![]() Join Date: Aug 2011
Rep Power: 0 ![]() ![]() ![]() Thanks: 2
(Thread Starter) | Not Ranked : 0 score We both are running CS Intake/ CS TIP/ 2nd cat delete/ 3" exhaust from down pipe back. 2011 ms3(me) and 2012 ms3(friend) Only thing different was i have AP and he didnt. Soon there entails my quest for mo POWAA and learning how to tune this fun little car on the weekends. First couple of logs just lil changes. |
(Thread Starter) | Not Ranked : 0 score Started to move more things around Fueling tables, WGDCS, Load Cal , AFR, everything following Alibors guide and help from jason from this forums. These are the next logs trying to smooth out the graph some and actually tune to hit my boost targets. |
(Thread Starter) | Not Ranked : 0 score Final logs with actually almost hitting my boost targets and trying to smooth graph out best i could. I believe these are where im going to leave it not much kr really to worry about and no maxed out wgdcs like the ots maps like to run high. The only thing i dont know much about is how to tune timing to improve power. So thats the last thing on my agenda. I was trying to target about 16.5 PSI tapering down to 16.0 bye redline. I have above mods listed and trying to keep stock fuel pump in check. 11.8 AFR pretty solid. I am always looking to improve as I am addicted to tuning now and well continue to do so crosses fingers with things improving so far. Please let me know where do go from here thanks. |
![]() Join Date: Jun 2011 Location: Nashville, Tn
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 90
| Not Ranked : 0 score Forgot the donate mod... Get that done and you'll see the whiz kids start coming in here. That is when the learning really starts.
__________________ Cobb AP on a stage 2+ tune, Cobb SF SRI, Cobb TIP, CNT racing DP, KMD internals, KW V2 coilovers, JBR SSP, JBR shifter bushings, JBR chrome-moly RMM, JBR heavy shift knob, JBR PMM, Exonic in-dash TV, PowerBass 10", SoundStream Picasso 550w amp 18x8.5 +38 Work Emotions on order. Hold on a second, I just gotta check my "fuck you" map. |
| The Following User Says NO Thank You to Mac21 For This Un-useful Post: | CCC (11-09-2011) |
![]() Join Date: Jun 2010 Location: Wichita, KS
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 40,628
Groans: 386
| Not Ranked : 0 score Why not up the boost to 18 psi? That is plenty safe and you have tons of wgdc left to play with. Should net you some decent gains as well. |
| The Following User Says Thank You to wolly6973 For This Useful Post: | rfinkle2 (11-09-2011) |
![]() Join Date: Apr 2011
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 470
Groans: 131
Groaned at 30 Times in 9 Posts
| Not Ranked : 0 score I think because he doesn't have an upgraded CDFP.
__________________ JBR SSP - JBR RMM - AP Stage 1 91 OTS |
![]() Join Date: May 2009 Location: Chicago, IL
Rep Power: 10249 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,116
Groans: 136
| Not Ranked : 0 score He can keep upping boost until he starts to see fuel pressure drop. I believe GenPu's have been able to hit 18PSI or so on the stock pump like I did on my GenJuan. Tapadatass
__________________ |
![]() Join Date: Apr 2010 Location: Charlotte, NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 492
| Not Ranked : 0 score I was running 18psi on my stock pump but it was only for a few months. It kept up pretty good, just depends on how shitty his pump is
__________________ 2010 super smiley Red MS3 - Corksport SRI/TIP - ETS TMIC - CNT hiflow catted long DP - Sure boost tubes - SURE motorsports anchors - SU RMM - Greddy Type S BPV - KMD HPFP Internals - harryclay tune - Semi-flat black wheels (painted stockers) - Eibach pro springs ftw - Michelin Pilot Super Sports 235/40/18 - Yellow 55v fogs 13.69 @ 106 (4g eth mix, intake/tune) 13.67 @106 (intake,dp,tmic, 50/50 eth) |
![]() Join Date: Mar 2010 Location: Manassas, VA
Rep Power: 2313 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,791
Groans: 35
| Not Ranked : 0 score Looking good so far bro...keep up the good work and turn up that boost.
__________________ CP-e Atmosphere GTX3076r w1.06 Tial | JMF IM | NATOR D.C. FMIC | JBR Wide Path | Autotech Internals | HKS SSQV2 | Ebay DP | Denso ITV24 | CP-e RDM | AutoExe Strut Tower Bar | Whiteline RSB | Sonic Tuning Coils | DSS Driver Side Axle | JMF OCC BT - 395 awhp 345 awtq @ Moore Automotive 4/12/2014 on 93 octane Stock Turbo - 331 awhp 397 awtq @ Moore Automotive 11/10/2012 on ~e48 12.263 @ 111.75 mph 1.669 60' 11/17/2012 |
(Thread Starter) | Not Ranked : 0 score Wow thanks guys for the all the replys, I really love how this community helps out it fellows in training. I guess ill shoot for 17 psi now to redline and see what i come up with on that. If its still okay ill do 18 max because i cant get internals till december. Btw, did 2 more logs today just to keep checking. Well this friday i guess i going to be doing some more fun in ATR its really addicting. I will keep you guys posted on new results just to see how much this stock HPFP will hold btw i have only 4400 miles on my car and im driving it like i stole this bad boy. I used to be a car mechanic for 6 years before this and i loved my 98 LS1 camaro built from block up sold it to go college and now i have my first turbo car so im very conservative as not to blow up my Daily Driver. I will make the 17 psi prolly the weekend tune ^^ for saturday nights. If anyone lives in katy,tx or houston area and want to meet up we are rolling about 4 mazdaspeed 3s deep so more the merrier. Thanks all (slap)---> time to get to work. |
Groans: 386
| Not Ranked : 0 score A good way to show your thanks for the support is to donate to help keep our community running. |
| The Following 4 Users Say Thank You to wolly6973 For This Useful Post: |
![]() Join Date: Apr 2010 Location: Miami FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,836
Groans: 263
| Not Ranked : 0 score looking good. the power gains are never enough. youll always want more
__________________ 2010 Black Mica 2004 EVO 8 Green Monster The "7up" |
Groans: 35
| Not Ranked : 0 score If you want your turbo to last taper the boost down to 16.5 by 6500 rpm. Otherwise the little k04 will be out of it's efficiency range.
Groans: 136
![]() Run it to 21 PSI I say. Tapadatass
__________________ | |
| The Following User Says Thank You to silvapain For This Useful Post: | wolly6973 (11-10-2011) |
(Thread Starter) | Not Ranked : 0 score More logs with 17 psi targeted with taper to 16.50 to 6500. Pretty good imo fuel pump still hanging in there. 2 3rd gear logs and 1 4th gear pull its so hard to find a open road to 4th gear runs. |
Groans: 35
| Not Ranked : 0 score Start bumping your timing up 1* at a time and lean out your AFRs
Groans: 60
| Not Ranked : 0 score If you want your k04 to live, leave your boost at 17psi. Start bumping timing one degree at a time until you see consistant kr at the same load/rpm, and then back it down 1~2 degrees...
| The Following User Says Thank You to SSinstaller For This Useful Post: | wolly6973 (11-16-2011) |
(Thread Starter) | Not Ranked : 0 score Okay going to try tackling timing next and look for a good guide on where to tune timing. I'm not sure where to start in rpm band maybe 3000? On up or I should probably do every 500 rpm incriments first? Going to search these forums to find a guide thanks again for the great info. |
![]() | | #19 | ![]() |
![]() Join Date: Nov 2011
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 263
| Not Ranked : 0 score My fuel pump is garbage im running 16 psi and when I was doing my 3rd gear logs it was barley hanging on. |
![]() | | #20 | ![]() |
Groans: 60
Look at the graph as your making adjustments, it'll be easier to judge the relationship to the adjacent cells.. Timing transitions from cell to cell should be smooth, with an increase to redline, you don't want the timing jumping around as you transition between load points/rpm.. If you don't have an EGT to monitor temps in normal driving don't touch the closed loop timing... This is my OL no KR timing table, the reason for the dip in the last row is the table peaks at 2.0 load.. I routinely see >3.0 load in colder temps, so I have to drop the timing sharply to compensate. Your's will NOT look the same, my motor is far different than your's...do not try to copy this table...
__________________ Fully Built : Arias Pistons: Pauter Rods : ARP bolts: Ported Head: Cosworth BSD : Spec 3+ Clutch : Fidanza Flywheel : AWR Engine mounts 90duro : Custom TIP/Intake : Custom Blow Through 3.5" MAF : Custom FMIC : HKS SSQV VTA : Ported IM : Custom DP : Custom Exhaust : CPBoost Top Mount EM : Garrett GT3582R : PTP Turbo Blanket: Tial V44 EWG : Perrin EBCS : MrLilGuy/PTP HPFP : Ported fuel line : Ported Fuel Rail : Custom Ported Fuel Injectors : Kenny Bell Boost-a-Pump : HKS Twin Power DLI II : HKS M-Series Plugs : Cobb AP : AEM 3.5bar MAP :Koni Sport shocks : RPM Kspec Springs : TWM STS : TT Front Diff Mount : CPE Upper Diff Mount : Whiteline RSB : AWR Endlinks | |
![]() | | #21 | ![]() |
Groans: 35
| Not Ranked : 0 score damn... you smoothed out your timing table like crazy.
![]() | | #22 | ![]() |
![]() Join Date: Apr 2011 Location: Weston, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,511
Groans: 39
| Not Ranked : 0 score Yeah I want to get mine that smooth
__________________ 2011 MS3 / Fully Bolted / 290whp - 320wtrq ~ Sold 2010 Accord Coupe EX-L V6 ~ Current ~ K&N SRI / 4300k HIDs |
| COBB Tuning AccessPORT Update Features Boost Tuning, Faster Datalogging and LC/FFS | Cobb Tuning | MazdaSpeed 3/6 - ECU Computer Tuning | 177 | 12-03-2011 12:53 PM |
| My last 2 days | FightaX | Street Racing Stories ( Bench Racing ) | 14 | 09-28-2011 09:30 AM |
| COBB Tuning AccessPORT Update Features Boost Tuning, Faster Datalogging and LC/FFS | Cobb Tuning | Cobb Tuning | 1 | 08-31-2011 07:43 PM |
| COBB Tuning AccessPORT Update Features Boost Tuning, Faster Datalogging and LC/FFS | Cobb Tuning | 2010 MS3 - ECU Computer Tuning | 0 | 08-31-2011 07:32 PM |
