 Old 01-18-2012, 01:03 PM   #1
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
Default WGDC Inconsistencies with Boost Tuning - Random flatline and no wgdc compensation
Soooo, I've seen this in a couple cars, now:
On some runs, WGDC works perfectly. Other times, it stays at 0 for the entire run, and then other times it will only start to adjust a bit way too late to do anything worthwhile. I've seen it happen in an 07, an 09, and 2010 (which is what these logs are from).
In two of the cases, I just recompiled the tune in a new file and it fixed things, which led me to believe it was a corrupt file issue. But, I did that with the 2010 MS3 and it didn't help anything...
I've heard of this from a couple other folks, so I'm not the only one seeing it. Even some of the OTS tunes do it from time to time.
So, anyone else experienced this and have any luck diagnosing it? With all cases, both "Boost Error Comp" (BEC) and "Load Error Comp" (LEC) tables were in use, and all cells were populated with a value inequal to 0 (except the center, no-error value). The boost targets were set higher than achieved, as well as the load targets. "Load Dynamics" (LD) is zero'd, with the boost targeting box checked.
I don't think this is the same as the "shark fin" logs others reported, and @David@COBB explained, so I wanted to start this to get some ideas going and get the word out for anyone else experiencing it.
I am attaching an .xlsx file with seven (7) logs compiled into one dataset. All logs were taken in 4th gear. I've numbered each run in one of the rightmost columns, for anyone who wants to take a look. I have also attached the tune, in case anyone feels like looking at it. I'm also attaching a screenshot of the runs graphed over rpm, by run, showing calc'd load (blue) and wgdc scaled to 1/10 (red).
-06 MS6
-Corn fed 07 MS3 - Sold
The Following 6 Users Say Thank You to phate For This Useful Post:
ASHMS3 (02-11-2013), Boost_creep (01-18-2012), Bucker (01-22-2012), Lex (01-18-2012), ms3blackmica (02-10-2013), rfinkle2 (01-23-2012)
 Old 01-18-2012, 01:36 PM   #2
@Boost_creep and @Dano would have some input.
Boost_creep (01-18-2012), phate (01-18-2012)
 Old 01-18-2012, 01:52 PM   #3
Boost_creep's Avatar
Posts: 829   (View Stats)
I've been battling this issue for way too long.
It seems the best method (for me) of overcoming this issue, is halving the LEC, making the BEC a bit more aggresive, and setting the trl x gear tables either at, or slightly below logged values, for the specific rpm (as long as boost is reaching target). The only downside to this, is that there is still a bit of load correction (wg compensation) on initial spool up.
It's still a work in progress though. Lol.
www.dizzytuning.com
www.facebook.com/dizzytuning
The Following 3 Users Say Thank You to Boost_creep For This Useful Post:
ms3blackmica (02-10-2013), phate (01-18-2012), rfinkle2 (01-18-2012)
 Old 01-18-2012, 02:15 PM   #4
Eth Fiend
phate's Avatar
I believe in the most current tune (attached) the LEC actually is halved and the BEC has definitely been increased, lol. No dice. TRL x Gear values are close to what I want achieved. Have you tried recompiling your tune in a new file?
Also, what OTS map did you start with?
-06 MS6
Boost_creep (01-18-2012), rfinkle2 (01-18-2012)
 Old 01-18-2012, 02:24 PM   #5
Yes, I've recompiled like 4 times. Haha.
Stage2sf+tih+ic 93v200
Stage2sf+tih 93v210
Same results with both maps.
I have a 2009 btw.
www.dizzytuning.com
The Following User Says Thank You to Boost_creep For This Useful Post:
phate (01-18-2012)
 Old 01-18-2012, 02:31 PM   #6
Eth Fiend
phate's Avatar
Stage2sf+tih 93v210
I have a 2009 btw.
Damn man. Hmmmm, I wonder if there's any sort of sensor feedback that might cause this.
-06 MS6
 Old 01-18-2012, 02:35 PM   #7
JacksonMS30's Avatar
Posts: 2,242   (View Stats)
@phate, what is the IDC on the cars in question?
Maybe something to do with this...
Load Cap ... Again
2008 MGM MS3 GT
- HTA3586-
- P.E.R.M Twisted Top Mount -
- P.E.R.M.Tuning -
The Following User Says Thank You to JacksonMS30 For This Useful Post:
phate (01-18-2012)
 Old 01-18-2012, 02:37 PM   #8
TRex's Avatar
Posts: 3,139   (View Stats)
could it be IDC maxing out? like lex talks about here
Load Cap ... Again
The Following User Says Thank You to TRex For This Useful Post:
phate (01-18-2012)
 Old 01-18-2012, 02:42 PM   #9
Eth Fiend
phate's Avatar
Load Cap ... Again
No, it's not even close to that IDC, lol. This is actually on a stock fuel pump car on gas. I can't say for sure what the IDC is on this car, since we shouldn't be anywhere close to the fueling limit with 15psi of K04 goodness and pump gas.
And just for reference, I've seen ~120% IDC in my car and north of 140% IDC in bozo's car without having the ecu pull wgdc.
-06 MS6
Bucker (01-22-2012), JacksonMS30 (01-18-2012), TRex (01-18-2012)
 Old 01-18-2012, 02:48 PM   #10
TRex's Avatar
and we are sure this isnt another swas, tcs, dcs interference coming and trying to cut boost?
disable his swas and try again?
The Following 2 Users Say Thank You to TRex For This Useful Post:
 Old 01-18-2012, 02:49 PM   #11
Eth Fiend
phate's Avatar
That is a good point. These were all 4th gear logs, but I suppose it won't hurt to rule it out.
-06 MS6
TRex (01-18-2012)
 Old 01-18-2012, 05:12 PM   #12
I haven't had this happen to me when tuning a car since I did the following:
Added the trl-x gear tables to 75-100% throttle positions in the throttle - requested load tables (A, B and C).
Vertically interpolated those values up to the 50% throttle position (where I populate the wgdc up to) in the hopes for smooth overall operation.
Worth a try?
ms3blackmica (02-10-2013), MS3G35 (03-27-2012)
 Old 01-18-2012, 05:45 PM   #13
mrmonk7663's Avatar
Posts: 2,997   (View Stats)
What are you interpololating up to, stock values at 50 percent? This is what concerns me about the interpolation method on load tables A,B, and C. On E85 the stock values are too low at all throttle positions in my opinion. This forced me to make a custom load a,b,c table, through alot of trial and error. I think defining some baseline values at 50 percent and 6.25 percent would enable the interpolation to work much more efficiently. Load a,b and c play an enormous role in how the car acts at part throttle, even with load tuning turned off.
2011 Speed3-BT and shit
TEAM LBN BEERS -- FYCN
TEAM MUMFORD -- FYCN
 Old 01-19-2012, 05:12 PM   #14
G26
G26's Avatar
Posts: 2,988   (View Stats)
Groans: 39
My car is purely boost tuned, no load comp at all, and I have never had this happen over the many many logs I have done.
The only time I had my wgdc cut drastically like that, was when my ebcs was in 3port and I went about .50 psi over target.
The Following User Says Thank You to G26 For This Useful Post:
phate (01-23-2012)
 Old 01-22-2012, 08:06 PM   #15
Bucker's Avatar
Posts: 2,856   (View Stats)
Groans: 451
Odd WGDC behavior
I am having the issue too. FIX MEEEEE! Lol.
403whp/451ft/lb Dry Shot
phate (01-22-2012)
 Old 01-23-2012, 07:37 AM   #16
rcalt25's Avatar
Posts: 219   (View Stats)
rcalt25 has a reputation beyond reputercalt25 has a reputation beyond reputercalt25 has a reputation beyond reputercalt25 has a reputation beyond reputercalt25 has a reputation beyond reputercalt25 has a reputation beyond reputercalt25 has a reputation beyond reputercalt25 has a reputation beyond reputercalt25 has a reputation beyond reputercalt25 has a reputation beyond reputercalt25 has a reputation beyond repute
Groaned at 9 Times in 3 Posts
I'm gonna unhook my swas today to see if we can rule that out. Been really busy for the past week. I'll have logs to @phate this evening to see if it was the issue.
obx cbe, cp-e nano,cp-e tmic, jbr ssp and knob, jbr 88 duro rmm, turbosmart bpv, ngk 1 step colder plugs, autotech internals, Cobb tip, cp-e catless dp.
rcalt25 is offline   Reply With Quote
The Following User Says Thank You to rcalt25 For This Useful Post:
phate (01-23-2012)
 Old 01-23-2012, 07:42 AM   #17
@RichieRichness, this thread may end up being a good place for your issue if things don't get resolved in your next revision.
phate (01-23-2012), RichieRichness (01-23-2012)
 Old 01-23-2012, 09:32 AM   #18
Cobb Tuning's Avatar
Posts: 1,192   (View Stats)
@phate Can you post up the full logs of this happening?
-David@COBB
The Following User Says Thank You to Cobb Tuning For This Useful Post:
phate (01-23-2012)
 Old 01-23-2012, 09:41 AM   #19
Eth Fiend
phate's Avatar
-David@COBB
Yessir! The originals are attached to this post. Thanks for having a look!
-06 MS6
RichieRichness (03-22-2012)
 Old 01-23-2012, 12:15 PM   #20
RichieRichness's Avatar
Posts: 3,314   (View Stats)
Groans: 35
Has anyone considered using the load dynamics compensation table?
 Old 01-23-2012, 12:19 PM   #21
Atvfreek, DJ and Lex use the load dynamics table, and I'm pretty sure Lex has a car he is tuning now with jacked wgdc activity.
 Old 01-23-2012, 12:26 PM   #22
Groans: 35
I'm wanting to know the logic behind people doing hybrid tunes but not checking the "Use Abs. Load Target Table" check box...wouldn't you have more load based control over your tune with this box checked?
 Old 01-23-2012, 01:21 PM   #23
Looking at the Map and logs, there is a lot of changes to load in your created map. What I'd try at least once is removing the Load Error Comp to see if your requested load is influencing the calculation with load error, and forcing the entire system down.
-David@COBB
The Following 3 Users Say Thank You to Cobb Tuning For This Useful Post:
ms3blackmica (02-10-2013), phate (01-23-2012), rfinkle2 (01-23-2012)
 Old 01-23-2012, 01:53 PM   #24
Eth Fiend
phate's Avatar
-David@COBB
Will do. I just got a couple logs from the same car, but with SWAS unhooked, and the issue is still present. One log follows beautifully, the other log is late to adjust and never hits targets.
I'll set up a couple files tonight with different LEC/BEC values 0'd to see if we can narrow down or rule out a table, or maybe even one side of a table.
-06 MS6
rfinkle2 (01-23-2012), RichieRichness (01-24-2012)
 Old 03-22-2012, 09:58 AM   #25
Groans: 35
Can I get a follow up with this issue? I'm tuning @WhoIsJeremy and he is having a similar issue. We are load tuning his car based on the map i've been using for my car and WGDC is pretty much 0 for the entire run. Yet load targets are being met and boost is hitting 19psi. Very odd.
see attached:
datalog9.csv
We tried using an OTS map with a boost tune strategy and the opposite effect takes place....WGDC% hits and holds 99%
see attached:
datalog1.csv
The Following 2 Users Say Thank You to RichieRichness For This Useful Post:
btstarcher (02-10-2013), djuosnteisn (03-26-2012)
 Old 03-26-2012, 10:30 AM   #26
WhoIsJeremy's Avatar
Posts: 2,196   (View Stats)
WhoIsJeremy is the leader of the worldWhoIsJeremy is the leader of the worldWhoIsJeremy is the leader of the worldWhoIsJeremy is the leader of the worldWhoIsJeremy is the leader of the worldWhoIsJeremy is the leader of the worldWhoIsJeremy is the leader of the worldWhoIsJeremy is the leader of the worldWhoIsJeremy is the leader of the worldWhoIsJeremy is the leader of the worldWhoIsJeremy is the leader of the world
see attached:
Attachment 55611
see attached:
Attachment 55613
@David@COBB
2007 MS3 GT -- > World's first flying Mazdaspeed3.
2006 MS6 GT -- > World's first n2o Mazdaspeed6.
1990 LS1 RX7-- > Probably broke somewhere
#DIX, for all the single ladies
WhoIsJeremy is offline   Reply With Quote
The Following User Says Thank You to WhoIsJeremy For This Useful Post:
 Old 03-26-2012, 10:38 AM   #27
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
His pegging the MAP sensor in that last log with 99's. Jeremy do you have a mech boost gauge to keep an eye on what the boost really is?
And Rich... you say he "is" or "isn't" hitting his load targets? If he is, then the 0's are probably cause he's slightly over the load target.
Also, when you load tune, keep the "boost based" toggle enabled... it simply eliminates a few of the less common load inputs, but leaves the more dominant coarse load dynamics active.
Jeremy, what turbo is on the 6?
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
ms3blackmica (02-10-2013), rfinkle2 (03-26-2012)
 Old 03-26-2012, 10:41 AM   #28
see attached:
Attachment 55611
see attached:
Attachment 55613
Originally Posted by WhoIsJeremy View Post
Based on the logs, that looks like an WG actuator arm/BCS issue. With Load tuning, it tries to dump WG but can't (load targets met, it lowers target). With Boost Tuning, it's ignoring the load but can't do anything but target as high as possible to meet target.
-David@COBB
RichieRichness (02-12-2013)
 Old 03-26-2012, 10:46 AM   #29
it's a stocker baby k04
-David@COBB
You think the stock boost controller or the wastegate actuator went bad?
 Old 03-26-2012, 10:54 AM   #30
That odd behavior has been seen before on 2 cars that came in for a tune. Both of them had something wrong mechanically with the WG system. One just needed a new rocker arm (it was bent), the other one had a vacuum line leaking to the BCS.
I'd check it out mechanically to see what's up, and if it's something else move on to figuring out how to fix that.
-David@COBB
 Old 03-26-2012, 11:00 AM   #31
-David@COBB
I'm gonna do a boost test this week and make sure all the lines are good and I'll make sure all the mechanical parts are moving right. Thanks dude!
The Following 2 Users Say Thank You to WhoIsJeremy For This Useful Post:
djuosnteisn (03-26-2012), RichieRichness (03-26-2012)
 Old 03-26-2012, 10:34 PM   #32
Groans: 35
h8 u Jeremy!
 Old 03-27-2012, 07:04 AM   #33
h8 u Jeremy!
for what?!?! Aren't you supposed to be in vegas?! lol I havent sent you any logs for a reason.
 Old 03-28-2012, 12:45 AM   #34
Groans: 35
What year is it again? Niggah I haz laptop.
 Old 03-28-2012, 07:55 AM   #35
blah blah blah. Ill send ya logs when I get home than!
djuosnteisn (03-28-2012)
 Old 02-10-2013, 12:23 PM   #36
btstarcher's Avatar
Posts: 4,852   (View Stats)
Joining the club....WGDC starting off around 40-50, dropping to 0 rapidly. Overshooting boost targets and never quite getting it down.
SnailTune in progress
 Old 02-10-2013, 12:26 PM   #37
If you are overshooting boost targets and WGDC is 0 then you have a mechanical boost control issue. The ECU can't lower boost below what it can do at 0% WGDC.
Boost_creep (02-10-2013), btstarcher (02-10-2013), ms3blackmica (02-10-2013), phate (02-10-2013)
 Old 02-10-2013, 12:41 PM   #38
btstarcher's Avatar
Yeah, we're checking the connections to the BCS. The turbo is new, never been installed, but the BCS is from my old turbo. Justin found one of the hose clamps wasn't snug; it moves somewhat freely.
 Old 02-10-2013, 01:49 PM   #39
Nishan
ms3blackmica's Avatar
Posts: 5,635   (View Stats)
I guess I am quite lucky to say I have never encountered this issue before but I am glad I could read this thread for future reference.
www.tunedbynishan.com
No change in boost from 0% WGDC to 100% WGDC phate MazdaSpeed 3 - Engine, Transmission & Driveline 30 12-12-2011 03:27 AM
Boost Targeting with WGDC? RichB MazdaSpeed 3/6 - ECU Computer Tuning 20 10-12-2011 04:07 PM
WGDC @ 0...Boost Leak? mrmonk7663 2010 MS3 - ECU Computer Tuning 4 09-07-2011 10:46 PM
.33% WGDC at CL WorstEpEver MazdaSpeed 3/6 - ECU Computer Tuning 0 08-18-2011 07:09 PM
0 WGDC, High Load, Low Boost RJTSi
Cobb ATR Support
6 01-19-2010 10:04 AM
Page generated in 0.58586 seconds with 36 queries
