 Old 06-30-2018, 08:09 PM   #1
Dizzydaye's Avatar
Posts: 4   (View Stats)
Dizzydaye is an unknown quantity at this point
Default WOT KR with Stage 0 map?
Hello everyone I am new to the speed community. I have a 2012 Mazdaspeed 3 with 44k miles. I am currently experiencing 2-3 KR readings sometimes at WOT in 3rd gear or 4th gear pulls. My car is all stock except for a damond RMM, Cobb acessport and stage 0 tune.
attached are the 3 datalogs with the kr readings. Also the ambient temperature was 95 degrees fahrenheit on the day that I logged them.
About 5k miles ago I did not have these KR readings at WOT. And sometimes when I do another pull right after these readings show up my KR is fine all across the range.
should I be worried? Is my speed 3 okay? And should I get a compression check?
Dizzydaye is offline   Reply With Quote
 Old 07-01-2018, 02:33 AM   #2
Solarsurge's Avatar
Posts: 577   (View Stats)
Neutral  +1 score
AFRs in the 9s is way too rich. You should be seeing 11-12 at WOT. If you haven't changed your spark plugs yet, it sounds like it's about that time. Make sure they're gapped correctly. Also, it wouldn't hurt to clean your MAF sensor.
 Old 07-01-2018, 05:19 AM   #3
Dizzydaye's Avatar
Thank you Solarsurge. I am going to try and clean my MAF sensor and see if my spark plugs are gapped correctly and what condition they are in.
Also I read somewhere that the stock mapping runs rich to be safe on the engine is that true?
 Old 07-01-2018, 06:42 AM   #4
Solarsurge's Avatar
11s are rich. 9s are black smoke out the exhaust and backfires rich.
 Old 07-01-2018, 07:49 AM   #5
Police - Grammarhead
Vansquish's Avatar
Hot air+boost=knock. Also, knock retard + boost = low AFRs. The 9:1 AFRs are a reflection of the fact that you've got knock, and the car is attempting to compensate by adding fuel and pulling a boatload of timing.
Stage 1, Stage 2, and Stage 3 Dual OCC kits Matt@DamondMotorsports Damond Motorsports 0 11-10-2015 04:09 PM
First dyno pulls on Stage 1 and Stage 2 Cobb Maps PSmurf78 2010 MS3 - ECU Computer Tuning 11 05-14-2013 05:44 PM
Cobb ATR Support
4 05-24-2009 07:52 PM
Page generated in 0.25272 seconds with 23 queries
