 Old 07-04-2016, 08:15 PM   #1
Shwa's Avatar
Posts: 322   (View Stats)
Default Solenoid question with AEM kit
I'm installing an aem kit with a devils own solenoid because I'm going to be injecting post throttle body.
I've wired everything up, the pump is working but the solenoid isn't. When I primed it the solenoid filled up and then started leaking instead of feeding. It leaked out the "in port " out was dry. So it's not opening up
The solenoid has two black wires and according to devils own will work for power/ground either way. So one of the wires is to the brown/white wire to the aem controller, the other to ground.
Anybody have a similar set up and insight on how I should write it for it to function? Much thanks!!!!
3 Port Boost Control Solenoid / Boost Question Badinfluence MazdaSpeed 3/6 - ECU Computer Tuning 24 06-24-2013 02:59 PM
Upgraded solenoid install question. dsmluck MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 11 08-29-2012 01:02 AM
Where is the Boost solenoid ??? camdensms6 MazdaSpeed 3/6 - Turbo Induction 2 12-13-2009 09:25 AM
Page generated in 0.22506 seconds with 20 queries
