 Old 01-17-2012, 11:50 PM   #1
shifter48's Avatar
Posts: 361   (View Stats)
shifter48 is the leader of the worldshifter48 is the leader of the worldshifter48 is the leader of the worldshifter48 is the leader of the worldshifter48 is the leader of the worldshifter48 is the leader of the worldshifter48 is the leader of the worldshifter48 is the leader of the worldshifter48 is the leader of the worldshifter48 is the leader of the worldshifter48 is the leader of the world
Groaned at 6 Times in 4 Posts
Default All you tuners
Does anyone monitor EGT here???? I've run shifter kart where it's what we adjusted AFR with..1150F was safe..1250F was pure race mode...anything above that would melt a ring and blow the motor. Just don't see anyone here monitoring this it as a tool for tunes...I'm new to the turbo engines and starting to learn the AP...but!!..I think without knowing what the EGT is you don't know how far to push it or tailor your tune. Seems like we're in a computer age that figure and numbers rule...but the end results go out the exhaults or right pass the head.
67 yrs young..2012 MS3 with Tech, Cobb AP, JBR 88 dogbone, JBR Rear Swaybar,Autotech Internals..JBR 88TMM & 80PMM, HTP 3" tip with a custom fab MAF housing, UR FMIC, TWM short shifter assembly, Sure SSP and Weight, UR CBE, UR metal catted DP, UR res. TP, Synapse DV, Grimmspeed EBC, Bosh 3 bar map sensor, Denso ITV22's, FoMoCo Trans Fluid, Corksport aluminum skid plate, Sonic ST8's 18X8.5X40 running PSS 245/40's, Nitrogen filled tires, GoPro Hero, Hero-2 (For those moments, adds 20+driverhp) TUNED BY: mrmonk7663
_______________________________
Team LBN BEERS--FYCN
TEAM MUMFORD---FYCN
shifter48 is offline   Reply With Quote
 Old 01-18-2012, 03:41 AM   #2
ASHMS3's Avatar
Posts: 1,362   (View Stats)
Groans: 126
I don't think there are many if any that monitor it closely. I think the reason is that with the AP you can monitor AFR's and alot more with that instead of having to monitor EGT and adjust from there. I'm sure people alot smarter than me will chime in. Just my .02
 Old 01-18-2012, 04:26 AM   #3
kmac's Avatar
Posts: 1,792   (View Stats)
The only way to monitor it is with a gauge and pyrometer. Egt for di cars r not nearly as high as pi cars.
First 500whp stock block mazdaspeed3 (503whp 423wtq)
<3 Tokay.
Tire Pressure Monitoring System marco427 Gen2 MS3 General Discussion 14 12-16-2011 11:12 PM
Monitoring w/ AP AZSPEED3 MazdaSpeed 3/6 - ECU Computer Tuning 46 08-04-2010 05:15 PM
little question about monitoring ATAZ MazdaSpeed 3/6 - ECU Computer Tuning 7 12-21-2009 02:32 PM
ZF monitoring key suppliers Haltech Automotive News 0 03-04-2009 09:20 AM
monitoring datas with DH and COBB AP borderline MazdaSpeed 3/6 - ECU Computer Tuning 13 10-05-2008 08:48 AM
Page generated in 0.24534 seconds with 22 queries
