Like Tree5Likes
 Old 08-09-2012, 07:34 PM   #1
Nishan
ms3blackmica's Avatar
Posts: 5,635   (View Stats)
Default MAF Calibration Tutorial 2
This tutorial can be followed for both the Gen 1 MS3, Gen 2 MS3, and also the MS6. If you upgrade to a larger than stock MAF housing you will have to scale the entire maf curve before performing your MAF Calibrations as the larger cross section allows for more airflow with less cooling to the MAF resistors due to the decrease in air velocity.
If you have a larger than stock intake, you will develop a scalar first and THEN follow this tutorial. If you have a stock sized aftermarket intake, skip right to the videos.
In order to develop a scalar for a larger than stock intake diameter, you must take the (New MAF Cross-Sectional Area) and divide (/) it by the (Stock MAF Cross Sectional Area).
__________________________________________________ __________________________________________________ ______
You already know the cross section of the MAF housing is a circle and the area of a circle can is derived as (pi*r^2). Another derivation of this formula is (pi*d^2)/(4). When deviding the two cross sections, pi and all other constants will cancel. Therefor, all you need to do is take the square of the new MAF Diameter and divided it by the square of the stock MAF diameter. Simple as that.
Example Scalar: You decide to upgrade to a 3" intake (76.2mm). The stock MAF housing is 66.5mm diamter (2.61811"). You can either convert millimeters to inches or inches to millimeters, the choice is yours.
(76.2^2) / (66.5^2) = 1.313
Take 1.313 and multiply it by the entire MAF curve. Now you are ready to start your MAF Calibration. This is ONLY for vehicles with a larger than stock intake installed. This is only an example for a 3" intake.
***Please be careful when performing WOT (Wide Open Throttle) logs. You will be breaking the law because of the speeds you will be accelerating to in 4th gear. Make sure your tires are in good condition, have adequite pressure, and that your car is aligned properly. Anything can go wrong at over 100 MPH and extra caution must be taken when logging these pulls. You are at your own risk when performing WOT logs and you must take every precaution before starting.
For best results, watch in 720p HD and full screen and in the order they are placed. You can also download the zipfile to keep them on your computer and watch offline. Also i apologize for constantly coughing. I was still getting over having a sore throat from a cold.
If you would like to know how i mounted my AP, you can visit this thread...
Mounting Your Accessport
Setting up your Accessport
How to perform a closed loop MAF Cal Log
How to analyze the data from your closed loop MAF Cal log and make the appropriate changes in AccessTuner Race
Making Sure you do not have any dips in your MAF Curve!
How to perform a WOT (Wide Open Throttle) Log
How to analyze the data from your WOT MAF Cal log and make the appropriate changes in AccessTuner Race
Also, here is video from another thread on using AccessTuner Race.
www.tunedbynishan.com
The Following 11 Users Say Thank You to ms3blackmica For This Useful Post:
1LapMS3 (05-18-2013), Juyoung (09-01-2013), maisonvi (09-03-2013), metalgear386 (08-31-2013), new2boost (07-31-2013), oOfactoryOo (12-28-2013), Outlaw4shrt (04-23-2013), pfp22972 (03-11-2014), RdotQelo (07-20-2013), sadak (05-07-2013), Steven (03-24-2013)
 Old 08-09-2012, 07:34 PM   #2
Nishan
The Following 8 Users Say Thank You to ms3blackmica For This Useful Post:
bstover17 (04-23-2013), Digital_Jedi (09-20-2013), Doberman (02-27-2013), Fjager (12-12-2013), forcedinduktion (03-08-2013), goHAMM (02-07-2014), mazdas4me (04-09-2014), PolishMs3 (02-23-2016)
 Old 01-22-2014, 05:24 PM   #3
ThatGuy's Avatar
Posts: 153   (View Stats)
ThatGuy has a reputation beyond reputeThatGuy has a reputation beyond reputeThatGuy has a reputation beyond reputeThatGuy has a reputation beyond reputeThatGuy has a reputation beyond reputeThatGuy has a reputation beyond reputeThatGuy has a reputation beyond reputeThatGuy has a reputation beyond reputeThatGuy has a reputation beyond reputeThatGuy has a reputation beyond reputeThatGuy has a reputation beyond repute
Videos aren't working.
-'13 Pearl White
-CS Turbo inlet/SRI
-CS RMM
-COBB AP
-Autotech Internals
-H&R Springs
-JRB RSB
ThatGuy is offline   Reply With Quote
 Old 04-08-2013, 03:45 PM   #4
Steven's Avatar
Posts: 634   (View Stats)
Steven is the leader of the worldSteven is the leader of the worldSteven is the leader of the worldSteven is the leader of the worldSteven is the leader of the worldSteven is the leader of the worldSteven is the leader of the worldSteven is the leader of the worldSteven is the leader of the worldSteven is the leader of the worldSteven is the leader of the world
@ms3blackmica; thanks for the videos, you broke it down and I have finally been calibrating my MAF after about 6 months of having my AP.
Now I have a question. I am still getting aound 4.69LTFT but in voltages so low I dont log them when doing my second gear pull, I only see that when letting off of the gas or idling. Can I do a log at idle in neutral and use those values to calibrate that low? or is load required?
My Maf Cal overall is doing pretty well I would think exept for really down low, I have attached that in the first log.
The seond log is a short idle log to show you what I mean about my LTFT being off in the low MAF voltage range.
Thanks
2012 Mazdaspeed3 w/tech
Electronics: Cobb AP - Ultragauge - CS EBCS - Bosch 3 Bar
Engine: Autotech HPFP - Sure Aeros - Sure Return - HTP TIP - CS BPV - CS DP + RP - NGK 1 Step Colder Plugs
Steven is offline   Reply With Quote
 Old 04-08-2013, 03:53 PM   #5
Nishan
4.69 is good!
Steven (04-08-2013)
 Old 04-08-2013, 03:59 PM   #6
Steven's Avatar
Its not great though, maybe I have OCD, I just dont want to see those LTFT's.
 Old 08-27-2013, 04:11 PM   #7
Nishan
Added a new video to the OP from another thread that I made on using AccessTuner Race.
Enjoy guys.
rfinkle2 (08-27-2013)
 Old 01-15-2014, 03:19 PM   #8
SomeNobodyspeed3's Avatar
Posts: 63   (View Stats)
SomeNobodyspeed3 has a spectacular aura aboutSomeNobodyspeed3 has a spectacular aura about
Man I gotta lot to learm! Bringnit!
SomeNobodyspeed3 is offline   Reply With Quote
 Old 01-21-2014, 05:31 PM   #9
d4rk13l4de's Avatar
Posts: 6   (View Stats)
d4rk13l4de will become famous soon enoughd4rk13l4de will become famous soon enough
thanks for this!!
d4rk13l4de is offline   Reply With Quote
MAF Calibration Tutorial ms3blackmica MazdaSpeed 3/6 - ECU Computer Tuning 301 04-09-2019 07:50 AM
MAF Calibration Tutorial ms3blackmica MSF KB - Mazdaspeed 3/6 - ECU Computer Tuning 127 09-20-2012 07:37 AM
Monterey: 2012 Pebble Beach Concept Car Lawn offers a tutorial in cars to come Haltech Automotive News 0 08-19-2012 05:50 PM
Page generated in 0.47219 seconds with 25 queries
