| Site News Please stop by here for the latest information on the forum. |
(Thread Starter) | Not Ranked : 0 score Once someone gets over a certain post number, what is the reason behind this? If there is some logic behind this feature, is there a way we could get the option to merge or not to merge a post?
| Lurkers
Posts: n/a
| why would u want 2 posts if they are consecutive of yourself anyway. its just unnecessary clutter and post numbers . are you a post whore? |
| The Following User Says Thank You to For This Useful Post: | doubleflusher (01-31-2010) |
![]() Join Date: Jul 2008 Location: Houston
Rep Power: 472 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 138
Further, I personally find it preferable to separate replies to different people in different posts. It might be the same thread, but, there can be "sub threads" so to speak in a thread, where different people are expressing their ideas, and I'd rather have my responses to each one separate. | |
Groans: 78
| Not Ranked : 0 score one of the biggest reasons is if you have a fs thread and need to bump it!
__________________ [Precision 5557 T4 flanged Journal Bearing Turbo][Race Roots Ceramic Coated T4 Manifold][Race Roots 3" V-Band Catless Downpipe][Race Roots Under-Car FMIC kit][CXracing 18"x31"x3" IC Core][Tial 44mm EWG With 0.9Bar Spring][Cobb AP][Full Str33tunit Mount Set][Madvillain 4" Inlet/Intake][Cp-e xcelXL Maf Housing][Devilsown Meth Injection Kit][HKS Ignition Amplifier][Cp-e Catback Exhaust][HKS bov][PTP IM Spacer][Whoosh EGR Delete][AEM Digital Boost Gauge][Matt Damond OCC Kit][Trunk Mounted Optima Battery with KnuKonceptz Kit][Madvillain ECU box][TWM Short Shifter][BC Coilovers][Cobb Rear Sway Bar][Falken Azenis rt615's][Eibach Pro 25mm Spacers] |
| There is no need to bump posts here.
| The Following User Says Thank You to Haltech For This Useful Post: | doubleflusher (01-31-2010) |
![]() Join Date: Jan 2010
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() Thanks: 0
| Not Ranked : 0 score As a n00b here I've found some of the post rules very irritating. I've tried to PM and post in several threads to buy stuff and I'm not allowed until some ridiculous amount of post. I understand why, but I think the system discourages a lot of users like myself. Just my opinion. |
![]() Join Date: Apr 2009 Location: Danbury, CT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,870
if someone were allowed to buy/sell stuff right away, I think u would see more problems and returns of parts. People buying then changing there mind. If ur going to buy a $500 used part off someone, just think of it like sale tax, $10 to donate to the site on time thats it.
__________________ 08.5 MS3 GT - COBB AP : HPFP : DM CatchCanBack to almost stock! 99 Miata NB - Stock for now Building a EFR 6258 Kit w/ Megasquirt 2 enhanced, COPs, Methanol, 750cc Injectors | |
| The Following User Says Thank You to DSIT995 For This Useful Post: | doubleflusher (01-31-2010) |
| The Following User Says Thank You to BacDoc For This Useful Post: | DSIT995 (01-31-2010) |
![]() Join Date: Dec 2009 Location: Denver, CO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 29,434
Groans: 40
| Not Ranked : 0 score ^^ what he said. I do understand why tho, but being recommended to come here in search of parts, it does make it rather difficult/discouraging. On the other hand, the double post merge...I know there have been times where no one has posted since the last time i did, and when I do post new info, say data logs, it merges and doesn't appear I added anything new. |
If you have major spam issues or post whoring you should have mods constantly viewing the boards for that stuff. | |
![]() Join Date: Feb 2009
Rep Power: 151849 ![]() Thanks: 55,993
Groans: 1,443
| Not Ranked : 0 score I think the double post rule sucks, but it's a rule of the forum. I can choose to not use this forum. I also think that if someone double posts, they are to be warned, and eventually punished. Users need to be responsible and take responsibility for their own actions. Don't be a cunt and double post to bump your for sale thread. If your shit isn't selling, it's because people don't want it or it costs too much. Double posting is only effective, and welcomed, in the VIP section.
__________________ Evo VIII - 9.93 @ 150.05 - CAI and LEDs Beanfab / Tuned by Nishan |
| Not Ranked : 0 score NASIOC thats a great site, im not a member but I have trolled threw it many times. Like the flashing lights u got now Mr VIP
| Not Ranked : 0 score Bling! Bling! NASIOC is very unique. And unbelievable wealth of knowledge and comedy, but OT is not easily accessible. I've been trying to change the tone of OT to make it more user friendly. |
| Ok, i made a few changes to the system in regards to this to see how it goes... The whole purpose of this is to prevent two problems i saw here: 1) Post Whoring - To gain access to FS area 2) Abusive Post Bumping Ive set a post to be merged within 10 minutes. After 10 minutes, it will now be a separate post. The second thing i added is that when a post IS merged within that 10 min period, the post with be auto bumped as if there was a new post. Lets see how this works out for you guys now.
| The Following 14 Users Say Thank You to Haltech For This Useful Post: | 06Speed6 (02-04-2010), aaronc7 (02-01-2010), Aetherfury (02-04-2010), Alpha (02-01-2010), danesti (02-01-2010), Darksun280 (02-01-2010), djuosnteisn (02-01-2010), doubleflusher (02-01-2010), DSIT995 (02-01-2010), E4Performance (02-01-2010), ETERNAL (02-01-2010), fjames (02-01-2010), FreeFlyFreak (02-01-2010), superskaterxes (02-01-2010) |
![]() Join Date: Dec 2009 Location: Chicago
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,256
Groans: 40
| Not Ranked : 0 score ^^that sounds perfect to me! I agree w/ merging posts if they're made right after each other, but like I said, I've made posts to threads a day or more later that were merged...that didn't make sense to me. Again, I like the new setup!!! Thanks for at least hearing us out and looking to provide a solution, as a newbie here, that shows me u have at least SOME respect for your users |
Groans: 1,443
After you are here for longer, you'll see more gestures like this from him. Now you may consider donating to this site of awesomeness. http://www.mazdaspeedforum.org/forum/foru...donation&id=20
__________________ Evo VIII - 9.93 @ 150.05 - CAI and LEDs Beanfab / Tuned by Nishan | |
![]() And there's nothing wrong about making a profit from your sponsors and donors. This site provides some value to it's users and vendors. | |
| The Following User Says Thank You to BacDoc For This Useful Post: | doubleflusher (02-02-2010) |
![]() | | #19 | ![]() |
| I respect all of my users... But we also have rules in place to protect users. But unlike other forums, we listen and care.
| The Following 4 Users Say Thank You to Haltech For This Useful Post: | 06Speed6 (02-04-2010), danesti (02-01-2010), doubleflusher (02-01-2010), superskaterxes (02-01-2010) |
![]() | | #20 | ![]() |
My earlier criticism was merely constructive insight from someone who knows and understands how these things work. Thanks! | |
![]() | | #21 | ![]() |
| Not Ranked : 0 score Thanks for finally addressing this Hal! It makes some of the more technical threads much more effective IMO. Giant thank you.
__________________ 500awhp 440awtq uncorrected ![]() EFR8374 ms6, no meth, 50/50 e85, and IDCs in the 90's @ 500+ awhp, with room to grow... fifth port winning. Count down to head lift.... 3.... 2.... 30r ms3 dd on deck, has fuel... needs top mount turbo lovin' next... Check out the hair Salon: www.permtuning.com |
![]() | | #22 | ![]() |
![]() Join Date: Oct 2009 Location: Andersen AFB, Guam
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 717
Groans: 124
| Not Ranked : 0 score Nice to see this adressed. I post post after post sometimes ad I think of new things. I understand that being merged. But if I have my own thread and something changes its nice for it to be a new thread. |
![]() | | #23 | ![]() |
| Not Ranked : 0 score Thanks for the changes. I have a suggestion for Hal's consideration. I don't personally understand post whoring, I couldn't care less what my post counts are. But, if that is a concern, as a suggestion, make consecutive posts not count towards a post count, regardless of whether they get merged or not. Even if its days or weeks later, if they are consecutive they don't add to post counts. Just an idea. |
| Double Post Merge | djuosnteisn | Website Help/Feedback | 12 | 02-01-2010 04:54 PM |
| Report: Marchionne says Chrysler and Lancia could be merged within a year | Haltech | Automotive News | 0 | 01-20-2010 10:50 AM |
| Auto Merge Double posts | MZRDISI4 | Website Help/Feedback | 11 | 07-31-2009 07:46 AM |
| Toyota and Ford post double-digit declines | Haltech | Automotive News | 0 | 08-01-2008 12:00 PM |
| Mexico seeks to double auto industry size | Haltech | Automotive News | 0 | 07-14-2008 01:50 PM |
