![]() Join Date: Mar 2011 Location: Bradenton, Florida
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 143
__________________ 2010 CBM Speed 3 (Daily) Muffler Delete Sure Aeros TRZ Poly RMM 14.11 @ 100 2.1 60' 1986 Firetird 350 Chevy (2 Bolt Main) Stock Bottom End Edelbrock E-tec 200 Heads (Port, Polish, Decked) JE Pistons Ford 9" Rear End 4.30 Gears Stock Suspension 11.29@113.8 mph, 1.54 60' |
![]() Join Date: Jan 2009 Location: Newark, NJ
Rep Power: 1040 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,110
Groans: 661
| Not Ranked : 0 score Your fp is probably shitting the bed with the cat delete. Buy something to monitor your car... And some real mods |
![]() Join Date: Nov 2010 Location: Fort Worth, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 227
Groaned at 74 Times in 30 Posts
| Not Ranked : 0 score My guess would be fuel pump as well
__________________ //Stage 1 & Done\\ |
(Thread Starter) | Not Ranked : 0 score Meh not to worried about it right now as I said, but good thing I planned on internals and AP when I get back in 4 months.
Groans: 661
| Not Ranked : 0 score You might not be worried but keep running your car with a dead fuel pump and you'll need a new engine in no time. |
| jbr makes fall-a-parts. ![]() Join Date: Jan 2011 Location: Cambridge Ontario Canada
Rep Power: 13536 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 25,744
Groans: 793
| Not Ranked : 0 score Bpv or bov?
__________________ ![]() Inb4 85% silicone core. It's better than aluminum. What's you buddy's ex wife trap? I <3 SP63, but that port job though... "The coolant must be evaporating." Bye Felicia "Exclusivity" - CP-enis Demodded. The Seals |
![]() Join Date: Nov 2009 Location: Lacey, WA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,314
Groans: 48
Groaned at 16 Times in 14 Posts
| Not Ranked : 0 score lolol @ manel
__________________ "Pain? I ain't got time for pain.. Only pain I got time for is the pain i put on fools who don't know what time it is." -TTT |
![]() Join Date: Sep 2009 Location: Los Angeles, California
Rep Power: 442 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,334
Groaned at 72 Times in 51 Posts
| Not Ranked : 0 score fp
__________________ 2010 Mazdaspeed3 Cobb AP - CP-E SRI - Ultimate Racing TP - CP-E RMM 75D - JBR RSB - JBR SSP - Autotech HPFP Internal - Denso ITV22 - Advan RZ 18x8 (Conti ExtremeContact DW 235/40/18) |
![]() Join Date: Nov 2010 Location: Portland, OR
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 110
| Not Ranked : 0 score my car farts too but i have bolt ons and test pipe and stage 2 ots map it sounds beastly
__________________ 11' Speed 3 Mods: Stock for now. |
![]() Join Date: Oct 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,795
Groans: 89
| Not Ranked : 0 score Most likely AFTERFIRE. Backfire is no good. |
| The Following User Says Thank You to 08.5MS3 For This Useful Post: | Dre (06-24-2011) |
![]() Join Date: May 2009 Location: Chicago, IL
Rep Power: 10249 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,116
Groans: 136
| Not Ranked : 0 score It's not the fuel pump; it's the car going rich at throttle lift-off, and the fuel is igniting in the exhaust. It happens to all our cars (ECU runs rich to cool the engine and turbo), but the catalytic convertor absorbs the sound normally.
__________________ |
![]() Join Date: Nov 2010 Location: St. Louis missouri
Rep Power: 1310 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,310
Groans: 134
| Not Ranked : 0 score Wouldn't the car be running rich if the fuel pressure is dropping and the pump is dumping fuel? |
| The Following User Says Thank You to Ckmazdaspeed3 For This Useful Post: | manelscout4life (06-24-2011) |
Groans: 136
| Not Ranked : 0 score If the pressure drops then less fuel is being pumped in, not more. Plus, it's not at shifting that the pump has pressure issues; it's during WOT in the 4K RPM range (where we get max torque).
Groans: 134
| Not Ranked : 0 score Idk, I guess I'm missing a piece of the picture, because I am sure that the ecu responds to the pressure drop by dumping fuel... But I will be the first to admit that idk how all the pieces fit together. |
Groans: 89
Groans: 661
| Not Ranked : 0 score When the pressure drops the ecu adds more fuel. I was running an atr tuned map with an 11.8 AFR that I matching pretty closely to. When my fp first started breaking down (700-800psi) my AFR would be in the 10's at wot and the car would after fire. |
| The Following User Says Thank You to manelscout4life For This Useful Post: | Ckmazdaspeed3 (06-25-2011) |
Groans: 89
| Not Ranked : 0 score Backfire occurs in the induction side, such as intake valves that do not close soon enough. Afterfire occurs, as stated, with fuel being burned in the exhaust system. Afterfire is fine. Backfire is not. Tapawhat? |
![]() Join Date: Jun 2011 Location: whittier California
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 65
Groaned at 32 Times in 8 Posts
Sent from my T-Mobile G2 using Tapatalk | |
| The Following 2 Users Say NO Thank You to aanguia1 For This Un-useful Post: | Dre (06-25-2011), manelscout4life (06-25-2011) |
![]() | | #19 | ![]() |
(Thread Starter) | Not Ranked : 0 score Now that makes sense. and no, stock BPV. And the reason I'm not worried about it even if it was fuel pump, the farthest my car is moving in the next four months is about 75 feet a couple times a week from the house to the garage. Lol no need to dump money in something that ain't being driven. But thanks guys I didn't think to look up afterfires, that makes more sense.
![]() | | #20 | ![]() |
Groans: 134
Last edited by Ckmazdaspeed3; 06-25-2011 at 06:43 AM. Reason: MSF Database - Automerged Doublepost | ||
| The Following User Says Thank You to Ckmazdaspeed3 For This Useful Post: | 08.5MS3 (06-25-2011) |
![]() | | #21 | ![]() |
Groans: 89
![]() | | #22 | ![]() |
Groans: 89
Tapawhat? | |
| The Following User Says Thank You to 08.5MS3 For This Useful Post: | Ckmazdaspeed3 (06-25-2011) |
![]() | | #23 | ![]() |
| Not Ranked : 0 score my car afterfires . stupid OTS map my AFR's are like 10.8 at WOT
| The Following User Says Thank You to Soto For This Useful Post: | 08.5MS3 (06-25-2011) |
![]() | | #24 | ![]() |
![]() Join Date: Dec 2017
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score My afr was hitting 10s today while on a stock tune and muffler and res delete. Im getting it tuned soon just knocked out basic stuff first Sent from my VS995 using Tapatalk |
![]() | | #25 | ![]() |
![]() Join Date: Jun 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,505
| Not Ranked : 0 score Holy seven year old dead thread revival! Stock tune will get in the high 10s under max load, WOT at redline. It's deliberate to provide cylinder cooling to control knock. It allows the stock tune to use more aggressive timing than you might think. By all means get a good tune, but AFR that rich is normal on stock tune up high. Check your fuel rail pressure to make sure it is 1600 or better under WOT. As these cars age the pump's piston and cylinder wear. If you are getting a tune that raises boost above stock levels, a pump internals upgrade is mandatory, anyway. And, stop renewing 7 year old threads.
![]() | | #26 | ![]() |
| Not Ranked : 0 score Lol I didn't even look at the date that's kind of funny. But yeah I plan on getting hpfp anyways here soon and my fuel pressure is fine. I was just curious about pops Sent from my VS995 using Tapatalk |
![]() | | #27 | ![]() |
Groans: 136
| Not Ranked : 0 score Jesus this place has gone downhill with fucking noobs not reading shit. Sent from my iPhone using Tapatalk Pro
| The Following User Says Thank You to silvapain For This Useful Post: | MSMS3 (03-14-2018) |
| Backfire at WOT not when shifting!!! | Shooter445 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 8 | 04-04-2011 06:47 PM |
| Backfire? | danlash | Mazdaspeed3/6 General Discussion | 10 | 03-23-2011 04:25 PM |
| Anyone here get some serious backfire? | Death-From-A-Mile | Mazdaspeed3/6 General Discussion | 40 | 10-12-2008 12:47 PM |
| Pop/backfire at WOT/shifting? | aaronc7 | MazdaSpeed 3 - Engine, Transmission & Driveline | 74 | 05-23-2008 01:30 PM |
