016), kgb (11-01-2013), Khaos (01-17-2017), koms3 (11-15-2013), Krystorr (06-02-2019), kunfu (02-11-2012), lifeownedme (03-21-2012), mac_dre (01-06-2012), maisonvi (01-09-2012), MattJackson86 (01-18-2012), mazdaspeed619sd (05-15-2013), meelo88 (01-04-2013), meicalnissyen (02-26-2017), Menace1 (01-29-2013), Mistersix (07-06-2013), MS3-a(sore)ASS-rex (01-06-2012), Ms3_Miami (10-11-2012), MS6FL (02-12-2012), Muzzybud (12-09-2015), mzr0818 (01-06-2012), neotide87 (06-03-2012), NickyBIGBallz (06-10-2013), nighthawk358 (01-15-2012), NJsean0 (04-10-2017), NoRegrets (01-30-2012), nosnhoj1078 (03-11-2016), p057 (03-09-2012), PapaBruno (05-12-2015), paveltol (03-23-2012), phate (02-02-2012), pyrophelia (09-04-2013), Qwik6 (05-05-2012), Raider (02-21-2012), razortechrs (07-28-2014), rghispanic88 (02-02-2012), Rizz Nasty (08-05-2012), Rocker (04-21-2014), rolanblack (12-21-2012), rymanmazda (03-19-2014), sadak (04-29-2013), sarm1084 (06-30-2016), sbrunnings (09-23-2013), Schmitty5 (02-12-2012), Scoobs (05-07-2012), silentwolf8 (01-30-2012), SLOWHATCH (03-23-2012), soulitified (04-25-2017), spals (06-02-2013), speed6253 (06-22-2013), speed6qc (10-04-2014), speeding3 (08-21-2013), Stingray69 (02-26-2012), The Nut (05-31-2013), TheSki1974 (11-13-2014), twincitySPEED6 (09-11-2012), uncorked11 (01-06-2012), WAHBAM (01-15-2012), wankular (01-06-2012), WetzMS3 (01-14-2014), Willofalltrades (08-20-2012), ZetaDrift (03-22-2013) |
![]() Join Date: May 2008 Location: Brandon, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 667
Groaned at 7 Times in 4 Posts
| Neutral : -1 score To start off, here's some pics of how spacers look. Gen 1 MS3 Stock Wheels vs Stock + 15mm spacers | Eibach Pro-Kit - pics courtesy of @builthatch Before After MS6 Stock Wheels vs. Stock + 15mm spacers | H&R Springs - pics courtesy of @superskaterxes Before After MS6 18x8 +48 vs 18x8 +33 (effectively w/ 15mm spacer) - 235/40/18 tires | BC Coilovers (unfinished height adjustment lol) Before After
__________________ 2007 MS6 - broked & gone 2006 MS6 - less broked Last edited by RhoadBlock; 01-07-2012 at 05:53 PM. |
| The Following 19 Users Say Thank You to RhoadBlock For This Useful Post: | ak_spray (06-11-2012), Broxer (02-13-2012), captain slow (01-06-2012), Fail_6 (04-25-2014), fcbrandon (04-17-2012), fywdyl (01-18-2012), Juyoung (12-07-2012), kgb (02-24-2014), Menace1 (01-29-2013), Ms3_Miami (10-11-2012), neotide87 (01-14-2012), Nliiitend1 (01-06-2012), Notorious AMA (01-16-2014), SamiChicago (07-10-2015), sarm1084 (06-30-2016), SLOWHATCH (03-23-2012), speed6253 (07-06-2013), Takinato (05-22-2012), We Are Ninja (05-23-2015) |
![]() Join Date: Mar 2011 Location: Kenosha, WI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,298
Groaned at 6 Times in 3 Posts
| Not Ranked : 0 score typo: "As accepting as I am accepting as I am for the " possible typo: "The MS6 is a bit different in what you guys can fit than my MS6" did you mean 'the ms3'? also, if possible and i know it's a bit off topic, but maybe put the weight of the stock wheels up there for each platform/generation. Again, not really into the Will it Fit realm, but just a thought. Great start...and THANK YOU!
__________________ "Also you cannot do anything "like a boss" in a srt4. If you ever get a job where the boss drives a neon, go somewhere else. Apparently that job has no future." - themytb Oh you mean dogs. Yeah I like dogs. I drive a Hyundai. |
| The Following User Says Thank You to sick_role For This Useful Post: | RhoadBlock (01-06-2012) |
| Not Ranked : 0 score Good catch. I can only catch so many typos in my quick scan edit before I hit post lol. I'll add the wheels weights. They apply since everyone is always concerned with weights for new wheels anyway. I need someone to give them to me tho. I don't know them off the top of my head anymore. |
| The Following User Says Thank You to RhoadBlock For This Useful Post: | SLOWHATCH (03-23-2012) |
![]() Join Date: Jul 2008 Location: Tucson, AZ
Rep Power: 739 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 517
| Not Ranked : 0 score im currently running 17x9 TRMotorsport C3 as a track wheel, with Nitto NT05 255-40-17 tires, soon to be switching over to a Hankook .RS3. Theres a few NT05 threads floating around with my impressions.
__________________ JDMFresh.com 1990 Mazda Miata NASA Time Trials/Time Attack, Global Time Attack A miata may be gay, but its probably faster than your car around a track. That's pretty gay. |
| Not Ranked : 0 score Damnit, those were in stickies I unstuck... |
| Not Ranked : 0 score ^ lmao I know. I just tried to search for them too and can't find the damn thread again haha. |
| Not Ranked : 0 score GenPu is here: Stock 2010 MS3 wheel weight? |
![]() Join Date: May 2011 Location: Pooler, GA
Rep Power: 387 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 979
| Not Ranked : 0 score i thought Gen1 wheels were 18x8?
__________________ 2008 MS3: MAISONVI PISTON SHIFT KNOB - AUTOTECH INTERNALS SURE COUNTERSHIFT - SURE SHORTCUT - SURE ANCHORS JBR TRILOGY - JBR RSB - JBR TUBING - JBR TIP - JBR SRI - JBR EGR DELETE HYPNOTIC TUNED |
| Not Ranked : 0 score Here's @jroc's setup with a few pics for reference. Snagged this from another thread you posted in.
__________________ 2007 MS6 - broked & gone 2006 MS6 - less broked Last edited by RhoadBlock; 01-06-2012 at 12:24 PM. Reason: MSF Database - Automerged Doublepost | |
| The Following 3 Users Say Thank You to RhoadBlock For This Useful Post: |
![]() ![]() Join Date: Mar 2008 Location: Boise, Idaho
Rep Power: 1904 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 229
| Neutral : +3 score These are setups Ive used and my thoughts. My race wheels are 18x9 35 offset, front works with all the way up to 275/35/18 with the only mods needed to run being taking out inner fenders liners or doing some trimming. I took them our for races. Takes 5 minutes. Rear fit with 40 offset also but in order to get the tire to not rub with a 245/35/18 I had to roll the fenders and run -2.0 degrees of camber. A 45offset would have been more ideal. For the street Ive ran 18x8.5 45 offset with 5mm spacers and 255/35/18 all the way around. Rolled fenders and -2.0 camber was needed to clear. Fits great and looks hella tough. New street setup is 17x9 45 offset with 5mm spacers in front only and 255/40/17 rs-3 tires. Rolled fenders and -2.0 camber will probably be needed as well. I see so many people running 225-235 tires on these cars and then crying about traction. Of course you have no traction on skinny ass hard compound tires. These cars have the potential to run 255-275s in the front and 245-255 in the rear, if you get your wheel selection right. These cars make alot of torque with big displacement 4 cyl. and boost. If you take the time to find the right setup you can have a car that not only makes the power but puts it down. 18s look great on this car and thats what most will run. Get the right offset and go with a wider tire. 245/35/18 or 255/35/18 will allow you to go low, while delivering a much needed contact patch and in a softer compound will really put a smile on your face. This isnt a honda, and 225s just arent gonna work. I hope this tread and this comment helps in your decision making process. Save a few more bucks and do it right the first time. Good luck and happy modding. LOL
__________________ 2008 Mazdaspeed3, Fully built then fully parted. Sold 2007 ccsb Silverado, 3/5 drop Procharged, longtubes, 10psi Daily Mazdaspeed 12.5 @109 k04 stock ecu 18psi pump gas stock motor 311whp 11.7 @120 atp gtx3071r ap tuned 22psi 30/70 e85/pump stock motor. 422whp |
| The Following 32 Users Say Thank You to driver311 For This Useful Post: | anavrinIV (01-06-2012), AwAfrican (05-24-2016), bmfms3 (02-02-2012), breakfstincluded (02-10-2012), Constantin (05-23-2012), dsdblock12 (09-18-2018), Fjager (10-22-2014), GLORIFIEDBOZO (01-18-2012), helmetface (02-22-2012), htrdce69 (01-05-2014), Jellikit (07-15-2015), jroc (01-06-2012), JTMS3 (01-18-2012), MattJackson86 (01-18-2012), mride23 (04-04-2015), MS3-a(sore)ASS-rex (01-06-2012), Ms3_Miami (10-11-2012), mWindu (02-20-2013), NoRegrets (01-30-2012), RhoadBlock (01-06-2012), ricola (08-16-2017), sadak (04-29-2013), sarm1084 (06-30-2016), Scoobs (05-07-2012), SLOWHATCH (03-23-2012), SweetJP (01-14-2012), Todd98SE (10-26-2012), travis9935 (01-16-2012), uncorked11 (01-06-2012), wankular (01-06-2012), wayner (07-15-2014), Zbrit00x (01-20-2012) |
![]() Join Date: Feb 2011 Location: Oshkosh, WI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,456
Groans: 398
| Not Ranked : 0 score THANK YOU SOOO MUCH FOR THIS!!!!! I have absolutely no idea what the fuck is going on when it comes to wheels, and when I get to the point of upgrading I didn't wanna make a noob thread. Now I wont have to.
__________________ 2007 MS3 Silver. Intake bits, exhaust bits, FMIC bits, freektuned, loved, cherrished, SOLD!!! 2014 5.0 Gotta Have It Green w/Track Pack |
| The Following 3 Users Say Thank You to captain slow For This Useful Post: |
![]() Join Date: Feb 2011 Location: Rosemount, MN
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 189
--- I am here: http://maps.google.com/maps?ll=44.738526,-93.125995 -Jake
__________________ New: 2012 Mazda MX5 Miata True Red | |
| The Following User Says Thank You to Jake5713 For This Useful Post: | LastOfThePrimes (10-28-2013) |
![]() Join Date: May 2009 Location: Chicago, IL
Rep Power: 10249 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,116
Groans: 136
| Not Ranked : 0 score 16" steelies will fit on the MS3. For the winter I run 16x6.5 et42 steelies with 205/60R-16 tires.
__________________ |
| The Following 9 Users Say Thank You to silvapain For This Useful Post: | ak_spray (06-11-2012), breakfstincluded (02-10-2012), captain slow (01-07-2012), Easter Bunny (06-09-2012), Frank1 (12-12-2015), MS3-a(sore)ASS-rex (01-06-2012), RhoadBlock (01-07-2012), Rocker (11-12-2013), _MS3orDIE (12-01-2013) |
| Not Ranked : 0 score ill have some more pics with the rs3 setup (and without the tiger stripe vinyl) in about a week and a half as i have a track weekend next weekend. ill also take some side shot/ inner and outer clearance pics as well with as fresh as can be tires when i get the chance
![]() Join Date: Nov 2010 Location: York/Philly, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 777
| Not Ranked : 0 score i am running the overdone, but great looking, evo X wheels. 18x8.5 (+38) with a 5mm spacer in the rear +33 and a 3mm spacer in the front +35mm, with 235/40 on bc coils set at 17 in the front and 20 in the rear. rear fenders rolled flat with a small pull and rear bumper tabs dremeled. RARELY rubs with two people in the car. rubs over big bumps with four people. i LOVE how it handles the corners. |
| The Following User Says Thank You to dastpe For This Useful Post: | rey_06 (06-13-2013) |
![]() Join Date: Mar 2008 Location: Chicago
Rep Power: 4020 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,876
| Not Ranked : 0 score You thought wrong. They are indeed 18"x7".
__________________ Stance is not a verb. 2008 MS3 GT 2016 MX-5 Club |
| The Following 3 Users Say Thank You to Nliiitend1 For This Useful Post: |
| I have candy in my van ![]() Join Date: Apr 2009 Location: Chicago, IL
Rep Power: 2810 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,091
Groans: 70
| Not Ranked : 0 score I'm glad I still have @Nliiitend1 fender roller. Gonna roll the fenders on the Mazda5 tonight.
__________________ Current Fail: 2008 Mazda5 DD/Mazdaspeed5 BT project |
| The Following 3 Users Say Thank You to MATT DAMOND For This Useful Post: |
![]() | | #19 | ![]() |
| Bob Ross Fanclub ![]() Join Date: Jan 2009 Location: SEFL
Rep Power: 4333 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,534
| Not Ranked : 0 score 17x9.5 et 44 to 50 I would say are the best rims for this car. For tires I would go 265 wide if the selection in 17" for this width was better. This is my set up. 17x9.5 et44 with 5mm spacers in the front. 12mm spacers still fits. 255x40x17 RS3
| The Following 4 Users Say Thank You to Tomas For This Useful Post: |
![]() | | #20 | ![]() |
| Not Ranked : 0 score well thank you for correcting me
| The Following User Says Thank You to 2008MS3H For This Useful Post: | Nliiitend1 (01-06-2012) |
![]() | | #21 | ![]() |
| Not Ranked : 0 score enkeis?
![]() | | #22 | ![]() |
| Not Ranked : 0 score Nt03+m
| The Following User Says Thank You to Tomas For This Useful Post: | sarm1084 (06-30-2016) |
![]() | | #23 | ![]() |
| Not Ranked : 0 score fyi i was on H&R springs at the time
![]() | | #24 | ![]() |
![]() Join Date: Nov 2010 Location: Murrieta, CA
Rep Power: 1393 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,136
| Not Ranked : 0 score I am looking at getting the XXR 527's in 18x8.75 with either a +20 or +35 offset. I would like to run a wider tire than what I have now (215/40/r18). I am willing to have the fenders rolled but i would prefer not to. Will these fit well and if so which offset should I choose? Edit: Also I am lowered some on the corksport lowering springs.
__________________ 2009 CWP Speed3 |
| The Following User Says Thank You to SleeperHatch For This Useful Post: | breakfstincluded (02-10-2012) |
![]() | | #25 | ![]() |
| The Following User Says Thank You to dastpe For This Useful Post: | Nliiitend1 (01-07-2012) |
![]() | | #26 | ![]() |
![]() Join Date: May 2011 Location: Fort Collins, CO
Rep Power: 0 ![]() ![]() ![]() Thanks: 23
Groaned at 17 Times in 4 Posts
Thanks for the informative post - it's convinced me to go beyond 225s and to do it right the first time.
__________________ '08 Speed3, '06 Murano, '95 S14 SR20DET Last edited by G-Man; 01-08-2012 at 11:06 AM. Reason: added info | |
| The Following User Says Thank You to G-Man For This Useful Post: | sarm1084 (06-30-2016) |
![]() | | #27 | ![]() |
__________________ 2008 Mazdaspeed3, Fully built then fully parted. Sold 2007 ccsb Silverado, 3/5 drop Procharged, longtubes, 10psi Daily Mazdaspeed 12.5 @109 k04 stock ecu 18psi pump gas stock motor 311whp 11.7 @120 atp gtx3071r ap tuned 22psi 30/70 e85/pump stock motor. 422whp | |
| The Following User Says Thank You to driver311 For This Useful Post: | sarm1084 (06-30-2016) |
![]() | | #28 | ![]() |
| Not Ranked : 0 score Very nice dude. Jealous. My new wheels and tires will be here tuesday. Ill post pics of them installed with the new "vinyl work". I went with the same exact tire for the street as you. 255/40/17 rs3. couldnt beat the 130 price a tire and I need sticky rubber very bad. LOL How bad does your setup rub in the rear? I assume thats why you are any lower? Looks soo good either way man. Much props.
| The Following User Says Thank You to driver311 For This Useful Post: | Tomas (01-18-2012) |
![]() | | #29 | ![]() |
![]() Join Date: Jun 2011 Location: Wilmington, Delaware
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 612
Groaned at 25 Times in 10 Posts
| Not Ranked : 0 score Great sticky much needed
__________________ If your not first your last. ![]() 03 Speed Protege.. SOLD 10 Speed3 BT and getting my DRANK on!!! |
![]() | | #30 | ![]() |
| Not Ranked : 0 score Fuck Im having the hardest time getting my 255/40/17 rs3 to not hit my coilover perch. i might have to grind it down. I tried a 5mm spacer first then a 1/4 and still hits. I have a 8mm being made and Ill kill someone if it doesnt fit. I think 10mm is gonna be to much. That puts it at a 35mm offset and Ill have to run mad camber to clear. Right now I have it set at 2.2 and hoping thats enough with the 8mm. Damn I should have went with the 245/40/17. Same contact patch 9.1 but almost a half inch less section width. They would have been spot on with 5mm spacers. Damn.
![]() | | #31 | ![]() |
Sent from my Epic Win Avatar
__________________ 2009 CWP Speed3 | |
| The Following User Says Thank You to SleeperHatch For This Useful Post: | Ms3_Miami (10-11-2012) |
![]() | | #32 | ![]() |
| Neutral : -1 score
![]() | | #33 | ![]() |
![]() Join Date: Jun 2011 Location: sufu
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 58
Groaned at 41 Times in 24 Posts
![]() Sent from AT&T Inspire 4G using Tapatalk.
__________________ HT programmer, Mazdaspeed CAI, Turbosmart Dual port Bpv, Corksport Test pipe back exhaust, HTP TIP, Autotech CDFP internals, CP-E TMIC, Cobb Springs, Koni yellow struts, SU RMM, Ts shift plate, prosport bg, 10k headlights, 3k fogs, OZ Ultraleggera HLTs, Pioneer nav/dcs......On the way; Devils Own Stage 2 | |
![]() | | #34 | ![]() |
| Not Ranked : 0 score So I have 18X8 OZ ultraleggas with a ET48, what's the widest I can run? I really want 245 or 255's but not sure if they will fit in there. I am at stock height now for winter but have Cobb 1" lowering springs, and koni yellow struts. My 225/40's just don't cut it! Sent from AT&T Inspire 4G using Tapatalk.
| The Following User Says Thank You to travis9935 For This Useful Post: | 247carguy (09-14-2015) |
![]() | | #35 | ![]() |
| Not Ranked : 0 score I've been thinking of going 255/35-18 on 18x8.5 ET 40 with no drop in ride height (because daily driver, high curbs, etc). Other than a roll/some camber, any potential issues with this setup?
![]() | | #36 | ![]() |
Ps. Why no drop. Atleast do a 1in drop like some eibach pro kit. Car will look much better. Shit even just the front lol
![]() | | #37 | ![]() |
| Not Ranked : 0 score I already have to back in to the driveway as it is, if I pull in forward, I have to cut an extreme angle (basically park directly next to the curb then turn in immediately) or it tries to rip the front of my car off. Backing in barely clears the rear.
![]() | | #38 | ![]() |
I don't rub in the rear at all. I tell you what esse, had to roll those fuckers a ton. Unfortunately it's also noticeable since the fenders started to bulge at the edge. But fuck it. Because race car. Oh and I also had to cut some of the lip of the rear bumper. That's not noticeable however.
I can run these tires on the 9.5" width rims with ET44 with a 12mm spacer = ET32 and still clear the fenders in the front. And this with only -1.8 camber. I think you'll be fine with 10mm spacers and -2.2 camber!
__________________ | ||
![]() | | #39 | ![]() |
![]() | | #40 | ![]() |
| Currently Active Users Viewing This Thread: 2 (0 members and 2 guests) | |
| Weight of OEM 18" wheels/tires on 2010 MS3 | Driver72 | 2010 MS3 - Wheels & Tires | 19 | 11-14-2009 09:43 AM |
| Lutz lays out his strategy for GM advertising: "Memorable," "clever," "viral" [w/VIDEO] | Haltech | Automotive News | 0 | 08-04-2009 09:40 AM |
| Saudi government bans "lewd" personalized license plates including: "SEX," "ASS," and "USA" | Haltech | Automotive News | 0 | 04-14-2009 01:40 PM |
| Separate "Appearance" from "Wheels/Tires" | KaiserSoze | Website Help/Feedback | 1 | 04-21-2008 08:33 PM |
