![]() Join Date: Jun 2013 Location: Gilbertsville, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 201
(Thread Starter) | Not Ranked : 0 score Just got my internals installed today (thank you @faeker; ) along with my JBR intake and did a little log before I got home. 4th gear, very slight bank turn when I first started. Shitty road.. Everything looked ok, only thing that concerns me is the little bit of knock in the 3000's. I seem to get a very minute amount of knock for a few cells in each run. That is why it is concerning. But if someone could take a look at these couple logs I would appreciate it. Datalog3 is cobb ots stage 1 93 tune, datalog7 is the JBR S-OTS stage 2 tune. Thank you!
__________________ 2013 CWP Mazdaspeed3 |
![]() Join Date: Feb 2013 Location: Green Bay, WI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 945
| Not Ranked : 0 score .38 knock is nothing. Anything over 2.0 you need to worry about.
__________________ 2013 CWP Mazdaspeed3 - SOLD 2014 Mitsubishi Evo X - time for some fun. |
(Thread Starter) | Not Ranked : 0 score I worry about everything though lol. Thanks though. I tried plugging the newest log into VD but it did not seem to work well. I am guessing I need to pick a straighter stretch of road.
![]() Join Date: Sep 2012 Location: Elizabeth, NJ
Rep Power: 3180 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,265
Groans: 665
| Not Ranked : 0 score OTS maps by nature run fairly rich up top. It's most likely just noise. |
| Nishan ![]() Join Date: Apr 2012
Rep Power: 9816 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 13,290
| Not Ranked : 0 score 0.38 is absolutely nothing to worry about.
__________________ www.tunedbynishan.com |
| Not Ranked : 0 score That little fart knock you get at the end of the run is likely from coming off the throttle abruptly. I get the same bit of mechanical noise/settling when I go straight from WOT to the brakes at ~102mph. If Vdyno was giving you trouble, here's the graph for it. Just lobbed a 250lb occupant/stuff weight at it so you can surmise accordingly.
| The Following User Says Thank You to JgamB For This Useful Post: | lk250f (09-25-2013) |
__________________ 2013 CWP Mazdaspeed3 | |
| Not Ranked : 0 score I use CF 1.01, the sort of de-facto standard around here - the Vdyno default is 1.09 Dynojet, so you're looking more at 260/285 in this log assuming my guesstimate of 250lbs occupant n stuff was remotely accurate. You were about a 1/4 second faster from 60-100, so it's certainly making more power than your stage 1 log. The real fun starts when you get properly tuned.
I am not sure what happened to cause the logs to be so different. My 60-100 in that run was 6.59. I must have uploaded the wrong run..
| First Datalog (AP) | 2eatV8everyday | 2010 MS3 - ECU Computer Tuning | 8 | 09-10-2012 03:13 PM |
| First datalog | razorscs | MazdaSpeed 3/6 - ECU Computer Tuning | 5 | 03-24-2012 03:51 PM |
| My first Datalog...... | MS6FL | MazdaSpeed 3/6 - ECU Computer Tuning | 5 | 05-16-2011 03:10 PM |
| Datalog | tozfeekum | MazdaSpeed 3/6 - ECU Computer Tuning | 13 | 04-01-2010 12:43 PM |
| Little help with my datalog please | Stockturbo_Ms3 | Cobb ATR Support | 12 | 02-22-2010 09:31 PM |
