![]() Join Date: Mar 2012
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5
Groaned at 7 Times in 5 Posts
(Thread Starter) | Not Ranked : 0 score My mods exist of only a MSCAI and a Cobb OTS Stage 1 MSCAI tune 91 octane. I plan to upgrade my internals as my next mod just as soon as I can but in the mean time... I would love to get some input or advice from those of you who actually know WTF is going on with these numbers. Any help at all is greatly appreciated!! |
| Not Ranked : 0 score I don't see much knock. Seems to be normal spool up that a lot of folks get (including me). I don't remember what non-zero LTFTs mean during WOT logs, but I would look at your MAF cal again and maybe search for the LTFT thing. Other than that, yes get some internals..... |
| The Following User Says Thank You to sheston For This Useful Post: | Somnospeed (04-24-2015) |
![]() Join Date: Oct 2011 Location: San Leandro, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 460
Groans: 87
| Not Ranked : 0 score Looks ok except your LTFT.
__________________ 2018 Audi RS3 2013 CWP Mazdaspeed3 - CS Turbo 2007 Acura TSX 6MT |
| The Following User Says Thank You to tegxsi For This Useful Post: | Somnospeed (04-24-2015) |
(Thread Starter) | Not Ranked : 0 score MAF cal... yes... now I remember... I don't think I have ever properly done that. Last time I messed with any logging was over two years ago and I don't think I ever got that done right. I suppose I should read up on that again. |
![]() Join Date: May 2010 Location: SLC, Utah
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 15
| Not Ranked : 0 score Something's jacked up. It looks like it's taking you 5 seconds to transition to OL. And I prefer not to got WOT at that low of RPM.
![]() Join Date: Jan 2015 Location: Brisbane, Australia
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 38
But you definitely need Internals. Other then that, looks to be all sweet
__________________ '12 Black Speed 3 CS RMM -~- CS SSP & Gearbox Bushings -~- CS OCC -~- CS LED light kit -~- CS Front and Rear Sway Bar -~- UnPlugged EGR Delete -~- CS Hood Struts -~- DVC30 WMI -~- JBR 3" Widepath -~- CS HPFP -~- GrimmSpeed 3 Port -~- HKS SSQV -~- CS TMIC -~- 500W Memphis Sub/Custom Wheel Well Box -~- 3" Xforce TBE -~- RayD Tuned | |
| Approved MSF Vendor ![]() Join Date: Jan 2012 Location: Maryland, USA
Rep Power: 884 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,286
| Not Ranked : 0 score Open Loop
__________________ --- 2011 Black Mica MS3 Tech --- ![]() www.stratifiedauto.com COBB AP and VersaTuner Custom Tuning. Guardian Angel Protection and Boost Control. |
| The Following User Says Thank You to Mike@Stratified For This Useful Post: | Somnospeed (04-24-2015) |
| False Knock reality check | Mattyhawk1 | MazdaSpeed 3/6 - ECU Computer Tuning | 6 | 05-19-2015 09:22 AM |
| Check the noobs logs and tell him where he fucked up | Ragnarok0mega | 2010 MS3 - ECU Computer Tuning | 8 | 08-12-2014 06:49 PM |
| Check out my Knock log | thered rocket | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 5 | 04-23-2013 06:21 PM |
| Suspension knock and check engine light | spoonher | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 0 | 08-04-2009 02:25 PM |
| Stock car with lots of knock, what hoses do I need to check? | Meder | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 16 | 11-25-2008 06:45 PM |
