![]() Join Date: Mar 2018
Rep Power: 0 ![]() Thanks: 1
| Not Ranked : 0 score First, you dont give any infos. Is it a specially made tune for your car and mods or a general map ? Which mods do you have ? I wouldn't expect much from a general tune because each car is different and if it is a specially made tune,unless it is your final flash, it is useless to comment until it is finish... If it is
Groans: 438
I don't get it.
__________________ All good things must come to an end... | |
| The Following 2 Users Say Thank You to g00s3y For This Useful Post: | kTaLgsTo (04-18-2018), Thor Hammer (04-18-2018) |
Groans: 211
1. OTS. Otherwise known as Off The Shelf. (Similar to the ones that come on your Cobb AP with a short list of mods to match yours) but Stratifieds are much better. 2. Custom E-Tune. You email Stratified with a list of your mods. They send back a map. You load it, run it, data log it, then send the log back. They send you an update based upon your numbers. Then repeat until done. So, which one do you have bruh? And why the hell would you think that either of those options mentioned above are not safe for your car? When had you done some research you would know without a doubt that Stratified knows this platform very, very, well.
__________________ 2007 MS6- H&R Coilovers/ C-PE Catted DP/Corksport HPFP Internals/ AEM CAI/ ETS TMIC/ CPE Austenite Dual CBE/ CPE TIH/ Synapse Synchronic/ Freektuned/ AP Short Shifter/ AWR RMM and OEM TMM with CS Inserts/ Southbend Stage 2 Endurance/Stop Tech Slotted Rear and DBA T3 4000 Series Front with EBC Reds/CPE xFlex Rear Diff Mount/ Whiteline Rear Sway Bar/DSS Level 2.9 Rear Axles | |
![]() Join Date: Dec 2017 Location: Idaho
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 84
| Not Ranked : 0 score Nobody wants a ZZB, but everyone wants a ZZA
__________________ 2011 MS3 Tech - 2008 Jeep Grand Cherokee CRD - 1989 Crown Vic LTD LX - 1985 Lincoln Town Car Signature The key to happiness is owning a car ridiculously slower than your 'fast' car. |
| The Following User Says Thank You to kTaLgsTo For This Useful Post: | Db09ms3 (04-18-2018) |
Groans: 211
| Not Ranked : 0 score You know you watched the whole thing. Are you ready to sell me that rev3 intake manifold??
Groans: 211
| How To: Stratified Tune | Lex | Stratified Automotive Controls | 1 | 07-24-2014 12:22 PM |
| First Stratified S-OTS+ Tune | Jadcock | 2010 MS3 - ECU Computer Tuning | 45 | 07-09-2014 08:57 AM |
| Stratified Tune | phahengpro | MazdaSpeed 3/6 - ECU Computer Tuning | 42 | 03-07-2014 03:29 PM |
| Stratified tune done. | MS309 | Stratified Automotive Controls | 57 | 08-04-2012 05:39 PM |
| Stratified (Lex) Tune! (330/393 VD) | psychophyr | Stratified Automotive Controls | 11 | 02-23-2012 04:39 PM |
