![]() Join Date: May 2012 Location: Cary, NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 46
Groaned at 6 Times in 4 Posts
(Thread Starter) | Not Ranked : 0 score There was one small piece that I couldn’t find, and that is a torque spec on the spring loaded bolts. My assumption is you tighten them by feel and visual. Is that the correct assumption? Thanks!
__________________ 2012 MAZDASPEED3 BLACK MICA (Stage 1, Cobb AP, Autotechs, Cobb SF, TIP & Airbox) Coming soon: 2nd etune 2013 MAZDASPEED3 Liquid Silver (Stock and not allowed to touch!) |
![]() Join Date: Apr 2010 Location: Weston, CT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,011
Groans: 214
Groaned at 15 Times in 13 Posts
| Not Ranked : 0 score I've been told to tighten them so there is no more than 1mm space between each coil on the spring.
__________________ 2013 Evo X - Stock (for now) 2010 Speed 3 - Sold |
| The Following 2 Users Say Thank You to CCC For This Useful Post: | captain slow (01-29-2013), jtt (01-30-2013) |
![]() Join Date: Feb 2012 Location: Quantico, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,434
| Not Ranked : 0 score They are not big....wrist tight.
__________________ [SIGPIC][/SIGPIC] 2013 Scion FR-S (Whiteout) GunMetal 16x8+25 Enkei CompE_Cusco OCC_ Kartboy Crank Pulley_Kartboy TMM insert_Koni Yellows_RCE Springs_K&N Drop-In_Eibach FSB_J2 Catless FP_WhiteLine Camber Bolts_Nameless Race Pipe_RBF600_Ferodo DS2500_PTUNING Tuned Less parking more racing |
(Thread Starter) | Not Ranked : 0 score Thanks!
![]() Join Date: Feb 2011 Location: Oshkosh, WI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,456
Groans: 398
| Not Ranked : 0 score Corksport has this in their instructions so I'd do that
__________________ 2007 MS3 Silver. Intake bits, exhaust bits, FMIC bits, freektuned, loved, cherrished, SOLD!!! 2014 5.0 Gotta Have It Green w/Track Pack |
| The Following User Says Thank You to captain slow For This Useful Post: | LumberJack (01-29-2013) |
![]() ![]() ![]() Join Date: Nov 2012 Location: Temecula, CA
Rep Power: 2724 ![]() Thanks: 3,896
| Agreed, that's about how tight i wrenched mine too!
__________________ 2018.... Doing even more freeky things! 10.36@148 Fastest Gen 2 |
| The Following User Says Thank You to LumberJack For This Useful Post: | CorkSport Vincent (03-20-2015) |
(Thread Starter) | Not Ranked : 0 score They do, but there is no mention of torque specs for the bolts I am referring to. Unless I missed it.
![]() Join Date: May 2009 Location: Chicago, IL
Rep Power: 10249 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,116
Groans: 136
| Not Ranked : 0 score A benefit of springs behind the nuts is that you don't have to be accurate with torque specs. I'd say the CorkSport instructions are sufficient. Tapadatass
__________________ |
| The Following 4 Users Say Thank You to silvapain For This Useful Post: |
![]() Join Date: Jan 2011 Location: Midlothian, Va
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 12,042
Groans: 274
| Not Ranked : 0 score I'd say that it probably doesn't matter much, but I'm in for a rough estimate on recommended torque. I've ran mine both ways and there was no noticable difference, but I just like to have stuff torqued properly whenever possible. |
Groans: 398
Torquing something with a spring involved can be tricky and may not be uniform for every vehicle. What may take you 10 ft lbs to do could take someone on another car 15 ft lbs for example. Thats why they just say tighten so there is about a 1mm gap. You could test it for us!
__________________ 2007 MS3 Silver. Intake bits, exhaust bits, FMIC bits, freektuned, loved, cherrished, SOLD!!! 2014 5.0 Gotta Have It Green w/Track Pack | |
| hidin in yo bushes ![]() Join Date: Mar 2012 Location: Soviet Maryland
Rep Power: 6573 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,956
Groans: 122
| Unless its something important... meh...
__________________ CP-e S2 RMM // TurbineTech FMM // Ghetto SRI // 3" ATP MAF housing // Ultimate Racing CBE // Ebay Downpipe // Cobb AP // Autotechs // PG TIP // HKS V4 BOV // NGK Iridiums // ACT Street Disc // JBR Trans Mount Rich Tuned 330WHP and 363TQ 10-19-13 Moore Automotive ![]() |
| The Following User Says Thank You to CWP_MS3 For This Useful Post: | chuckms6 (01-30-2013) |
I just took a guess and went with it, hope for no leaks. One thing that was interesting was the supplied rear donut gasket. UR comes with a new donut gasket for the rear of the TP, but not the front. It was a lot smaller than the Mazda supplied one, and I almost didn’t even see it when I was installing. I wasn’t sure if I should remove it and replace it with the stock one, or just use it. Long story short, I just used the one supplied from UR.
__________________ 2012 MAZDASPEED3 BLACK MICA (Stage 1, Cobb AP, Autotechs, Cobb SF, TIP & Airbox) Coming soon: 2nd etune 2013 MAZDASPEED3 Liquid Silver (Stock and not allowed to touch!) | |
![]() Join Date: Aug 2012 Location: North Texas
Groaned at 22 Times in 10 Posts
| Not Ranked : 0 score I was worried when I installed the corksport racepipe, I seems way to loose, I tightened a little more than instructed, then I shook the hell out of it to try and get it to seat, seemed to work, the instructions say to recheck in a thousand miles sounds like good advice. |
(Thread Starter) | Not Ranked : 0 score Did the CS come with any donut gaskets or were you to re-use the stock ones? I had a big gap when I put mine. It made it super easy to install, but I was a little worried that it might leak.
| Not Ranked : 0 score I tried to leave some space in between the spring as instructed, but was leaking @ the joint. The only way I could get my test pipe to seal properly was to tighten the springs all of the way down. I now have no space in the springs and have been using the pipe that way for 10k + miles with no problem. |
![]() Join Date: Nov 2011 Location: Minooka, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 545
Tapatalk LIKE A BOSS!
__________________ 2012 Mazdaspeed3 Black Mica HYPNOTIC TUNED, FREEK TUNED, HTP full 3" intake/TIP, HKS SSQV 4 full VTA, Corksport catless downpipe, Corksport catless Racepipe, Cobb AP V3, Autotech Fuel Pump Internals, JBR 88duro RMM, JBR 88duro TMM, JBR 80duro PMM, JBR cylindrical shift knob, Fidanza aluminum flywheel, EBC green brake pads, Centric high carbon rotors, Nitto NT555 tires, Gorilla spline lug nuts, DDM tuning HID's lows, Resonator Delete. | |
![]() Join Date: Jul 2011 Location: Glendale Heights, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 507
| Not Ranked : 0 score seconded ^^^^^^^ i tightened my shit all the way and it works fine. just get it to seal is all thats important.
__________________ Ultimate Racing // testpipe, catback // TWM // Full Replacement Shifter, Short Shift Boot // Cobb// AP // Sure aeros, sidewinder, shortcut, ags SS knob, return, chargetubes, countershift // Corksport // License Plate Relocate, Fog Light LED's, Interior LED's, Poly Exhaust Hangers, Oil Catch Can // PTP// HPFP Upgrade, 2150 rail valve // H&R // SS Coilovers // SPC// Adjustable Camber Arms // Hawk// HPS Brake Pads // Ebay Chargespeed Lip 06-07 STI Lip // DDM 8K 55W HIDs // JBR// Rear Sway Bar, 88D RMM, AP Mount //WHITELINE// Front End Links // ETS// TMIC// |
(Thread Starter) | Not Ranked : 0 score That’s interesting that so many had to tighten it to the point there was no gap in the springs. Did anyone just try re-using the stock rear donut gasket to take up some of the slack? It seems like that may be the answer. I can only assume mine is not leaking. I don’t hear any air pissing out at idle or while revving it. But under load with the motor moving around maybe it does leak. With an intake, RMM, and TP it is louder to point where you would never be able to hear leaking while driving. Next oil change I will do a visual, and look for any soot around the joints. On a different note, I was going to post this as a new question, but maybe it is best here. I am a getting a LOT more vibration now with the TP, especially within certain RPM ranges. I am trying to figure out if is due to lack of a resonator in the TP, or that I need to tighten or loosen the bolts holding it. It has also produced a rattling somewhere outside the car. Might be a heat shield, but it sounds like it is around the muffler more. I only have 6K miles and nothing was rattling before the TP install. Any ideas on how to remedy that, aside from putting the old cat back on! LOL
![]() | | #19 | ![]() |
![]() | | #20 | ![]() |
(Thread Starter) | Not Ranked : 0 score Thanks. I will start with that then. So would you say that added vibration is not typical with a TP install?
![]() | | #21 | ![]() |
![]() Join Date: Nov 2011 Location: Raleigh, NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,624
Groans: 63
| Not Ranked : 0 score Didn't I tell you just to put it on as it was? Unless you bought a different one than what I gave you... The one I gave you was a corksport 80mm. The donut gasket on it was my stock one that I had to tear up to make it fit (this is what happens when you're sold a pipe that isn't the one you're told you're buying). That gasket has to be there, the stock one doesn't fit, and it does seal perfectly (at least it did on my car for almost 15k miles).
__________________ Blue Pu. "Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." |
![]() | | #22 | ![]() |
![]() ![]() Join Date: Jun 2008 Location: Greenville, SC
Rep Power: 2562 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,586
Groans: 125
| Not Ranked : 0 score i like to consider the germans when torquing stuff like this.... "guten tight" there is a bead on the bolt. seat that up against the flange, and get it good and tight. easy as that.
__________________ 1994 Mazda RX7 - 20b-rew - S480sx - Injector Dynamics - Xcessive Manufacturing - Full Function Engineering - Haltech Elite 2500 |
| The Following User Says Thank You to socks For This Useful Post: | rfinkle2 (02-03-2013) |
![]() | | #23 | ![]() |
I was going to re-use the stock bolts and nuts but another MSF member advised against it.
![]() | | #24 | ![]() |
I have been meaning to call you. I was going to use the CS with missing hangers you gave me but decided against it. I know you didn’t have any issues with it, but we are only talking a $150 for a new one, so that’s what I decided to do. BTW, I am hanging on to yours so I can get it back to you. I figured you might know someone else that could use it.
![]() | | #25 | ![]() |
Groans: 63
Really though, just throw it up for the price of shipping here, I really don't care. It's just more crap for the girl to bitch about. Either that or put it up in the nator NC section same deal. Or better yet put it on your wife's car, you know that isn't staying stock long.
__________________ Blue Pu. "Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." | |
![]() | | #26 | ![]() |
By hangers, you mean the pieces you cut off, right?
![]() | | #27 | ![]() |
Groans: 63
| Not Ranked : 0 score yep, those. they're sitting in a box of car parts in a closet. Not sure why I kept them, they just made it back into the box and never left.
| Length of test pipe bolts | GODspeed7 | 2010 MS3 - Engine, Transmission & Driveline | 14 | 05-09-2012 04:47 PM |
| How far to torque bolts? | drenkel | 2010 MS3 - Engine, Transmission & Driveline | 4 | 05-16-2010 10:26 AM |
| Doing a corksport test pipe install, bought it used, what bolts will I need | jasonspeed3 | MazdaSpeed 3 - How-To's | 15 | 12-03-2009 01:41 PM |
| INstalling a used CS test pipe in the morning, what bolts will I need? | jasonspeed3 | MazdaSpeed 3 - Engine, Transmission & Driveline | 5 | 07-11-2009 10:25 PM |
