![]() Join Date: Mar 2011 Location: Chicago, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 22
(Thread Starter) | Not Ranked : 0 score im getting lots of kr on e85, ckspeed thinks its fake, what are your opinions? first two are before clint upped my timing and changed my wgdc, me and keith did a datalog and the first one had high kr but didnt record.
__________________ 2011 black mica ms3. Mods: mounts- jbr 80duro rmm, jbr 80duro trans mount engine- sure aeros,cs tip, forge v1 bpv, autotec internals,cnt catless dp, dizzy tuned shift- sure shortcut, countershift, anchors looks- ddm 6000k lows, 3000k fogs, rally armour mud flaps, cs led kit |
![]() Join Date: Jul 2010
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 19
| Not Ranked : 0 score lol dude what spark plugs you got? could be your spark plugs with seeing how freakin consistant it is try replacing those first. i doubt its anything else. may be sound to |
(Thread Starter) | Not Ranked : 0 score stock plugs, but wouldnt e85 be enough that i wouldnt need colder plugs
![]() Join Date: Jun 2010 Location: Wichita, KS
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 40,628
Groans: 386
| Not Ranked : 0 score How much e85 are you running? 100%, a few gallons? You said that you increased timing? You need to retard timing and see if it goes away. stock plugs should be fine with your mods Last edited by wolly6973; 09-14-2011 at 10:08 AM. Reason: MSF Database - Automerged Doublepost |
clint aka @phate did my timing table for me, i dont know anything about timing and im kinda nervous to mess with it personally. clint added timing and it didnt change anything at all, it didnt get worse
__________________ 2011 black mica ms3. Mods: mounts- jbr 80duro rmm, jbr 80duro trans mount engine- sure aeros,cs tip, forge v1 bpv, autotec internals,cnt catless dp, dizzy tuned shift- sure shortcut, countershift, anchors looks- ddm 6000k lows, 3000k fogs, rally armour mud flaps, cs led kit | |
In my experience, there are some changes in the modeling of the timing @ spool, and it seems difficult to start with a lower stage map and increase timing without inducing knock / remodeling part of the timing curve. (@ least on gen2 cars) Your decay rate is a bit long too. | |
37.50 37.50 46.70 55.00 55.00 55.00 55.00 55.00 55.00 55.00 55.00 55.00 55.00 55.00 37.50 37.50 46.70 55.00 55.00 55.00 55.00 55.00 55.00 55.00 55.00 55.00 55.00 55.00 37.50 37.50 46.70 55.00 55.00 55.00 55.00 55.00 55.00 55.00 55.00 55.00 55.00 55.00 37.50 37.50 46.70 55.00 55.00 55.00 55.00 55.00 55.00 55.00 55.00 55.00 55.00 55.00 24.50 31.90 39.70 39.00 40.00 40.00 40.00 40.00 40.00 40.00 40.00 40.00 40.00 40.00 26.00 32.00 40.00 40.00 40.00 40.00 40.00 40.00 40.00 40.00 40.00 40.00 40.00 40.00 23.00 31.00 37.00 37.00 37.00 37.00 37.00 37.00 37.00 37.00 37.00 37.00 37.00 37.00 15.90 20.50 26.50 29.00 30.50 32.00 32.00 32.00 32.00 32.00 32.00 32.00 32.00 32.00 11.50 15.50 20.50 24.50 26.75 29.00 29.00 29.00 29.00 29.00 29.00 29.00 29.00 29.00 10.16 13.25 15.40 20.70 23.35 26.00 26.00 26.00 26.00 26.00 26.00 26.00 26.00 26.00 8.82 11.00 13.19 15.30 18.15 21.00 21.88 22.75 23.00 23.00 23.00 23.00 23.00 23.00 7.48 8.75 10.97 12.43 15.41 18.40 18.80 19.50 20.50 20.50 20.50 20.50 20.50 20.50 6.14 6.50 8.76 10.64 13.31 14.00 16.50 17.69 18.78 20.00 20.00 20.00 20.00 20.00 4.56 5.50 6.87 8.23 12.40 13.00 15.00 16.40 17.60 18.50 18.50 18.50 18.50 18.50 2.97 5.03 7.09 9.14 11.20 12.00 13.25 15.26 16.76 18.00 18.00 18.00 18.00 18.00 1.38 3.54 5.69 7.85 10.00 11.50 12.25 13.68 16.00 16.00 16.00 16.50 17.00 17.50 -0.21 2.04 4.30 6.55 8.80 10.00 11.50 12.49 14.00 15.00 15.50 16.00 16.00 17.00 -1.80 0.30 2.40 4.50 6.60 9.00 10.75 11.38 13.00 14.00 15.00 15.50 15.50 16.00 -2.80 -0.70 1.40 3.50 5.60 8.00 9.50 10.50 12.50 13.50 14.50 15.00 15.00 15.50 -3.80 -1.22 1.35 3.92 6.50 7.50 9.00 10.00 11.50 12.50 13.50 14.00 14.50 15.00 -4.80 -2.35 0.10 2.55 5.00 6.00 7.75 9.50 10.50 11.50 12.50 13.50 14.50 14.50 -5.80 -3.47 -1.15 1.18 3.50 6.00 7.50 9.00 10.00 11.00 12.00 12.50 13.50 14.50 -6.80 -4.27 -1.73 0.80 3.33 5.00 6.50 8.50 9.50 10.50 11.50 12.00 12.50 13.50 -7.80 -5.06 -2.31 0.43 3.17 4.50 6.50 8.50 9.00 10.00 11.00 11.50 12.00 13.31 -8.80 -5.85 -2.90 0.05 3.00 4.00 5.25 6.50 7.00 8.00 9.00 11.14 11.79 13.13 -9.80 -6.84 -3.88 -0.91 2.05 3.10 4.05 5.00 6.50 7.50 8.50 10.79 11.57 12.94 -10.80-7.73-4.65 -1.58 1.50 2.80 3.65 4.50 6.00 7.20 8.30 10.43 11.36 12.75 -11.80-8.68-5.55 -2.43 0.70 2.30 3.70 4.50 5.63 6.90 8.10 10.07 11.14 12.56 -12.80-9.65-6.49 -3.34 -0.18 1.79 3.75 4.50 5.25 6.60 7.90 9.71 10.93 12.38 -13.00-10.05-7.10-4.14-1.19 0.77 2.72 4.00 4.88 6.30 7.70 9.36 10.71 12.19 -14.00-11.05-8.10-5.14-3.00 -1.00 2.00 3.50 4.50 6.00 7.50 9.00 10.50 12.00 thanks guys
| The Following User Says Thank You to blakkat For This Useful Post: | rfinkle2 (09-14-2011) |
Groans: 386
| Not Ranked : 0 score Looks like the timing is pretty conservative though. I would definitely give everything in the engine bay a once over to make sure nothing is loose. Does the kr always happen in the same rpm range, or do you get it up top as well? |
| The Following User Says Thank You to wolly6973 For This Useful Post: | rfinkle2 (09-14-2011) |
| Not Ranked : 0 score I see that, and was having a kr issue with running such retarded timing also. I switched to a base map given to me with much more aggressive timing, and have been able to add a few degrees with no knock to boot (straight pump 93 octane.) |
![]() Join Date: Jul 2010 Location: Phenix City, Alabama
Rep Power: 2996 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 16,814
Groans: 451
| Not Ranked : 0 score I can help you too, brother. Gen 2 on 50/50 e85/93. Let me know. feel free to email. wsbucker@gmail.com
__________________ 330whp/381ft/lb No Nitrous Meh 403whp/451ft/lb Dry Shot |
| The Following User Says Thank You to Bucker For This Useful Post: | rfinkle2 (09-14-2011) |
![]() Join Date: Nov 2010 Location: St. Louis missouri
Rep Power: 1310 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,310
Groans: 134
| Not Ranked : 0 score I can't believe that this can be real KR. How can 2 gallons eliminate all KR on mine, and yet he can run around a 50/50 mix and have so much? Also, I don't think that the kr is consistent. It never seems to be around the same number or at the same place. And the fact that adding timing did not exacerbate it, makes me skeptical. Can injector seals fail on such a lightly modded car? Just my two cents. |
| The Following User Says Thank You to Ckmazdaspeed3 For This Useful Post: | rfinkle2 (09-14-2011) |
Groans: 386
| Neutral : +1 score I was getting kr in the same region as you a while back also. I added a few gallons of e85 and pulled a TON of timing and nothing helped. Once I put the timing back to OTS values, it was pretty much gone except for a really small count every once in a while at spool up. |
| Not Ranked : 0 score Ask Phate to knock your decay rate down some. The new datalogging rate makes it look like way more knock than is truly present. |
| The Following User Says Thank You to rfinkle2 For This Useful Post: | wolly6973 (09-14-2011) |
Groans: 451
| Not Ranked : 0 score im talking with blakkat now. Ill be sending him some revisions via excel including reducing decay rate and making sure his OL/CL transitions are on point.
![]() Join Date: Dec 2010 Location: St. Louis
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,169
| Not Ranked : 0 score I'd bet on engine noise.... You have motor moounts? You need to change try scaling your offset a bit....This is something that you really need to let someone who knows what they are doing mess with....
__________________ EWG K04...GETSUM! A journey to make people cry like babies when loosing to a wagon. |
| The Following User Says Thank You to bewsted For This Useful Post: | rfinkle2 (09-14-2011) |
(Thread Starter) | Not Ranked : 0 score yes i have a jbr rmm, shit man this is getting complicated, theres no way i can do this without fucking something up
Groans: 386
| Not Ranked : 0 score You coming to the meet out in DeKalb tonight? We can mess with it there. |
' @finkle, the only ic maps i see are all stage 2
![]() | | #19 | ![]() |
![]() | | #20 | ![]() |
| Not Ranked : 0 score I mean i'm not guarenteeing that it is engine noise but it does happen....
![]() | | #21 | ![]() |
| Not Ranked : 0 score ol copy to cl call it a day
![]() | | #22 | ![]() |
Groans: 451
| Not Ranked : 0 score What? I am talking about exit delays and max load stuff lol.
![]() | | #23 | ![]() |
| The Following User Says Thank You to rfinkle2 For This Useful Post: | atvfreek (09-14-2011) |
![]() | | #24 | ![]() |
| Not Ranked : 0 score I just looked @ that last log, and there is definitely something other than timing going on there. |
![]() | | #25 | ![]() |
Groans: 60
| Not Ranked : 0 score I run four degrees more timing than that at redline, and higher timing just about everywhere else...on nothing but 93 pump gas. IMO you really need an EGT if your going to play with timing... Adding or subtracting 2 degrees may net 0 butt dyno gains, but raise or lower your egt's 200 degress. Low timing or very high timing will raise EGT's, and can cause KR.. Looking at those logs, the first thing I would do is bump up the knock sensor offset above 5K. KR of .06, .1, .2 above that rpm are almost certainly just engine noise..
__________________ Fully Built : Arias Pistons: Pauter Rods : ARP bolts: Ported Head: Cosworth BSD : Spec 3+ Clutch : Fidanza Flywheel : AWR Engine mounts 90duro : Custom TIP/Intake : Custom Blow Through 3.5" MAF : Custom FMIC : HKS SSQV VTA : Ported IM : Custom DP : Custom Exhaust : CPBoost Top Mount EM : Garrett GT3582R : PTP Turbo Blanket: Tial V44 EWG : Perrin EBCS : MrLilGuy/PTP HPFP : Ported fuel line : Ported Fuel Rail : Custom Ported Fuel Injectors : Kenny Bell Boost-a-Pump : HKS Twin Power DLI II : HKS M-Series Plugs : Cobb AP : AEM 3.5bar MAP :Koni Sport shocks : RPM Kspec Springs : TWM STS : TT Front Diff Mount : CPE Upper Diff Mount : Whiteline RSB : AWR Endlinks Last edited by SSinstaller; 09-14-2011 at 11:46 AM. |
![]() | | #26 | ![]() |
| Not Ranked : 0 score that is my guess too
![]() | | #27 | ![]() |
| Not Ranked : 0 score I think you are running too little timing for e-85. I've even seen cars on 93 with too little timing have kr issues. Some of the base ots maps have weird ignition tables. What base map did you start with?
__________________ 2010 Speed3-PTE5858 Freek built/Freektuned 510hp420tq 11.321@129.93 |
| The Following 3 Users Say Thank You to atvfreek For This Useful Post: |
![]() | | #28 | ![]() |
Groans: 451
| Not Ranked : 0 score ok, here are the basic settings that I throw at every map I make for me or anyone else. These are essentially just sensor calibrations and other shit to make it act consistently in most conditions. I have emailed this to blakkat and I figured I would make it available for you losers, too. This is a building block. Fueling/ boost/ timing will be built on top of this as per mods/ owners desires. I would add timing, blakkat. I know Phate knows what he is doing, but at the same time he isnt going to just toss a 20* timing map on there without working up to it. I run the eth/93 mix with that much timing now with no issues. If you want to step that up, ill give you a modified timing table of mine.
![]() | | #29 | ![]() |
Groans: 60
| Not Ranked : 0 score My KR offsets are the same everywhere except >1.5 load at 5000 I use .8 and 5500 .95. My decay rates are set to 100..
| The Following User Says Thank You to SSinstaller For This Useful Post: | wolly6973 (09-14-2011) |
![]() | | #30 | ![]() |
Groans: 451
| Not Ranked : 0 score Yes, like I said this is what I use as a starting point. I am sure that a lower decay rate makes sense as well as the KR offsets, but I have found that these settings work for my needs. Actually, I might lower my decay rates now for myself. Once you have a tune dialed in pretty well thats a good call.
| The Following 4 Users Say Thank You to Bucker For This Useful Post: |
![]() | | #31 | ![]() |
Groans: 60
__________________ Fully Built : Arias Pistons: Pauter Rods : ARP bolts: Ported Head: Cosworth BSD : Spec 3+ Clutch : Fidanza Flywheel : AWR Engine mounts 90duro : Custom TIP/Intake : Custom Blow Through 3.5" MAF : Custom FMIC : HKS SSQV VTA : Ported IM : Custom DP : Custom Exhaust : CPBoost Top Mount EM : Garrett GT3582R : PTP Turbo Blanket: Tial V44 EWG : Perrin EBCS : MrLilGuy/PTP HPFP : Ported fuel line : Ported Fuel Rail : Custom Ported Fuel Injectors : Kenny Bell Boost-a-Pump : HKS Twin Power DLI II : HKS M-Series Plugs : Cobb AP : AEM 3.5bar MAP :Koni Sport shocks : RPM Kspec Springs : TWM STS : TT Front Diff Mount : CPE Upper Diff Mount : Whiteline RSB : AWR Endlinks | |
![]() | | #32 | ![]() |
(Thread Starter) | Not Ranked : 0 score still have steady 3 degrees of kr, fml. looked for loose shit in the engine bay and didnt find anything. im gonna try a stage 0 map after i run out of e85.if kr is still there ill just have to keep searching the engine bay
![]() | | #33 | ![]() |
Groans: 451
| Not Ranked : 0 score Hey, if you copy your MAF scale over to the stage 0 map you can flash that thing with eth still in the tank. Sorry, should have mentioned that last night.
![]() | | #34 | ![]() |
Groans: 386
| Not Ranked : 0 score Just to keep the thread up to date... We tried adding timing per the few theories in this thread, and got more kr. So that theory is untrue in this case. Then we richened up the AFRs from 11.9(was seeing a .3 variance, so up to 12.2) to 11.6, and this did not change anything. |
| The Following User Says Thank You to wolly6973 For This Useful Post: | Bucker (09-15-2011) |
![]() | | #35 | ![]() |
(Thread Starter) | Not Ranked : 0 score used up all the e85, and ran straight 93, still getting kr around 6, plugs seemed fine, not indicative of 6* of kr. im dumbfounded
![]() | | #36 | ![]() |
Where are you getting the 6* KR? If @ wot, take it easy until you get your map straightened out. | |
![]() | | #37 | ![]() |
(Thread Starter) | Not Ranked : 0 score sorry i should have explained, i switched to a stage 1 stock map
![]() | | #38 | ![]() |
| Not Ranked : 0 score Are the 6* of KR @ wot? Also, are you using 91 octane or 93? |
![]() | | #39 | ![]() |
Groans: 386
| Not Ranked : 0 score He has 93 oct. Other shots in the dark that were mentioned to me when I had my issues were to check the crank angle sensor to make sure it is seated correctly. If it is a little out of line, it could be showing less timing than you are actually running. Also, like I mentioned at the meet. Try pulling the IM and making sure the kr sensor is tight. If you want, I can help you with that next week sometime. |
| The Following User Says Thank You to wolly6973 For This Useful Post: | rfinkle2 (09-16-2011) |
![]() | | #40 | ![]() |
I ask about the octane because it seems that part throttle knock on the 91 octane maps is common. | |
