 Old 08-13-2017, 12:28 PM   #1
noah26's Avatar
Posts: 10   (View Stats)
noah26 has a little shameless behaviour in the past
Default Which Cobb running map to run
Everything is stock I want to start with a ATP long careless downpipe I wanted to know the best Cobb tunning map to run with a all stock set up with that downpipe
Sent from my SM-G950U using Tapatalk
noah26 is offline   Reply With Quote
The Following User Says NO Thank You to noah26 For This Un-useful Post:
Thepedigree13 (08-14-2017)
 Old 08-13-2017, 01:36 PM   #2
Djohns's Avatar
Posts: 3,944   (View Stats)
Do you have fuel pump internals?
2010 black mica speed3
Soon:built motor
 Old 08-13-2017, 02:00 PM   #3
noah26's Avatar
No I don't see a point if I start with just the downpipe correct me if I'm wrong
sharksinspace (08-13-2017)
 Old 08-13-2017, 02:23 PM   #4
danb's Avatar
Posts: 176   (View Stats)
danb has much to be proud ofdanb has much to be proud ofdanb has much to be proud ofdanb has much to be proud ofdanb has much to be proud ofdanb has much to be proud ofdanb has much to be proud ofdanb has much to be proud ofdanb has much to be proud ofdanb has much to be proud of
You have to get fuel pump internals if you put on a DP.
Start researching how to mod these engines or you"ll go zoom zoom boom.
And it would be best to contact cobb, let tell them what mods you have and have them tell you what to run. i only say that because you can get different suggestions on what map to run, they"re cobbs maps they"ll know whats best to use and will let you know if its best to wait and go full tune... Then work on a full tune with 1 of the tuners represented here when you have everything you plan on installing
2007 speed3 GT. cobb rmm, JbR pmm, Corksport adjustable shifter, twm solid shifter bushings, Sure shift knob, AP3, Autotech, CS turbo, CS occ, HTP 3.5, Depo catless dp, TS Kompact bpv, CS 3port, cpe BlockD, GA V3, DO DVC-30, Cx racing piping, tr1035.. Freektuned
2011 mazda 6
danb is offline   Reply With Quote
 Old 08-13-2017, 02:30 PM   #5
noah26's Avatar
Thanks buddy!
 Old 08-13-2017, 02:42 PM   #6
danb's Avatar
Originally Posted by noah26 View Post
Thanks buddy!
you're welcome.
Start reading and good luck with your car!!
2011 mazda 6
 Old 08-13-2017, 03:58 PM   #7
Djohns's Avatar
Okay I'm correcting you because you're wrong lol. Definitely can't have a dp without internals, especially on a 2nd gen.
Soon:built motor
 Old 08-13-2017, 05:51 PM   #8
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
Read. You'll have questions. Search for answers. Read more. You'll have more questions. Search again. Read more. Rinse-Repeat.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
 Old 04-21-2018, 04:01 PM   #9
Theredmazdaguy's Avatar
Posts: 18   (View Stats)
Theredmazdaguy has a little shameless behaviour in the past
The thing is pretty much anything say for an intake, that causes you to push more fuel through the engine than the stock fuel pump can handle, you need HPFP. Get those first, then add everything else later so your car doesn't hate you
Theredmazdaguy is offline   Reply With Quote
Anyone running COBB AP stage 2 OTS bbjoy MazdaSpeed 3/6 - ECU Computer Tuning 11 01-25-2014 08:19 PM
Anyone running the Cobb Piping kit? NCspecV81 2010 MS3 - Turbo Induction 7 10-28-2013 10:48 PM
Anyone running Cobb Ap w/ similar set up? NickG1986 MazdaSpeed 3/6 - ECU Computer Tuning 2 03-15-2011 07:42 AM
ETS TMIC and CPe nano running w COBB AP kalix MazdaSpeed 3/6 - ECU Computer Tuning 12 06-04-2009 07:41 AM
Is anyone running An Cobb Ap with a BOV? HighSun_Murder MazdaSpeed 3/6 - ECU Computer Tuning 7 05-16-2009 11:43 PM
Page generated in 0.28819 seconds with 24 queries
