![]() Join Date: Nov 2010 Location: Denver, CO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 365
(Thread Starter) | Not Ranked : 0 score I have a CS TMIC and I was thinking about getting the optional shroud. I heard a rumor that it doesn't fit good. I have been trying to find pics of it install and can't find any. Would someone be able to enlighten me? Possible pics would be nice. I want a custom look.
__________________ 2010 MS3 Velocity Red w/ Tech Package Custom FreekTune e85 mix Future Mods DO stage 2 WMI, Intake manifold of some type. |
![]() Join Date: Apr 2011 Location: Weston, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,511
Groans: 39
| Not Ranked : 0 score No point, the cs allows you to reuse your stock plastic IC cover which seals to the hood scoop.
__________________ 2011 MS3 / Fully Bolted / 290whp - 320wtrq ~ Sold 2010 Accord Coupe EX-L V6 ~ Current ~ K&N SRI / 4300k HIDs |
| The Following User Says Thank You to G26 For This Useful Post: | Bucker (09-05-2011) |
(Thread Starter) | Not Ranked : 0 score I have that setup now and was looking for a more custom look. I would like to show off my TMIC and make it not look so stock at shows.
Groans: 39
| Not Ranked : 0 score Gotcha
(Thread Starter) | Not Ranked : 0 score it's not a make of break. I will stick with the stock if I have to. I just like the bling. I notice that you have the CS front strut bar. Did you notice a difference and did you get it power coated or polished? I'm on the fence with this mod too.
__________________ 2010 MS3 Velocity Red w/ Tech Package Custom FreekTune e85 mix Future Mods DO stage 2 WMI, Intake manifold of some type. Last edited by stang9779; 09-04-2011 at 10:17 PM. Reason: MSF Database - Automerged Doublepost |
Groans: 39
Heres a pic
__________________ 2011 MS3 / Fully Bolted / 290whp - 320wtrq ~ Sold 2010 Accord Coupe EX-L V6 ~ Current ~ K&N SRI / 4300k HIDs | |
(Thread Starter) | Not Ranked : 0 score I read some where that you can have them powder coat it gloss black of flat black. It's a special order plus $50.00.
![]() Join Date: May 2010 Location: Colorado Springs, CO 80915
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 921
| Not Ranked : 0 score Below is a pic of mine at a car show...As for the shroud, yeah def a waste of the money for me since i still use the stock plastic shroud. IMO don't waste the extra $ to get one.
__________________ 2010 Mazdaspeed 3 - Built Motor - GTX3071: SOLD 2012 Jeep Wrangler Unlimited Sport: Current DD |
(Thread Starter) | Not Ranked : 0 score why don't you use it? is there a fitment issue?
| Not Ranked : 0 score no fitment issue that i know of...i kinda just bought it and then once i installed it, i didnt want to use the shroud because i wanted more of that stock look. Its more of a personal preference. From what i can recall there shouldnt be any fitment issues. When i bought mine it came with the hardware to install the shroud. If you want, tomorrow ill bolt it all up real quick and give you a def answer on if theres fitment issues or not and include some pics.
__________________ 2010 MS3 Velocity Red w/ Tech Package Custom FreekTune e85 mix Future Mods DO stage 2 WMI, Intake manifold of some type. | |
| Not Ranked : 0 score black powder coated
(Thread Starter) | Not Ranked : 0 score cool that's the one I'm thinking about. I can't wait for the pics. thx I noticed that you live in CO too. I'm in Denver about 15 minutes from DIA.
| 5.000000yeah ![]() Join Date: Nov 2009 Location: Philadelphia Pa
Rep Power: 1773 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,249
Groans: 44
Groaned at 30 Times in 18 Posts
__________________ 2012 MUSTANG 5.0 // BBK X_PIPE//FLOWMASTER HUSHPOWER //3.73 REAR//SVE DRIFTS//JLT OIL SEPARATOR//BMR LCAS//J+M PANHARD BAR//STEEDA PANHARD BRACE//AIR RAID//BAMA//CAT DELETES// LOUD AS HELL ![]() |
(Thread Starter) | Not Ranked : 0 score Sent from my SCH-I510 using Tapatalk
Groans: 44
| Not Ranked : 0 score You can see the rub marks from the rubber gasket on the front half of the shroud. I don't think it touches on the rear half, and I honestly don't think it matters.
(Thread Starter) | Not Ranked : 0 score I would of really liked it if they made it go over to the drivers side more. This would of covered up the wires and other stuff up like the stock one does. I wish I could fab up on and get it powder coated.
![]() | | #19 | ![]() |
![]() Join Date: Feb 2011 Location: Germany
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 29
| Not Ranked : 0 score I modified my CS Shroud because it didn´t fit. If i put it under the notch on the backside of the TMIC, the 2 holes on the front didn´t lined up correct. It was to short. So i built a custom clamp on the backside of the shroud like on the oem part. Now the CS shroud sits directly on top of the TMIC notch and is sealing perfect in front and back!! Also its now correct leveled with the TMIC. Before this mod, the Sealing of the Hood was only touching the TMIC on the backside but not the Shroud. If you look from the side at the Shroud, you can see that its to deep on the backside. Thats the reason why it can´t touch the shround. Thats not good! The only problem i see, is that the aluminum shroud is rubbing more than stock part because of its brushed surface. The OEM Sealing rubber is wearing faster. You can see small rubber parts on the shroud and if you touch the rubber, you cant slide your finger over it as easy as before. It look like there is a special coating on the rubber, so that it slides better. This coating is now rubbed away on some parts of the sealing :-( This was the reason why i changed back to stock cover. But i liked the CS one much more. |
![]() | | #20 | ![]() |
![]() | | #21 | ![]() |
| Not Ranked : 0 score Just ordered one of these.
![]() | | #22 | ![]() |
![]() Join Date: Jan 2012 Location: darlington, md
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 494
| The Following User Says Thank You to Ryguy For This Useful Post: | dale_gribble (02-22-2013) |
![]() | | #23 | ![]() |
| Not Ranked : 0 score but since im here image-1176725117.jpg |
| The Following 3 Users Say Thank You to Ryguy For This Useful Post: |
![]() | | #24 | ![]() |
![]() Join Date: Oct 2017
| Not Ranked : 0 score Sorry for resurrecting the dead. ![]() I have the TMIC from Corksport but since i want to use another strut tower brace i can't use the OEM-Cover anymore. So i tried to get the optional aluminium shroud - but it isn't produced anymore. ![]() Does somebody have the corksport aluminium shroud and can take some measurements for me so that i can lasercut one myself? Picture 1 shows my setup now. Picture 2 shows the measurements i need (A to J) Many thanks in advance. |
| CP-e TMIC Shroud clearance | qwerty4550 | MazdaSpeed 3/6 - Turbo Induction | 29 | 12-19-2011 10:28 PM |
| Anyone cut their own shroud for TMIC? | WorstEpEver | MazdaSpeed 3 - Engine, Transmission & Driveline | 14 | 11-15-2011 02:50 PM |
| Genwo's: Sent your CP-e TMIC to get the shroud | bertrand_CX_7 | 2010 MS3 - Turbo Induction | 3 | 09-15-2011 08:22 PM |
| TMIC Shroud | DONWORK | 2010 MS3 - Turbo Induction | 30 | 08-20-2011 02:12 PM |
| ETS TMIC, to shroud, or not to shroud? | steven88 | MazdaSpeed 3/6 - Turbo Induction | 0 | 09-12-2008 11:08 PM |
