 Old 03-23-2012, 03:28 PM   #1
CornBread's Avatar
Posts: 170   (View Stats)
CornBread has a reputation beyond reputeCornBread has a reputation beyond reputeCornBread has a reputation beyond reputeCornBread has a reputation beyond reputeCornBread has a reputation beyond reputeCornBread has a reputation beyond reputeCornBread has a reputation beyond reputeCornBread has a reputation beyond reputeCornBread has a reputation beyond reputeCornBread has a reputation beyond reputeCornBread has a reputation beyond repute
Default cobb AP stage 1 tune question
okay i am confused. i just got my AP and cobb loaded the stage 1 tune for stock intake on 2012. why is everyone running the satge 0 tune if cobb is saying the stage 1 is good and safe for the 2012 speed3
also what needs to be in a log to get good feedback from forum and be useful
CornBread is offline   Reply With Quote
 Old 03-23-2012, 03:32 PM   #2
Pseud0logik's Avatar
Posts: 2,042   (View Stats)
Pseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the world
Groaned at 34 Times in 31 Posts
No clue. You are doing it right. Stage 0 is the equivalent to the stock tune. Just keep an eye on your fuel pressure, any dips below 1600psi and you need internals.
All of the default values are fine for the logs, you'll want to add MAF voltage for MAF logs.
Pseud0logik is offline   Reply With Quote
The Following User Says Thank You to Pseud0logik For This Useful Post:
jimmy (03-23-2012)
 Old 03-23-2012, 04:16 PM   #3
helmetface's Avatar
Posts: 5,685   (View Stats)
Groans: 219
lol....1600? Read the COBB manual and even that is on the safer side sometimes..
 Old 03-23-2012, 04:28 PM   #4
I'm pretty sure the Gen2s take a shit if their pressure drops below 1500psi at WOT, thus the 1600psi minimum recommendation which allows a little headroom.
 Old 03-23-2012, 04:36 PM   #5
helmetface's Avatar
Groans: 219
Ahhhh Gen 2 *doh* just replace it off the lot if you plan on modding . lol
 Old 03-23-2012, 04:13 PM   #6
bigriver's Avatar
Posts: 1,123   (View Stats)
bigriver is the leader of the worldbigriver is the leader of the worldbigriver is the leader of the worldbigriver is the leader of the worldbigriver is the leader of the worldbigriver is the leader of the worldbigriver is the leader of the worldbigriver is the leader of the worldbigriver is the leader of the worldbigriver is the leader of the worldbigriver is the leader of the world
3rd gear wot log is good. Find straight, flat and clean road. I use a freeway on ramp. Turn dsc and ac off. Set AP rev warning to 6500 rpm. In third gear around 2500 rpm start logging, wait a couple of seconds then stomp on pedal to floor (throttle position at 75-76%). Then when AP blinks when you hit 6500 let off gas and shift gears as normal. Prolly to 6th since you be going about 80 mph. Turn logging off. But honestly I wouldnt go wot much until you get fp internals.
Use standard item list for the log and save as excel file.
2012 mazdaspeed 3, black mica w/ tech package, AFE drop in dry filter, Autotech internals and CS rmm inserts. .
bigriver is offline   Reply With Quote
Stage 1 OTS tune help/question captain slow MazdaSpeed 3/6 - ECU Computer Tuning 3 03-06-2012 07:39 PM
What are the requirements for Cobb ap stage 1 tune? caesura 2010 MS3 - ECU Computer Tuning 3 01-23-2012 08:32 PM
Quick Question about Stage 1 vs Stage 2 Roguevice 2010 MS3 - ECU Computer Tuning 11 07-16-2011 01:58 PM
AP stage 1 tune Vs stock + TIP/SRI? Ex_WRX_driver Gen2 MS3 General Discussion 12 05-24-2011 05:27 PM
need tune after TurboXS Stage 1 kit? solar MazdaSpeed 3/6 - ECU Computer Tuning 6 03-17-2011 10:12 PM
Page generated in 0.27465 seconds with 23 queries
