![]() Join Date: May 2010 Location: SLC, Utah
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 15
| Not Ranked : 0 score 10w40 is fine - not optimal but fine. If you're in a cooler climate I would change to 5w30 now but if you are in a warmer climate I would just wait for the next oil service to change. My bet is the dealer put in 0w20 - oil that the CX-5 uses. Dealers are't the smartest (oddly enough) when it comes to our MZR-DISI engines.
| Display Modes | |
| First proper log. | Slash | 2010 MS3 - ECU Computer Tuning | 20 | 04-21-2013 05:29 PM |
| Is this the proper part that I need? | Caligula | MazdaSpeed 6 - Engine, Transmission & Driveline | 3 | 08-17-2012 05:49 PM |
| Proper wastegate? | TheNewGuy | MazdaSpeed 3/6 - Turbo Induction | 8 | 11-08-2010 07:08 AM |
| What is proper AFR for MS3? | Matrix311 | MazdaSpeed 3/6 - ECU Computer Tuning | 13 | 12-08-2008 10:06 AM |
