 Old 04-23-2018, 07:38 AM   #1
Speed3kid93's Avatar
Posts: 59   (View Stats)
Speed3kid93 has a spectacular aura aboutSpeed3kid93 has a spectacular aura about
Groaned at 18 Times in 7 Posts
Default E50 tune leaner than pump gas.. why?
Hey guys,
A little confused,
I recently switched from a pump gas tube to e50 tune both from the same tuner. However my 93 octane tune targeted a 11.3 air to fuel and my e50 tune is targeting 11.8.
Why is the e50 tune leaner?
When you use E85 you need to use more fuel because the btu is lower.
More fuel should mean a richer air to fuel..
So why is it leaner?
HPFP, Corksport Dp to CBE, cobb SRI and TIP, Cobb big front mount intercooler, corksport RMM, eibach lowering springs, accessport v3 with e50 tune by Will @ pd tuning 22 psi 11.8 AFR
Speed3kid93 is offline   Reply With Quote
 Old 04-23-2018, 03:04 PM   #2
Hoyoman's Avatar
Posts: 302   (View Stats)
Hoyoman is the leader of the worldHoyoman is the leader of the worldHoyoman is the leader of the worldHoyoman is the leader of the worldHoyoman is the leader of the worldHoyoman is the leader of the worldHoyoman is the leader of the worldHoyoman is the leader of the worldHoyoman is the leader of the worldHoyoman is the leader of the worldHoyoman is the leader of the world
Groans: 43
Groaned at 6 Times in 3 Posts
Because that's what the tuner is targeting. Why not just ask your tuner..
2012 black mica MS3 ; 3.5 HTP/ Catless DP/ AT HPFP/ APV2/ FMIC/ GFB BOv/ 3" CBE/ RMM/ XXR 530(18x9 +33)/ NT05 245/40/18/ 3bar map/ 3 port EBCS/ bnrs3/ DO stg2 dvc30/ REAR swaybar/ EBC Yellow/ CS Inj seals/ PNP IM/ Manley H-Beam/ Manley platinum piston 87.5/ soon...... PI+ BNRs6+ 44mm TIAL+ ACT 6 puck
E35 meth d012 26psi 420/451 self tuned/built
Hoyoman is offline   Reply With Quote
 Old 04-23-2018, 09:48 PM   #3
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
Bad tune?
Target AFR of ethanol has nothing to do with BTU's.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
 Old 04-24-2018, 05:50 AM   #4
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
Originally Posted by Speed3kid93 View Post
Hey guys,
A little confused,
O2 sensors read in lambda, and then convert to AFR using the gas scale of 14.7:1 (this scale isn't able to be modified in the ECU). Technically, you are putting in more fuel with the eth blend, you're just running at slightly higher lambda. Fairly common method, as you don't need to run such a low lambda when you have such high octane fuel.
-06 MS6
-Corn fed 07 MS3 - Sold
g00s3y (04-24-2018), kTaLgsTo (04-24-2018), Thor Hammer (04-24-2018)
 Old 04-24-2018, 07:18 AM   #5
g00s3y's Avatar
Posts: 2,127   (View Stats)
Groans: 438
It's leaner to even out the weight distribution with you in the car
andale927 (04-24-2018)
new tune pump gas PL ENDO 2010 MS3 - Dyno Sheets/Discussions 4 01-15-2014 08:15 PM
Advice on buying AP for Stage 1 tune with stock fuel pump ChicagoMike 2010 MS3 - ECU Computer Tuning 15 08-26-2011 05:59 AM
need help making a tune to run a lil leaner pugzsigmapi
Cobb ATR Support
9 08-02-2009 10:15 PM
datalog not doing so well not tune no fuel pump fully bolt ons Sanch MazdaSpeed 3/6 - ECU Computer Tuning 21 01-20-2009 05:21 PM
Page generated in 0.25254 seconds with 24 queries
