![]() Join Date: Feb 2011
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 18
Groaned at 27 Times in 7 Posts
![]() Join Date: Feb 2010
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,452
Groans: 82
| Not Ranked : 0 score Introduce yourself? There's a new member intro section, I'd suggest making a thread there if you haven't already. Glad you like the AP. |
| The Following User Says Thank You to Speed3eak For This Useful Post: | rfinkle2 (04-06-2011) |
![]() Join Date: Mar 2011 Location: Shawnee, Ks
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,101
Groans: 48
Groaned at 49 Times in 30 Posts
| Not Ranked : 0 score How many miles do you have on your ride. Did the SRI make a noticable difference alone? |
| Banned ![]() Join Date: Feb 2010 Location: Oregon
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 544
Groans: 30
Groaned at 40 Times in 13 Posts
| Not Ranked : 0 score Airborne!!! Keep your feet and knees together!! 1/504 PIR 1995-1998 |
![]() Join Date: May 2010 Location: Virginia Beach
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 369
Groans: 58
| Not Ranked : 0 score Im just letting you know that you butt dyno is way off. You need to recalibrate that soon.
__________________ [SIGPIC][/SIGPIC] 2013 CWP (DD)COBB AP| JBR HSK| JBR RSB| JBR SSP| JBR Shifter Bushings| AT Internals| Ksport Kontrol Pro Coilovers| 3.5 MAF HOUSING| 3' HTP TIP| UR FMIC| TIGS| GTX2867| EBAY 3' DP TUNE IN PROGRESS (RFINKLE2) 1999 Mazda Miata (PROJECT) (blown motor) BEGI Cast Manifold| BEGI DP| SR20 Turbo (GT2554)| Flying Miata Silicone IC Piping| Cx Racing IC| HKS BOV| TEIN SA| Harddog Rollbar|Sparco Spint V| TRmotorsports C1 15x8 |
![]() Join Date: Jun 2008
| Not Ranked : 0 score Congrats on the AP. Why is 40hp off with this mod+SRI? Probably not too far off.
__________________ ZOOM-ZOOM-BOOM-BOOM |
(Thread Starter) | Not Ranked : 0 score Yea I meant 40hp total. I did not explain myself well there. ![]() Here is a log of a 3rd gear pull. All The Way! 2/504 PIR Desert Storm |
| Not Ranked : 0 score Make sure that when you are logging, you keep an eye on your fuel pump. You logged a fuel pump variable, but I believe it is voltage, rather than pressure. For reference, you would like to see fp north of 1400 psi. |
![]() Join Date: Jan 2011 Location: Wildomar, Ca
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 375
He has FP in there. (4th row) 2.33 11.17 18.13 1350.25 0.56 1.56 179.98 3813 3.5 71.37 48.47 71.03 2.45 11.32 17.26 1382.16 0.56 1.56 190.1 3902 3 72.15 49.71 64.92 2.57 11.32 18.71 1329.95 0.21 1.56 207.44 4006 2.5 72.54 49.71 49.16 2.71 11.32 19.29 1260.33 0.21 1.56 200.56 4116 3 72.54 51.57 51.55 2.85 11.32 17.84 1203.77 0.21 1.56 198.29 4220 4.5 72.54 52.82 57.65 2.99 11.32 17.11 1224.08 0.21 1.56 203.59 4285 4.5 72.93 54.06 59.16 3.13 11.32 17.11 1334.3 0.59 1.56 208.21 4411 4.5 72.93 55.92 59.21 3.25 11.32 17.4 1369.11 0.24 1.56 210.55 4504 5 72.93 57.17 60.28 3.35 11.32 17.4 1367.66 0.24 1.56 213.71 4607 5 72.93 58.41 60.89 And its dropping low between 3800-4600 rpms. | |
![]() Join Date: Jun 2008 Location: Bowling Green, Kentucky.
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 909
| Not Ranked : 0 score Going to need a fuel pump, looks good other than that.
__________________ EBTEC Manley Built // GT3071R // FreekTuned // Freek 3.5" Intake // Ported IM // Perm Plate Dual CC // Catless DP // CNT CB // Tokay V 1's // Autotech // AEM Failsafe // TR8 IC// GFB // JBR 88 RMM // DM PMM // JBR 70 TMM // ACT 6 puck prolite fly // Cobb RSB // 6 pc chassis braced // Koni FSD's // Cobb Springs // EGR Full delete // SWAS switch // SS brake lines // 100% Methanol Injection D14 ____________________________________________Dragon Slayer _________________________________________________ |
![]() Join Date: Mar 2010 Location: STL, MO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,038
Groans: 123
| Not Ranked : 0 score 1400 is way wrong u wanna see 1600+ at WOT. Pick up some KMD V2 internals or Autotech internals. Or if if rich a Cp-e fuel pump
__________________ 2003 Evo VIII BUILD PLANS: LR 2.0/2.4, 6466, 800+whp. Shooting for 9s at full weight. Time is on my side, gonna take forever. Old: 2009 White MS3. Fully bolted and tuned. Sold |
(Thread Starter) | Not Ranked : 0 score I am getting 1600+ at WOT but EX_WRX is right, I do have a low pressure spot in the mid rpm range. Fuel pump is next, prob CP-e version. I just wanted to be able to log and jumped on the chance to Beta the AP for 2011. Just updated to a new map from that log. COBB is fine tuning them as we give datalogs. So cool. Will see if it helps. Last edited by Airbornemedic; 04-06-2011 at 03:15 PM. |
| The Following User Says Thank You to Airbornemedic For This Useful Post: | 4G63 (04-06-2011) |
(Thread Starter) | Not Ranked : 0 score Here is another log. Cobb gave to a new map to try after I gave them the above log. This new log is a 4th gear pull with this new map installed. |
From the datalogging guidelines provided by Christian on the cobbtuning.com web page: italics cut and pasted: If the DI Fuel Pressure drops below 1400psi while at WOT, then you will need to install an upgraded CDFP or use the Free AccessTUNER Race software to lower your boost targets. | |
| Not Ranked : 0 score FP between 3200 and 3600 looks a little sketchy. You let off at 5800 rpms? You need to pull all the way to 6700. Last edited by Ex_WRX_driver; 04-06-2011 at 04:16 PM. Reason: Put 5800 instead of 5500 |
![]() Join Date: Feb 2011 Location: Cleveland TN
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,751
Groans: 90
| Not Ranked : 0 score Looks good, glad your enjoying your AP. I'd recommend getting a testpipe if you haven't already, its been the most noticeable power upgrade i've done.
__________________ 2012 Triumph Street Triple SOLD -- 2010 Velocity Mica Red MS3 ATP GTX3071r - Cobb AP(Freek Permed) - CNT Catted DP - UR CBE - DO Stage 2 WMI(80/20) - cp-e TMIC - cp-e xcelXL - cp-e invicid inlet - Grimmspeed MBC - KMD v2.2 hpfp internals - Bosch 3bar MAP - H&R Springs - DDM 6k Raptor Kit - ITV22's - Forge v2 BPV - 225/40/18 Nitto Neogens - SURE RMM |
(Thread Starter) | Not Ranked : 0 score Thanks Broxer, that is on my list. ![]() Yea missed my marks on the RPM targets a bit. I only have 1900 miles on the car and with the changes with mods, spring temps, and AP maps I cant judge yet by feel. The tach takes a back seat to the watching the road LOL. Anyhow, thanks for the responses. |
| The Following User Says Thank You to Airbornemedic For This Useful Post: | rfinkle2 (04-06-2011) |
![]() | | #19 | ![]() |
![]() Join Date: Jun 2010 Location: Wichita, KS
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 40,628
Groans: 386
| Not Ranked : 0 score If your AP is in view, you can set it to flash at you for a shift light/let off light at whatever rpm you choose. |
![]() | | #20 | ![]() |
![]() Join Date: Jan 2010 Location: Mukilteo, WA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 26
| Not Ranked : 0 score Or you could let it bounce the rev. limiter.
__________________ Current Cars: 2014 Ford Focus ST, Performance Blue 1948 Lotus 7 with a turbo'd '99 Miata Motor (200+hp and weighs 1400 lbs) 1992 Mazda Miata, Racing Red Old Cars: 1992 Mazda Kliata, Miata with V6 KL-DE Engine, Blue/Black 2011 Mazdaspeed3, Celestial Blue Mica 2008 Mazdaspeed3, Black Mica 2006 Mazda3, Strato Blue |
![]() | | #21 | ![]() |
![]() Join Date: Mar 2011 Location: Jacksonville, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 387
| Not Ranked : 0 score Did u have to calibrate your MAF? |
![]() | | #22 | ![]() |
| Not Ranked : 0 score You should log Pedal so we can see if you are WOT, also you should not boost so low in the rpm band. Wait till atleast 3000 RPM before pegging it, I never do before 3500. Loading up the boost at low RPM is hard on the engine.
![]() | | #23 | ![]() |
(Thread Starter) | Not Ranked : 0 score I am not sure how the logs are coming across since I have tried to line up the categories with the numeric data. Should I just post the raw AP data or my attempt of organizing it? Wierd. I did have throttle position in the data, but like I said, not sure if I screwed up the format. I have not calibrated my MAF. The cobb tuner I am working with said my fuel trims are fine and AF ratio are fine. Just got another map adjustment but will have to wait until tomorrow to do some more runs. Drank three 7&7s LOL.
__________________ Cobb SF intake // Cobb TIP // Sure RMM // Cobb AccessPort Stage 2 // StreetUnit Racepipe // CP-e HPFP // CP-e TMIC // Denso ITV22 |
| The Following User Says Thank You to Airbornemedic For This Useful Post: | ELiTeNeSs (04-06-2011) |
![]() | | #24 | ![]() |
![]() | | #25 | ![]() |
![]() Join Date: Nov 2010 Location: VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 27
| Not Ranked : 0 score Airbornemedic, are you testing the 2011 AP for Cobb?
__________________ 2011 MS3 Black Mica Autotech Internals // Cobb AcessPORT (FREEKTUNEd) // CorkSport Racepipe; Springs; Camber Arms // Cp-e TMIC; SRI; TIP; RMM 75A // DDM 35W 6000K HIDs Denso ITV22's // JBR SSP stage 2; Mud Flaps // Tenso-R Concept 9 rims // 35% Tint // OCC (Matt Damon) // Koni Yellow Sport [SIGPIC][/SIGPIC] |
![]() | | #26 | ![]() |
Groans: 58
| Not Ranked : 0 score The reason that I say it is because of my dyno's. Look at my build thread and you will see what I am talking about. There is a gain but not near as much as you are thinking. I assure you. And my dyno's were done on the same machine using the same correction factor.
![]() | | #27 | ![]() |
To check that low RPM boost targets are being hit correctly, Cobb has us going WOT at 2K for 3rd and 2.5k for 4th. | |
| The Following User Says Thank You to Ex_WRX_driver For This Useful Post: | rfinkle2 (04-07-2011) |
![]() | | #28 | ![]() |
| Not Ranked : 0 score FWIW, if using throttle position, ~74-75% = wot. |
![]() | | #29 | ![]() |
![]() Join Date: Jan 2011 Location: pittsburgh, pa
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 105
are you a beta tester? because the AP for the '11s isnt out yet, its still being tested.... unless your using one meant for a 2010
__________________ '11 Speed 3 Black Mica (Sold unfortunately, going back to school) '12 3 Skyactiv- its slow as hell but getting 38mpg makes it somewhat worth it Licensed PA State Inspection and Emissions Tech | ||
![]() | | #30 | ![]() |
![]() Join Date: Feb 2011 Location: Roanoke, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 102
| Not Ranked : 0 score He is beta testing the unit like a few others are doing..... I am on revision B and I have to say I like A better. Hopefully they will have C for me to try tomorrow. Gotta say it is kind of fun being a Gennie pig. But the out come will be a tried and well tested unit, that will Perform! |
![]() | | #31 | ![]() |
| Not Ranked : 0 score yea, i read that they didnt have as many testers as they thought so i just threw an app in for shits and giggles...
![]() | | #32 | ![]() |
(Thread Starter) | Not Ranked : 0 score I am on my D or 4th map revision. Have not had a chance to run it yet. The C version seemed to work pretty good. Power was very linear and predictable. The more you pressed the throttle the more you get. It does not have spikes and plateaus. Fuel pressure now stays easily 1600 plus on stock FP. Boost gets to 17.5ish.
![]() | | #33 | ![]() |
because i live in pa and mine is saying its a cali
![]() | | #34 | ![]() |
| 2011 MS3 AccessPORT Beta Testing Applications Being Accepted. | Christian. | 2010 MS3 - ECU Computer Tuning | 195 | 05-11-2011 06:34 AM |
| H&R + Koni Install and impression | jamesthebikeguy | MazdaSpeed 3/6 - Suspension & Brakes | 49 | 08-04-2010 06:37 AM |
| Mazdaspeed Coilover Track Review/Impression | AlpineFD | MazdaSpeed 3/6 - Suspension & Brakes | 7 | 05-07-2009 11:46 AM |
| Chrysler's in-car wi-fi makes weak first impression | Haltech | Automotive News | 0 | 09-15-2008 05:00 PM |
