| MazdaSpeed 3 - How-To's MazdaSpeed 3 - How-To's - Want help out fellow owners? Post How-To's to simplify future installations for others. |
![]() | | #81 | ![]() |
![]() Join Date: Mar 2019 Location: South Mississippi
Rep Power: 0 ![]() ![]() ![]() Thanks: 3
![]() | | #82 | ![]() |
![]() Join Date: Apr 2019 Location: SW Idaho
Rep Power: 13 ![]() ![]() ![]() Thanks: 9
| Not Ranked : 0 score Not quite. You'll need to remove the shaft from the old plate kit and install it in the new one.
__________________ 2009 Mazdaspeed 3 GT almost stock |
![]() | | #83 | ![]() |
| Not Ranked : 0 score Ok, the shaft you're referring to is not the big, long piece deep in the transmission is it? The write up has us removing a bolt and pulling something big out. Trying to avoid that. |
![]() | | #84 | ![]() |
The complete kit comes with a new bearing, installed, so you don't need to remove and install a new bearing in the existing part. It also comes with a new breather that you'll need to drive in, and a new rubber bonnet. You'll still need to pull the complete assembly with shift shaft, remove the indexing bolt, drive out the pin to remove the shaft, then re-assemble with the new parts.
__________________ 2009 Mazdaspeed 3 GT almost stock | |
![]() | | #85 | ![]() |
![]() | | #86 | ![]() |
![]() Join Date: Nov 2010 Location: Stormville, NY
Rep Power: 1415 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,027
Groans: 155
| Not Ranked : 0 score This job looks worse than it is. If you can work a ratchet and a hammer, you're golden. Got it done in under 2 hours with a tea break. @dynobunny, thank you so much for such a detailed post. I owe you a beer for sure.
__________________ Want to win a v3 Cobb Access Port? Enter the raffle and help a good cause. http://www.mazdaspeedforum.org/forum/forum/f510/cobb-accessport-v3-raffle-good-cause-190013/ |
![]() | | #87 | ![]() |
![]() Join Date: May 2015
Rep Power: 0 ![]() Thanks: 0
I also managed to break that little clip, it was just so old and crumbly. I couldn't find anything on just the plastic clip so I think I'll have to replace the whole selector arm ![]() Found it for 100 plus shipping from TascaParts: A6011772ZB | |
![]() | | #88 | ![]() |
![]() Join Date: Aug 2019
| Not Ranked : 0 score I’m not certain this was how this was supposed to go. I tried to unstick the gasket on the plate with a chisel, but just managed to bend the chisel pretty good. Do I need a better one, or have I misinterpreted the directions? Thanks! |
![]() | | #89 | ![]() |
![]() Join Date: May 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2
| Not Ranked : 0 score I did this repair along time ago but I sure dont remember needing to use any force to remove anything. Be careful. |
![]() | | #90 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 550
| Not Ranked : 0 score Try getting a rubber mallet and whack the side of the plate. That worked for me.
__________________ Stockish |
![]() | | #91 | ![]() |
![]() Join Date: May 2012 Location: Greensboro NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 751
Groans: 27
| Not Ranked : 0 score the metal of that chisel is too soft. im going to leave the rest of the comments to myself. a screwdriver or the punch you are going to use later on would be a much better choice to insert in to get the pivot shaft assembly out.
__________________ 06 VRM Speed 6 W/Navi 05 Mazda Family Truckster FREEKTUNED\\Cobb AP\\Autotech Internals\\Eibach Pro Springs\\Sure SRI+TIP\\Street Unit TP\\CPE RMM\AWR 88 Duro TMM\\Forge V1\\JBR Shortcut\\JBR SSB\\CPE & Sure Rear Diff Mounts\\Unicorn Blood (Rotella T6) twitter.com/djern instagram.com/djern facebook.com/djern |
![]() | | #92 | ![]() |
![]() Join Date: Jun 2009 Location: Los Angeles Area, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
| Not Ranked : 0 score I saw this thread and made a video of the process start to finish. Like others have said here, the job is about two hours. The video shows every painful detail and is just over an hour long. https://www.youtube.com/watch?v=vdFXj7mo0cE |
| The Following User Says Thank You to cost0305 For This Useful Post: | manu (02-15-2020) |
![]() | | #93 | ![]() |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f33/how-mazdaspeed-3-pivot-shaft-seal-bearing-184322/ | ||||
| MS6 shifter seized in neutral? - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum | This thread | Pingback | 10-16-2015 06:45 AM | |
| shaft pivot seal replaced - Page 2 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum | This thread | Refback | 06-18-2015 05:28 PM | |
| How-to: MS3 Pivot Shaft Seal, Bearing, Breather Replacement | This thread | Refback | 04-04-2015 02:38 PM | |
| HOW-TO: shaft pivot seal replaced | jrzy ms6 | MazdaSpeed 6 - How-To's | 287 | 08-18-2018 07:47 PM |
| MS3 Shaft Pivot Seal Replacement | jmen73 | MazdaSpeed 3 - How-To's | 9 | 06-22-2015 11:19 PM |
| Shifter Pivot/Seal Fix? | Gru_Nuts | MazdaSpeed 6 - How-To's | 8 | 11-08-2014 12:03 PM |
| Shaft Pivot Seal replacement urgency? | KSUWildcatFan | MazdaSpeed 3 - Engine, Transmission & Driveline | 19 | 06-23-2014 08:09 AM |
| Shaft pivot seal useless tip | paveltol | MazdaSpeed 6 - Engine, Transmission & Driveline | 1 | 07-11-2012 03:48 PM |
